Old 12-23-2012, 12:23 AM   #1
motorace
Member#: 339003
Default explain imprezas AWD?
from what i know about 4x4 ford trucks, which i can be wrong about, the 2 fronts wheels would be locked together with one of the rear tires, with least resistance rear, having power. thus, 3 wheels have power while in 4x4.
what does an impreza have? with the computer transferring power to slipping wheels, does that means it's similar, as in 3 wheels have power?
(or like other brand awd vehicles, where its just 1 wheel up front and 1 wheel in the back and call it awd?)
motorace is offline   Reply With Quote
Old 12-23-2012, 07:44 AM   #2
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
Old 12-23-2012, 08:07 AM   #3
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Old 12-23-2012, 08:14 AM   #4
Zeeper
Member#: 299286
2015 WRX CVT
look at the AWD wiki, it depends upon whether you have a CVT or a 5 Speed which type of AWD the car has.
I don't think every single claim on the wiki document is accurate, but that has been discussed on the forum multiple times. It does give you a general idea of the different systems and how they work.
Most videos including those above show the CVT/Auto version of symmetrical AWD.
In no case is it like the systems you are describing.
http://www.awdwiki.com/en/subaru/
Old 12-23-2012, 08:27 AM   #5
Guzzi 1
Member#: 338666
2014 Impreza Limited
SWP/Blk Leather CVT
Great videos! I had not seen them before. They pretty much explain why Subarus can deal with bad roads easier than many other vehicles.
John
edit: Friday night when I got off work, the roads in these parts were beyond bad. With the wind and snow, salt and plow trucks could not keep up. Thw vehicle I drive at work is a full size Ford van without posi traction. It is by far one of the worst vehicles I have ever driven in snow, rivaling that of '60's and '70's muscle cars. I can tell you with certainty that the system used with the CVT does as well as the 5 speed manual system that was in my '03 WRX. EVERYBODY around me was struggling to make up hills and I was able to drive easily. No drama. Just as if the road was dry. THAT is why Subaru owners are smiling when driving on wintery roads. ;-))
Old 12-23-2012, 11:18 AM   #6
BajaGuy68
Member#: 127720
2015 WRX
Lightning Red
Loved the video's! I love my Subies and that is why I'm on my fifth one now.
BajaGuy68 is offline   Reply With Quote
Old 12-23-2012, 11:23 AM   #7
grubincan
Member#: 300961
And this one is a lot of fun too, if you have an hour to spare....
It's surprising how many vehicles have trouble on a just pair of front or rear rollers (is that a BMW xDrive that can't get off a single rear roller?) it would be nicer to see some other makes and newer models.
grubincan is offline   Reply With Quote
Old 12-23-2012, 01:13 PM   #8
Zeeper
Member#: 299286
2015 WRX CVT
I like this video the best, expecially because it shows the CVT Crosstrek holding its own with a dedicated 4WD Landrover. You can see how well the Symmetrical AWD (electronic clutch version) and VDC work together to limit wheel slip and transfer power.
Old 12-23-2012, 01:59 PM   #9
hemophilic
Member#: 301213
2012 Imp. Sp. Ltd.
Blue/Silver
^^ That's impressive.
Old 12-24-2012, 01:20 AM   #10
ans2k
Member#: 315631
2012 Impreza Sport
AWD sistems wars (testing) on rollers - YouTube
watching that video make me doubt a little about the legendary awd system of subaru.
Old 12-24-2012, 06:30 AM   #11
M45
Member#: 333446
2013 Impreza SL CVT
i'm not sure rollers is a great indicator of much since no one ever drives on rollers.
Old 12-24-2012, 10:32 AM   #12
Commander Keen
Member#: 319157
2012 Impreza 4DR 5MT
I think a VDC-equipped Subaru would have behaved differently.
Old 12-24-2012, 10:51 AM   #13
Zeeper
Member#: 299286
2015 WRX CVT
You don't have to think it, look at the Crosstrek video and notice that when a wheel has no traction it cuts off power to that wheel pretty much instantly. There is almost no wheel slip, and less than the 4WD Landrover!
What subaru was that in the roller video? It may not have had any traction control, only AWD?
