Welcome to the North American Subaru Impreza Owners Club Friday November 28, 2014
Old 12-22-2012, 11:56 PM   #1576
06SE
Member#: 158925
12' Sport LTD
MBP
Originally Posted by Zeeper View Post
Since someone asked, there are urethane mudflats that are 1/3 the cost of Rally Armor.
I just ordered a set of the 'simplified' (more my style, the original look a bit oversized)
http://www.ebay.com/itm/321026873742...84.m1497.l2649
www.Flapatax.com[/url] or search for flapatax on ebay when the above link is dead.
They sell two styles, pictured below, both styles are on ebay or their site, along with full mounting hardware and instructions.
http://www.subaruforester.org/vbulle...09/index2.html
Flapatax does not currently make a set specifically for the 12+ Impreza. I inquired ~1 month ago. He said it's on his list though.
06SE is offline   Reply With Quote
Old 12-23-2012, 12:26 AM   #1577
Zeeper
Member#: 299286
2015 WRX CVT
According to the ebay listing, these will fit. I'll let you know.
Keep in mind fitment is about the placement of the screw holes and how it mounts on the car. I would bet the basic pattern and size of the mudflaps is the same for all the flaps they make. This is also probably true for Rally Armor.
Old 12-23-2012, 05:43 PM   #1578
goregasm
Member#: 331656
2012 2.0i
Marine Blue Pearl
Anyone that can offer any help thanks in advance.
I keep bottoming out my car on snow banks and ****tily-designed driveways from businesses. Are there any springs with a higher ride height? Like maybe an inch or two? If I'd known about the crosstrek I would have waited but nope. AWD is kinda sad for most uses unless your car is a fair height above the ground.
goregasm is offline   Reply With Quote
Old 12-23-2012, 06:05 PM   #1579
von Wachtstain
Member#: 52726
May I ask what car were you driving before Impreza? Jeep? Because stock height of Impreza is rather high.
von Wachtstain is offline   Reply With Quote
Old 12-23-2012, 06:26 PM   #1580
kinger37
Member#: 324423
2012 Impreza Sport
ISM
Check out subtle solutions. They have 1 inch lift kits for our cars.
kinger37 is offline   Reply With Quote
Old 12-23-2012, 08:06 PM   #1581
thom52
Member#: 309257
2012 Imp 5D Prem CVT
Marine Blue
Unhappy
Biggest problem I find with the Impreza, compared to other cars I have owned is it has the worst (lowest)entrance angle I have ever experienced.
Even just slightly angled driveway entrances have been tearing the crap out of the stock front air dam due to a very long overhang past the front wheels. I can't even imagine adding that extra bit of plastic on the front to make that even lower!
thom52 is offline   Reply With Quote
Old 12-23-2012, 11:32 PM   #1582
Dirt Bringer
Member#: 340297
2013 Impreza 5sp Prm
Ice Silver
Originally Posted by scoutisimo View Post
and don't come back without an impreza.
It has been done.
Dirt Bringer is offline   Reply With Quote
Old 12-23-2012, 11:53 PM   #1583
Zeeper
Member#: 299286
2015 WRX CVT
Flapatax Update.
He contacted me because he listed the flaps for a 2012 Impreza 2.0 on ebay but hasn't officially released that one, though he has the hole pattern info.
I may be the guinea pig. We shall see, I'll let you know what the response is.
Old 12-24-2012, 12:11 AM   #1584
kinger37
Member#: 324423
2012 Impreza Sport
ISM
Flapatax Update.
I just ordered some as well. He said he would mark out the holes but I would have to drill them myself. This way if the holes dont line up I can move them. I'm glad you posted these. I like the design of the origional much more than the rally armor, plus the price is a big bonus!!
Old 12-24-2012, 02:31 AM   #1585
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I actually installed my rally armor flaps tonight, pretty easy process but I had to work slow because my car sat outside in 5f trends all day, and after being in the garage for an hour with the heat going out didn't warn up that much.
The brackets included were well worth the extra money imho, I could of fabbed some up, but this was much easier, and some we got them for 20% of price was reasonable
flyboy1100 is online now   Reply With Quote
Old 12-24-2012, 11:38 AM   #1586
pumpkyn
Member#: 156347
1997 Milano EK
2004 Platinum Wrex
Flapatax Update.
Thank you guys!
pumpkyn is offline   Reply With Quote
Old 12-24-2012, 01:04 PM   #1587
Dirt Bringer
Member#: 340297
Ice Silver
Is there any serious improvement to be gained from adding the sti strut brace to the Impreza?
Old 12-24-2012, 01:21 PM   #1588
goregasm
Member#: 331656
2012 2.0i
Marine Blue Pearl
This
and thanks whoever said subtle solutions, i'll check it out.
Edit: Nope, it's STi/WRX only.
Old 12-24-2012, 01:24 PM   #1589
Kyle Paton
Member#: 1184
2012 Impreza
Dark Grey Metallic
Anyone order any of the Whiteline Suspension stuff yet? There is alot listed in stock by vendors in the US.
