Old 12-24-2012, 10:42 AM   #1
TRMN8R
Member#: 321104
2005 WRX STi
Default Newb headlight question
Merry Christmas Eve everyone! Does anyone know what color temperature the 05 stock HIDs are? I'm putting aftermarket lights in, but I want the same white light, not the blue tinted stuff. I was thinking stay 6k or under, but I don't really know.
TRMN8R is offline   Reply With Quote
Old 12-24-2012, 10:45 AM   #2
jthatch12
Member#: 321715
03 Big 16G WRX
4500 to 5000k
Old 12-24-2012, 10:56 AM   #3
cmiovino
Member#: 134005
2004 WRX Premium
Make sure you only stick to legit aftermarket bulbs like Osrams (Nightbreaker +50, +90), Narva +50, or any of the other ones listed on the Daniel Stern lighting page. I highly recommend the Nightbreakers.. nice and white, as much as you can without going HID or having blue tint all over them.
... given that's what you mean by 'aftermarket lights'.
Old 12-24-2012, 10:56 AM   #4
Fredward
Member#: 322518
2008 2.5i Hatchback
1995 Mercedes-Benz S600
Do you have projectors retrofitted into your headlights? (I thought the 05 STi had halogen headlights? Maybe I'm wrong.)
OEM is usually ~4300k for almost every car manufacturer because that provides the most light output.
Don't drop in HID bulbs into halogen reflectors/projectors. It's provides horrible lighting, the light scatters, and it's dangerous for you and everyone else on the road.
Fredward is offline   Reply With Quote
Old 12-24-2012, 11:37 AM   #5
Mr Wrex
Member#: 332887
2012 WRX stage 2+
DGM (sedan)
Osrams are better than HIDs IMHO.
HID on left, Osram nightbreaker +90s on right:
Old 12-24-2012, 12:22 PM   #6
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
04/05 STI's have hid headlights bur utilize a reflector housing instead of projectors.
Old 12-24-2012, 01:10 PM   #7
mrkyle3
Member#: 272675
2004 Miata
H9 to H11 conversion. That's the way to go.
Old 12-24-2012, 03:08 PM   #8
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Not on an '05 it isn't, especially one with HID's. Only the '08-up has H11 low beams.
TRMN8R, why would you put aftermarket lights in your STi when it already has the factory HID's? Unless you do a projector retrofit nothing on the aftermarket is likely to give you better lighting.
If you're thinking of changing the HID bulbs only, don't. There is nothing to be gained, and plenty to be lost, by replacing the OEM 4300K D2R bulbs with anything else.
Mulder is offline   Reply With Quote
Old 12-24-2012, 03:24 PM   #9
TRMN8R
Member#: 321104
2005 WRX STi
Thank you. I'm only doing it because the car got wrecked and both sides are toast. The oem replacement assemblies, even used, are too expensive. I'm not really a fan of the halo projector conversions, but you can get the set for $250. If there are better things out there, I'm all ears.
Old 12-24-2012, 05:47 PM   #10
mrkyle3
Member#: 272675
2004 Miata
My fault, can't see his car on mobile app.
Old 01-08-2013, 11:22 PM   #11
Spec-C 2010
Member#: 337849
Can you make halogen protectors work with HIDs or do you just have to buy a HID projector? If so wheres a good place to get them? I got a 2010 sti that didn't come with HIDs.. Dang special edition anyway.
Spec-C 2010 is offline   Reply With Quote
Old 01-08-2013, 11:26 PM   #12
sc00by4life
Member#: 97135
There are a couple of different housings HID's use.
HID specific projectors (NOT halogen projectors), or HID specific reflector based housings. Its a little more complicated than buying a set of projectors.
Instead of destroying your sti SE, why not buy better halogen lights that were suggested above. Osram Nightbreakers.
Old 01-09-2013, 01:00 AM   #13
Spec-C 2010
Member#: 337849
Ya I tried a hid conversion kit and went back to the halogens. Thx
