Old 12-23-2012, 12:21 PM   #26
Diodon
Member#: 341423
Originally Posted by Dale2011WRX View Post
I have the factory short-shifter, Kartboy front and rear bushings, Cusco transmission mount, and Whiteline transmission member bushings. Definitely more NVH, but it shifts like sex.
Yeah, I went to see, thank you message,Merry Christmas !
Diodon is offline   Reply With Quote
Old 12-23-2012, 12:32 PM   #27
Back Road Runner
Member#: 60082
2004 Forester STI
Rev match yo!
It's helpful to learn to match revs for easier engagement.
Also you have the option to use a heavy shift knob (stainless steel) to add some weight to throws. This provides a smoother feel and seemingly lighter effort.
Like others said, bushings help a lot. They don't make it less notchy, but you do gain a lot of precision and actually feel exactly what's happening.
Back Road Runner is offline   Reply With Quote
Old 12-23-2012, 01:14 PM   #28
coalslaw
Member#: 324808
2006 IWL Stg2
no way it is near economy my dear...
at the least...hmm..leme think......rear seats dont fold down....its not light as civic...its over 200hp...hmm....only common thing they share is four doors.
coalslaw is offline   Reply With Quote
Old 12-23-2012, 01:54 PM   #29
ResidentR
Member#: 281656
2011 DGM WRX
5dr limited
If you think the wrx is a performance car and the civic si is not, then you have never driven the si and/or are smoking subaru crack.
Rev matching helps immensely and is pretty much a requirement to shift quickly without overly stressing the transmission. If I'm even a little bit off on a fast shift the synchros pretty much scream their unhappiness until it goes into gear.
ResidentR is offline   Reply With Quote
Old 12-23-2012, 03:32 PM   #30
ByeBye4g63t
Member#: 290896
2004 STi, FOR SALE
Originally Posted by easterbran View Post
On my 05 Sti with a Kartboy SS, second gear is pretty smooth, but 1st is ROUGH unless I am at a stop AND stomping on the clutch like I want it to go through the floor. It's even worse on cold mornings.
Blip the throttle slightly or when you're going to put it in gear and it doesn't go in, go back to neutral, take your foot off the clutch, and try again. I don't have this problem with my car unless the engine is still cold. However, my first car with a 5 speed had me do this everytime I went to first LOL.
ByeBye4g63t is offline   Reply With Quote
Old 12-23-2012, 03:37 PM   #31
easterbran
Member#: 307359
'05 STi Stage II
I'll give it a shot! Thanks for the tips.
easterbran is offline   Reply With Quote
Old 12-23-2012, 06:56 PM   #32
runboyrun
Member#: 287901
2003 WRX Wagon
Notch it into 2nd before you put it into 1st. Usually works for me.
runboyrun is offline   Reply With Quote
Old 12-24-2012, 12:21 AM   #33
keonigt
Member#: 304739
Chapter/Region: HIIC
2013 WRX premium
What is your guy's technique on shifting from 1st to 2nd?
keonigt is offline   Reply With Quote
Old 12-24-2012, 01:39 AM   #34
Ftinney84
Member#: 326998
2009 WRX sedan
WRB TP-Stg2
Im still fairly new at stick. But 1-2, best thing i've learned when driving the car normally is to just let out the clutch slowly. Definitely much slower than i would from 2-3 and so on.
Rev is always the hardest frigging gear to go in. And for some reason, everytime i need to reverse quickly, it always gets stuck
Ftinney84 is offline   Reply With Quote
Old 12-24-2012, 02:36 AM   #35
Coreycarlile911
Member#: 282614
2006 Wrx sti
Black pearl
Is this just an issue with new wrxs. I have 06 sti and if the clutch is all the way down first has never been a issue going under 10 mph same with reverse it has never been a issue. I will admit to a few grinded gears going into fifth when slowly shifting but with a little force it engaged no problem. I have stock shifter with just the front shifter bushings and group n tranny and motor mounts.
Coreycarlile911 is offline   Reply With Quote
Old 12-24-2012, 02:57 AM   #36
RM_2
Member#: 163058
'16 BRZ Limited WRB
'06 Saab 9-2X 2.5i NGM
If I'm in first and I'm past 25 mph, I shift into third. If I'm trying to maximize the acceleration provided by my car in 2nd gear, I go into second pretty quickly usually around 2800 RPM.
I do the same thing for 2nd to 4th. If I'm past 40 mph in 2nd gear, I go straight to 4th.
The synchros do take some time to warm up. I can't downshift into 1st unless I'm completely stopped when the car is cold, and the transmission in general is kind of uncooperative when the car's been sitting outside in 20 degree weather overnight. Pretty sure this is normal.
