#1 |
Member#: 164612
AKIC
Vehicle:2003 wrx purple |
I have been thinking about doing a h6 swap and doing a turbo kit and putting the sti trans behind that motor.. One problem If I'm correct the bell housing won't bolt up to the h6 motor... I know the shop in nc had a hell of a time doing this swap into a 2000 rs... Any ideas or thoughts.
#2 |
Member#: 283145
AKIC
Vehicle:1997 Subaru LEGASTi Wagon WRB |
Unless you either have a ton of money or a lot a free time and knowledge I wouldn't do it. Its a lot more work than throwing a kit on it or else a lot more people would be running them.
#3 |
Member#: 260501
AKIC
Vehicle:2011 WRX 5dr SWP Ltd |
It would be epic, that is my thought. Good luck.
#4 |
Member#: 283145
AKIC
If you want to talk to someone who did it call PDX. They built one for Perrin awhile ago.
#5 |
Member#: 32993
AKIC
Vehicle:vf39 Best trap 110 Best ET 12.54 Dale tuned |
Actually just look up the build it was well documented , you'll see what your facing with that under taking
#6 |
Member#: 283145
AKIC
^^^ Yeah I have the thread somewhere. Ill look for it tomorrow.
#7 |
Member#: 32993
AKIC
I believe you'll find it in the proven power bragging thread
#8 |
Member#: 156708
AKIC
Vehicle:2009 Cessna 172SP G1000 |
Good luck. It's an extremely involved project. |
#9 |
Member#: 169556
AKIC
Vehicle:07' OPB STi BW S256 01' 2.5rs GM6 w/leather! |
Someone needs to adjust their shift light RPM
#10 |
Member#: 283145
AKIC
#11 |
Member#: 292996
Vehicle:02 wrx |
the bellhousing bolt pattern is the same
#12 |
Modest Mouse
Moderator Member#: 27323
AKIC
Vehicle:2000 RSTi |
In talking to installers there was not a lot of gain on effort
#13 |
Member#: 285848
AKIC
Vehicle:1995 Impreza RaceCar 2007 Legacy SE OBP hers |
You could get a used porsche for the price of that build if you did it right, an it will have a flat6 and 6 speeds to row through.
#14 |
Member#: 156708
AKIC
Yep, the only gain is the sound, and you'd might as well just get the Porsche.
#15 |
Member#: 94836
AKIC
Vehicle:2oo5 STi Aspen 2o12 PiLoT CherrY |
I believe I read once, they use the Tribeca transmission on the Auto STI's in Japan/Australia?
#16 |
Member#: 273920
AKIC
Vehicle:05 Legacy GT Regal Blue Pearl |
All the EJ, EG, and EZ transmissions bolt up. The swaps have been done and if you really want to then do your research and ignore everyone here telling you not too. Just make sure you know what your up against. Lots of wiring to do, and depending on which 6 you go with determines how much fab work needs done along with engine management.
#17 |
Member#: 160040
AKIC
Vehicle:2002 Bugi / 1993 L Symmetry Tuning |
i planned on doing this and found it hard to source parts like cams and pistons that didnt cost an arm and a leg.
#18 |
Member#: 164612
AKIC
That's what I have been looking for is upgraded parts... But I still haven't found anything as of yet
#19 | |
Member#: 82476
AKIC
Vehicle:GOD CREATED TURBO LAG TO GIVE V8'S A CHANCE |
#20 |
Member#: 257415
AKIC
Vehicle:2007 Sti |
The rods, pistons, ect were all custom made on the build I followed. Lots of $$$
#21 |
Member#: 82476
AKIC
Hahahaha, yep. Was completely custom for Jeff Perrin if i remember right
#22 |
Member#: 273920
AKIC
The parts are out there. And are found pretty easy in australian market where the h6 is modded consistently it seems due to having manual trans option over there. In 5 minutes I've found super tech pistons, couple rod options and some can choices. Cosmetic head gaskets and forms of tuning people have been successful with. if your looking for simple quick and easy this is not that swap lol. But like I said if its what your goal is then get on it
#23 |
Member#: 164612
AKIC
I just think it would be sick in a wrx I seen one in a 00 rs and it was sick fast and it was na with a Cobb pro tune done. I wasn't sure about a few things lie wiring and motor supports and wat needs to be done to get the motor bolted up. I would prob. Pay some one to do the wiring one I hate wiring and I hate following wiring diagrams lol I know it can be done and if done its a real nice set up with lots of potential like autocross.... The rs I seen with this set up us quick on the track.... I was kinda wondering what everyone thought about it that's all a lot of good thoughts and I'm still trying to decide if I want that build or take my 2.0 out and build the hell out of it and have fun...
#24 |
Member#: 273920
AKIC
If I was you I would choose the EZ30D or R if you are wanting the works (AVCS/AVLS). That and they require little work to actually into the engine bay where as the EG33 requires some core support and radiator placement work. It's longer due to timing belt and the addition of two cylinders. EZ's are chain drivin so they fit almost like a 2.5. Not much longer
. I would love to EZ30R swap my wife's '10 OBS but her car is still under the warranty. And I have no time to or money to start acquiring the parts ![]() |
#25 |
Member#: 160040
AKIC
k well, my last ej257 build was around $10k and 15 months and that was with alot of favors from folks like Seth at P3 (thanks amillion by the way those who helped) dont get me wrong im sure alot of us would be stoked to see a build like this but who has $20k and two years of time to do this that's not someone like Jeff Perrin.
