Old 12-13-2012, 11:14 AM   #76
creative wrx
Member#: 141754
04 stock wrx ;)
z31 project, passat dd
Originally Posted by Junior2JZ View Post
Thanks dude!!! Honestly I when I saw the color in person for the first time, I knew I needed it and after owning a black 2010 I knew I wouldn't do black again.
This guy was hard to keep clean
Jr
Hard to keep clean? Thats what demetri is for!!!! LOL
creative wrx is offline   Reply With Quote
Old 12-13-2012, 11:16 AM   #77
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
lol I'm pretty sure you cleaned it 20 times for every 1 time I did lol
Old 12-13-2012, 03:03 PM   #78
kpadill2
Member#: 266208
FTW Orange stuff is for NA cars, compressions as high as 15:1
FTW Purple is a heavily oxygenated pure racing bred E85. Has an octane rating of 120+ as well. Its pretty much good for anything making big HP, but cant run methanol based fuel due to class rules/restrictions.
FTW Clear is straight up hardcore racing fuel. If you need this stuff you are making some serious power. The purple runs in 1200hp 4cyls, so this is naturally the next step if you have managed to build a 1200+hp 4 banger lol.
The Purple in my findings needed another 20-25% fuel over my e85 mapping. With e98 I usually need around 15%. Power gains to be had? From switching to FTW over normal e98 should be around 5-6% across the board. On a car like mine were I have exhausted all power output on the setup, it is well worth seeing the 40-50whp gains. That translates to another 2-3mph at the strip to me.
I would say that 95% of the people will be fine with the purple. I would put clear in those 1500-1600hp 2jz/vr motors or some crazy high compression forced induction v8. You will need A L O T of fuel to run that stuff, I would guess mechanical fuel pump and a base of 100psi since the IDs will move some serious fuel flow at high pressure.
Update on my stuff, I made 660 by adding a reg and bumping up the base to 70psi. Still out of fuel but the graph got smoother to 5500rpm with the extra fuel.
Tony @ T1 hooked me up big time as he usually does and I am receiving my id2000s and complete rail/fuel setup from them today. I was going to toss in some smaller injectors and go play, but I figured with the up coming winter mods I will need the fuel system anyway
Thank you for the great information! This stuff will be available for purchase soon? I'd be interested in going from e98 to try the purple but won't need it till January or so. It's expensive but it's basically free horsepower (if that makes sense haha).
And very nice GTR! If I hadn't built a subaru I could afford a GTR lol!
kpadill2 is offline   Reply With Quote
Old 12-15-2012, 11:37 AM   #79
Junior2JZ
Member#: 64908
9.1/157mph 2015 STI
Stuff is readily available for purchase.
Update
Went to a track rental yesterday with a few other GTRs . Made about 20-22 passes with the majority of them in the 10.12-10.20 range. I made my best pass ever on the oem 20" wheels. [email protected] with straight e85, 1.71 60ft 95% of the passes were done on pump e85 and the 20s to burn off the e85.
I then switched to the FTW and 18s all around, and made another 4 [email protected] passes cutting a 1.57 60ft, 4.28 330 and 6.49 1/8th ... Still only a [email protected] lol
I messed up and mixed my FTW with e85, making the FTW basically useless 2 gallons of e85 3 gallons of FTW. The fuel map was a disaster because I had tuned it for straight FTW.
Going to try and get out one more time this year. This time I will figure out draining it, then swap in. For now I will enjoy having the fastest/quickest stock turbo gtr on the oem wheels lol
Oh and on another note ... [email protected] tuning is a ****ing racer BRO!! He text me at 11pm the day before that he was making the 8hr drive to race his TA GC8. He clicked off a few [email protected]+ with his stock motor car on freaking Hoosier road race tires!! Something broke in the diff so his day ended early, but he stuck around to help and watch me run a bunch of 10.1s lol. Then made the same 8hr+ ride home. Very cool dude, and had a blast hanging out with you.
Jr
Old 12-15-2012, 12:54 PM   #80
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
Congrats jr
Putting it down with the 20's
wrxsubiemod is offline   Reply With Quote
Old 12-15-2012, 01:04 PM   #81
Slimsti
Member#: 155696
2007 BLK STI Dom3XTR
415/405 Precision Tuning
That's sick man. Lol low 10's on 20's is baller status
Slimsti is offline   Reply With Quote
Old 12-15-2012, 03:12 PM   #82
02rex62
Member#: 215004
02 Rex
I wanna go fast!!!!!
Bada**!
02rex62 is offline   Reply With Quote
Old 12-15-2012, 06:10 PM   #83
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
Jr on the aem you usually keep your boost breakpoints linear or you try and guess where peak boost is going to be and give yourself more adjustment in that area??
Old 12-15-2012, 08:31 PM   #84
Junior2JZ
Member#: 64908
9.1/157mph 2015 STI
Thanks guys
T1R Goodies
[email protected] 168mph MONSTER and my BE with his wheels
Bored of the 10.1 passes
Stretched
I keep it linear based off the power-band and general spool characteristics if I am just using the main Boost WGD tables. I like using the rpm/tps tables or VSS
Old 12-15-2012, 09:10 PM   #85
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
Oh cool was jw. When I setup tunes I usually give myself some fine adjustment in the vacuum idle area and from there I keep it linear breakpoint wise.