RM_2 is offline   Reply With Quote
Old 12-24-2012, 03:15 AM   #37
Coreycarlile911
Member#: 282614
2006 Wrx sti
Black pearl
Lol I like romping it to redline in first and shifting to fourth to get to cruising 35.
Old 12-24-2012, 07:02 AM   #38
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
Push clutch, move stick from "1" to "2", release clutch.
Sometimes I skip the clutch part.
sniper1rfa is offline   Reply With Quote
Old 12-24-2012, 01:12 PM   #39
happs subi
Member#: 200288
2002 Impreza WRX
World Rally Blue
Smurf's blood really helps out the whole shifting thing. That and hitting the gas before you pop it in 1st while you are still moving.
Oh, and the factory ss works. It's not preventing you from shifting right.
happs subi is offline   Reply With Quote
Old 12-24-2012, 02:42 PM   #40
aggarcia
Member#: 330146
2013 STI Limited
Cold transmission fluid ( especially conventional fluid ) does not shift very well. Synthetics are less temperature sensitive, but shifting easier/slower when cold does wonders for transmission internals.
AG
aggarcia is offline   Reply With Quote
Old 12-24-2012, 02:51 PM   #41
metoto2sti
Member#: 340990
2012 subaru Sti
Dark Gray Metallic
I have 2012 sti hatchback I never have a problem shifting gears.
metoto2sti is offline   Reply With Quote
Old 12-24-2012, 04:55 PM   #42
Dale2011WRX
Member#: 304299
2011 WRX, white
2014 Crosstrek, tangerine
Merry Christmas to you too. Good luck with your English in the new year.
Dale2011WRX is offline   Reply With Quote
Old 12-24-2012, 05:25 PM   #43
Navendra94
Member#: 327495
2012 Impreza WRX 5DR
Plasma Blue
STi transmission is waaaay smoother than the WRX :P
Navendra94 is offline   Reply With Quote
Old 12-24-2012, 05:28 PM   #44
MaddMax
Member#: 9264
2016 BMW M235i 6MT
Double clutching and a well matched rev makes getting into 1st from a roll relatively easy.
Subaru's aren't alone with 1st gear "lock out" either. My 96 Maxima 5MT was like this as was my 90 CRX Si. Every G35 and Nissan Z 6MT I've driven is the same way as well.
My Maxima and CRX were pretty notchy as well, much like my WRX. My CRX was surprising since it was a cable shifter and not a direct linkage. The 6MT on the G/Z is really notchy, almost resistant going into some gears.
If you want a buttery smooth shifter, you'll need to go looking for FWD cars with cable shifters. Most every FWD Honda and VW has super smooth shifting. It's also disconnected as hell too.
Old 12-24-2012, 05:43 PM   #45
jim_newton
Member#: 338099
2013 WRX 4dr
rattle trap
Originally Posted by runboyrun View Post
Notch it into 2nd before you put it into 1st. aLWAYS works for me.
^ this.. seriously
I've never seen any professional driver skip gears through acceleration, not sure why you'd want to do that. On decel some do it, but I still prefer to catch each gear
jim_newton is offline   Reply With Quote
Old 12-24-2012, 06:21 PM   #46
Coreycarlile911
Member#: 282614
2006 Wrx sti
Black pearl
Originally Posted by jim_newton View Post
^ this.. seriously
Well were not professionally driving. If we were we wouldn't be skipping gears but since for most of us it's our dd I don't see anything wrong with going from 1to3, 2to4, 3to5 or what have you. I personally usually go threw every gear but of I go with in second and am going 60 and coast your not gonna go to 3rd makes more sense to skip to 4 or 5.
Old 12-24-2012, 06:22 PM   #47
noonagon
Member#: 159745
2007 drunkman tuned
mega meth
They are a bit finicky in the first two gears. First is easy to get into from a start but not downshifting (obvious reasons) and second is hard to easily get into from 1st when you are hammering on it. Just a character of the car, the transmissions are not soft like an everyday car, they are race bred and meat to be rougher for the more skilled driver
noonagon is offline   Reply With Quote
Old 12-25-2012, 01:23 AM   #48
coalslaw
Member#: 324808
2006 IWL Stg2
civic si is weak sauce for performance car. id consider it premium econobox
Old 12-25-2012, 01:27 AM   #49
easterbran
Member#: 307359
'05 STi Stage II
It would be a fantastic car if it weren't so darn underpowered (especially torque)
Old 12-25-2012, 01:55 AM   #50
happs subi
Member#: 200288
2002 Impreza WRX
World Rally Blue
It's an econobox, fitted with the softest bushings known to man. And just because the rear seats don't fold down does not make it a performance car.
The newer civics are actually quite nimble, and have plenty of power to wrap yourself around a tree. It's not a turbo awd car, but for a NA fwd 4 banger its not bad.