Im about to order the BSR49Z rear sway bar
Kyle Paton is offline   Reply With Quote
Old 12-24-2012, 01:27 PM   #1590
kinger37
Member#: 324423
2012 Impreza Sport
ISM
This
http://www.subtle-solutions.com/prod...roducts_id=105
I contacted them and they said it WILL fit our Impreza's
Old 12-24-2012, 01:44 PM   #1591
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
Then you've never owned a VW TDI. Not only are those cars 1" lower than our Imprezas, but the TDI engine is taller than the gasser engine that VW also fits into these cars. VW couldn't mount the TDI engine higher, so their solution was to drop the TDI engine down lower. As a result, the fragile oil pan on the TDI actually hangs below the car's subframe, leaving it wide open to strikes against road debris, ice chunks, curbs, and so on.
I had a skid plate installed on the TDI that I dumped. I don't feel a need to install a skid plate on my Impreza.
Old 12-24-2012, 03:50 PM   #1592
thom52
Member#: 309257
Marine Blue
Cool
Keep us posted on ease of installation and how that works out.
Especially any problems or impact on handling.
1" is a pretty significant lift and would help with that long front overhang bottoming on driveways etc.
I guess I could play the glad game that its only plastic being torn up.
Old 12-24-2012, 04:24 PM   #1593
kinger37
Member#: 324423
2012 Impreza Sport
ISM
I haven't purchased them and I am not sure if I am going to. I have gone back and forth with the idea but decided it isn't in my best interest now as money is tight. Attached is a link that well help with your installation if you decide to go this route. Doesn't look like too difficult of an install.
http://www.subaruforester.org/vbulle...ft-kit-107084/
Old 12-26-2012, 11:17 AM   #1594
Blackmamba24kb
Member#: 330797
2012 Impreza 5dr Prm
Default Drl Led Strip Mod
So I recently did a little mod to my headlights, wished my HIDs came in at the same time but those are held up in shipping at the moment.
here is my simple mod for the "audi" style LED strips DRL (however they stay on once the engine is on and stay on for about 20 sec after i shut it off). Adds a sweet touch and very easy mod to complete. The only time consuming part is putting down the strip so that its hidden from plain view.
All lights on:
Just LED strips:
Each Headlight: Lit for approximately 20 secs after engine shut down.
Blackmamba24kb is offline   Reply With Quote
Old 12-26-2012, 12:04 PM   #1595
Blackmamba24kb
Member#: 330797
Question:
Does anyone have a solution to adding a visor light since our visors doesn't have lights?? short of using the map light of course...
i wanted to fab some sort of mod similar to the new Benz C class light where its embedded into the headliner and there is a metallic connector on the latch that locks the visor in place so if the visor is locked in and you flip it down to use the mirror, the turns light on the headliner. However if its unlatched and moved to the side window for shade the light won't turn on since the metal connector isnt engaged. (if this makes any sense)
might be more work than its worth but the wife complains about the lack of lighting when using the mirror.
Lastly, anyone know if the footwell lighting kit Subaru sells will work for our impreza? 2012 and up?? i know it says up to 2011, just not sure if it will work for the 2012 impreza 2.0
Old 12-26-2012, 07:03 PM   #1596
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Blackmamba, I'd like to see a description of how you installed those LED strip lights.
Old 12-27-2012, 01:29 AM   #1597
Blackmamba24kb
Member#: 330797
Default Led Drl Strips Install Instructions
ok i will do that
Old 12-28-2012, 10:48 AM   #1598
Smittyboifreesh
Member#: 325358
2012 Impreza
Default Coilovers for 2011 wrx fit our car?
I recently installed tein springs and they are way to soft the spring is almost compressed all the way down to the bottom. I saw a coil over installation for the 2011 wrx and everything looked the same as our 2012 Subaru. Will they fit?
Smittyboifreesh is offline   Reply With Quote
Old 12-28-2012, 10:55 AM   #1599
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Probably not
Old 12-28-2012, 11:29 AM   #1600
bankrupt
Member#: 341849
Subaru has a new footwell illumination kit for the impreza, xv crosstrek, and forester. I saw an announcement on it in the 12/10 news section of the cars101 website. The part number for the red version is H701SFJ100. I called my dealer about it yesterday and they quoted me $149 for the part, $215 installed. Obviously a lot pricier than the $40 dollar kit for the wrx and 2011 or older imprezas!
bankrupt is offline   Reply With Quote
factory SS or aftermarket for 2012??? Myth21 Transmission (AT/MT) & Driveline 8 01-07-2012 12:18 PM
Anybody in SCIC-land taken possession of 2012 Impreza 2.0i yet? somebody else Southern California Impreza Club Forum -- SCIC 1 12-30-2011 12:31 AM
Has anyone test drive a 2012 Impreza yet? pRiMe DiReCtIvE General Community 25 11-28-2011 11:03 PM
Hybrid Impreza in the works for 2012? rsholland News & Rumors 43 03-12-2010 11:58 PM