Only bad thing I noticed at least it seems bad is that you only get 16 breakpoints in aem1. So if your tuning stuff like you do where boost is high your making big steps like 0/4/8/12/16 psi.
Would be cool to have like 20 or 22 break points.
Old 12-15-2012, 09:11 PM   #86
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
And sounds like tens is as good as it gets on power/wheel combo.
Does it spin or hook?
Old 12-15-2012, 09:44 PM   #87
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
And I know they have that lc feature don't they.. Can you alter boost leaving the line? Don't know much about them ..
Old 12-15-2012, 10:55 PM   #88
Irv Weissmanhowerton
Member#: 278519
30r E85 sti 450+whp
kb'izzle
If someone was using no launch control (talking subaru here) just blurping the throttle, can it only make like 1psi boost, or can you actually get boost using no launch control
when I took off it was building boost, then just dumped the clutch at like 5500, spun all the tires and all, was wondering if this was just like we'd do with a non turbo car burning out, or was the 1 pound enough for some great 1.60's spinning all the tires
Old 12-15-2012, 11:12 PM   #89
lancelucas
Member#: 124282
04 WRX Wagon PSM
13 STI Sedan SWP
F'ers!!! Sounds like a blast. No track time for us PNW's until April at least
lancelucas is offline   Reply With Quote
Old 12-16-2012, 02:36 AM   #90
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
You might only get 1-2 psi free revving but as soon as you start adding some load and getting off the clutch boost goes up fast.
When you get the timing right this actually works very well just tricky.
Old 12-17-2012, 12:05 AM   #91
Junior2JZ
Member#: 64908
9.1/157mph 2015 STI
Oh in that aspect yea, I use less vacuum area and rescale
It went 10.1 on the 20s and 10.1 on the 18s... Think I just need to tweak the LC a little more on the sticky tires. I can get it to hook 1.5s on the 20s when its a little warmer out.
Yea you can alter that stuff. Right now the DBA 12+ cars don't have any boost off the line as of yet.
Move to the east coast
Old 12-17-2012, 12:15 PM   #92
Innovative Tuning
Member#: 67958
MY96 Time Attack
and 06 STI daily
Good to meet you finally after all these years. Traction degraded later in the day when you put the better tires on so you didn't get to improve your 60'. Between a little better 60' and straight purple drink power I'm expecting you to be the first GTR in the 9s on stock turbos.
Frustrating as it was to you, it was cool to watch you stack 10.1-10.2 passes all day in a stock turbo street car.
I went back and looked at logs. My Subaru was spinning straight into the limiter through most of the eighth so I wanted to see if the car was out of shape and I just lost it when I crashed, but that's not the case. Something definitely broke. Lateral Gs bumped a little (.1-.2) during the 3-4 shift, but settled to ~0 and then at the top of 4th gear the car suddenly took a 0.7 G turn at the wall. It felt like a rear axle failure, but it seems to be a diff this time. **** happens. I'll be back with drag slicks, DCCD locked, and a better rear diff after we fix the car.
Innovative Tuning is offline   Reply With Quote
Old 12-17-2012, 12:19 PM   #93
CatfaceType-R
Member#: 81102
Working with gforces at the strip, very good, my man. Kudos
Carmi
Old 12-17-2012, 12:21 PM   #94
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
10 10 10, 20s and them fifties chick.
Couldn't help myself
Old 12-17-2012, 12:32 PM   #95
Innovative Tuning
Member#: 67958
MY96 Time Attack
and 06 STI daily
And thanks for running down to make sure I was ok!
Old 12-19-2012, 04:07 AM   #96
spoolinsti05
Member#: 108051
2005 TickingTimeBomb
Jr tuned TT Sleeved
Was it in fact a broken axle? Wish I could have made the event. Any videos?
spoolinsti05 is offline   Reply With Quote
Old 12-21-2012, 02:28 AM   #97
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
More power , and maybe with some tweaking better 60 ft and your all in!!
Pretty cool to know it super consistent though. Wouldn't be Lying to tell someone who asked-yeah it runs 10.1's lol.
Old 12-21-2012, 12:22 PM   #98
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
Why's that one runner on far right look like it has oil build up? backfire?
[quote=Junior2JZ;38713281]Thanks guys
T1R Goodies
Old 12-24-2012, 03:25 PM   #99
Cosie Convert
Member#: 13627
96 Type RA
[email protected] Street Legal!
You guys need to get a Syvecs ECU on there, seriously!
Cosie Convert is offline   Reply With Quote
Old 12-26-2012, 03:14 AM   #100
jkopinga
Member#: 220799
2006 Impreza WRX
WRC Blue
Yep Andy, couldn't agree more. The Syvecs GT-R package is bloody awesome. Will be doing one in the coming time on a Alpha 12 package.
Jasper.
jkopinga is offline   Reply With Quote