Old 12-24-2012, 11:06 AM   #14
Snow Drift
Member#: 75071
4 Train - Subway
Past: 05, 08, 11 Red WRXs
No, all Subarus (save the BRZ and foreign kei cars) use full-time awd which is never deactivated. All 4 wheels receive power all the time unless slipping occurs where the system needs to reroute it.
2011+ Impreza 5MT
Rear Differential = Open (VDC applies brake to slow spinning wheel)
Front Differential = Open (VDC applies brake to slow spinning wheel)
Center Differential = 50/50 torque split ALL the time. A viscous coupling center differential has metal plates that are connected to either the front or rear driveshafts and are surrounded by a viscous fluid. During normal driving the metal plates spin at an even 50/50 rate. Upon either axle slipping that shaft's metal plates will begin to spin at a faster rate that the other. The shearing action of the plates and heat from friction causes the fluid to harden. The hardening fluid thus slows the spinning plate and forces all plates to spin at 50/50 again. This is a VERY good system.
Turn off VDC when in deep snow to prevent Engine Power Reduction from stalling the motor.
2011+ Impreza CVT
Center Differential = Actively changing torque split (60/40 normally per SOJ and SCI). A multiplate clutch system is housed in the center differential which can be compressed based on a number of sensors (throttle position, wheel slip, steering, etc). The computer will determine how much clamping pressure to apply to the center, thus altering the amount of torque flowing between the front and rear driveshaft. A major difference between Subaru and others is that the system is not FWD until slip. The system will alter the torque split if you merely push down the gas pedal. It is not a fwd car that only kicks in the rear tires in bad situations. This system works well for normal snow driving. Not designed for off-road.
Snow Drift is online now   Reply With Quote
Old 12-24-2012, 11:13 AM   #15
Commander Keen
Member#: 319157
CVT Center Differential = None
Old 12-26-2012, 03:54 PM   #16
riccnick
Member#: 311152
2012 Impreza
Ice Silver Metallic
^This
riccnick is offline   Reply With Quote
Old 12-26-2012, 07:59 PM   #17
Snow Drift
Member#: 75071
4 Train - Subway
Originally Posted by riccnick View Post
^This
Uh, there is a center differential. It is built into the rear of the transmission and contains clutch packs. How do you think power is split between the front and rear axles?
Old 12-26-2012, 08:02 PM   #18
Commander Keen
Member#: 319157
There is not. It is possible to combine a differential with an MPT clutch, just like the 5MT combines a differential with a viscous coupling, but this is not what the CVT has. It has only a clutch pack.
Old 12-26-2012, 08:46 PM   #19
Snow Drift
Member#: 75071
4 Train - Subway
And the clutch pack is the differential. It allows the front and rear axles to rotate at different rates or compress the packs and come to 50:50. It may not be a mechanical gear but it is a differential. You're playing semantics. If it didn't have a differential you wouldn't have AWD (unless you had two axle motors or hub motors)
Old 12-26-2012, 08:56 PM   #20
Commander Keen
Member#: 319157
A clutch is a clutch and a differential is a differential.
A differential allows shafts to rotate at different speeds with very little power loss.
A clutch must either disengage, or dissipate the difference in motion as heat.
The CVT's rear wheels can never turn faster than its front wheels.
Old 12-26-2012, 09:14 PM   #21
Snow Drift
Member#: 75071
4 Train - Subway
So would you say the Evo 9 and 10 don't have center differentials? Their center is a clutch pack.
Old 12-26-2012, 09:27 PM   #22
Commander Keen
Member#: 319157
Like I said before:
The Evo is an example of a real center differential combined with a clutch pack. Again, this is NOT what the CVT Impreza has.
See: http://www.roadandtrack.com/car-news...ntial-you-5535
Old 12-26-2012, 10:45 PM   #23
Snow Drift
Member#: 75071
4 Train - Subway
Evo ACD is just clutch packs.
Old 12-26-2012, 11:05 PM   #24
Commander Keen
Member#: 319157
Old 12-27-2012, 12:46 AM   #25
cnlson
Member#: 310098
2012 Impreza PremCVT
Dark Cherry Pearl
CK,
do you have an exploded view of the Rear Diff on a 12 CVT? i looked and am unable to locate one. I'm not argumentative, I'm actually really interested.
cnlson is offline   Reply With Quote
