Old 12-23-2012, 10:31 PM   #8151
s1eepR
Member#: 335330
2008 Impreza 5DR
Originally Posted by Pickler View Post
nice ride. how did you do that interior red trim?
The Red Pinstripe from Autozone (most people use it on the grill) I went a little crazy. It's really easy to apply. I just did it along the upper edge of the trim because the bottom edge didn't flow as well.
Originally Posted by Tentonted View Post
Can't tell from picture, but is it blue with gold (factory?) wheels? If so, I guess you painted the factory wheels.
I like it, bout as close as we will get to the traditional rally blue/gold wheels look.
Originally Posted by fancyfootwork15 View Post
His car is black. My car is Newport blue and I have gold summers.
Dark Gray Metallic, Sunburst Gold Metallic Wheel painted 2010 WRX wheels. Now I'm trying to find a set of 2011+ WRX wheels, when I do, I'll probably put these up, with a fresh coat of course.
Originally Posted by KartRacer3 View Post
Nice headlights! May I ask what projectors you went with? I know trs/lightwerkz has a morimoto mini d2s setup that requires little to now modifying (other than adapter plates). Either way looks great.
Yep, the Mori minis with Philips bulbs. The Aftermarket bubls have igniting issues. Thanks!
Thanks for the kind words guys!
s1eepR is offline   Reply With Quote
Old 12-23-2012, 10:45 PM   #8152
BSP671
Member#: 288190
2009 Impreza 2.5i
Spark Silver
Originally Posted by Cmac13
I get a clunking noise from the rear wheels too, but I replaced my suspension and it still does it, if I grab the wheel when it's jacked up and move it, it makes the noise too. I don't know what it is
Could be a number of things. I'd check the bearings and axle first.
BSP671 is offline   Reply With Quote
Old 12-24-2012, 12:02 AM   #8153
gbkallday2.5i
Member#: 329199
2010 Impreza 2.5
Gbkallday2.5i- it depends. If you have te factory mounting points then it's super easy to "bolt on". Do you plan on using it for something? I.e. bikes, Christmas tree, dead bodies, etc? It can be useful but it also can affect your mpg's if your carrying stuff all the time or on long trips. Also keep in mind, the rack could possibly scratch your roof at the mounting points if you don't put down something underneath it. Other than what's listed above I love my rack
probably going to use it most of the one for the dead bodies.... tired of flopping them in the back seat and stinking up the interior and getting blood stains on the seat! what a pain!
are factory mounting points the little flap like things on the top on like the roof trim?
what brand do you suggest? do you know of any place that I can get one cheap?
thanks a lot!
gbkallday2.5i is offline   Reply With Quote
Old 12-24-2012, 12:20 AM   #8154
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
thanks a lot!
a little too much info lol. I would recommend Yakima just because they look really nice and they have a lot of accessories. Although I believe thules square bars are a little bit stronger (less prone to flexing at heavier weight) you can get oem cross bars for cheap like $120+ used but I have them and they flex with my 40lb mountain bike
Old 12-24-2012, 01:27 AM   #8155
premier00000
Member#: 251060
2008 Impreza Outback
thanks a lot!
Not sure how much the OEM cost usually, but I got my bars for $40 and the side posts are painted DGM which matches the lower part of my car.
Old 12-24-2012, 03:46 AM   #8156
krueger519
Member#: 336523
2010 Impreza 2.5i
Maroon
What's a good sway and strut bar? and are there any recommendations for short shifter kits or should I just piece them together with different brands?
krueger519 is offline   Reply With Quote
Old 12-24-2012, 05:18 AM   #8157
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
Also forgot to tell you, whiteline is really good for sways. Strut bars it's really upto you. You can get a cheap gt-spec one for like $150, however the Cisco ones look really nice for $190ish. Ss kits-kartboy for simplicity, Cobb adjustable shifter is also nice. Depends on what you want really.
Old 12-24-2012, 05:37 AM   #8158
krueger519
Member#: 336523
2010 Impreza 2.5i
Maroon
Thanks, the wheels should be here in late March time frame, then its time for suspension then the transmission.
Old 12-24-2012, 06:19 PM   #8159
vto
Member#: 261641
2009 Impreza 2.5i
Got this exhaust of a 2012 STI Sedan, fits good and sounds way better than stock, had to do the usual trimming on the rear bumper and what not but for a $50 cat back I am very pleased.
vto is offline   Reply With Quote
Old 12-24-2012, 06:21 PM   #8160
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
^ got any more shots? Specifically directly from the back?
Old 12-24-2012, 08:04 PM   #8161
Steve2.5i
Member#: 293006
2015 Subaru WRX
WR Blue
Thiss
Old 12-24-2012, 08:16 PM   #8162
Tentonted
Member#: 303864
2008 Impreza 2.5i 5d
Nice!
Tentonted is offline   Reply With Quote
Old 12-24-2012, 11:58 PM   #8163
Icarus202
Member#: 340721
08 2.5i
Nice dude any drone off this setup?
Icarus202 is offline   Reply With Quote
Old 12-25-2012, 04:07 AM   #8164
theoutbackdream
Member#: 301179
2013 WRX Limited
Wow, looks like a WRX!
Old 12-25-2012, 07:36 AM   #8165
krueger519
Member#: 336523
2010 Impreza 2.5i
Maroon
Merry Christmas Subie fam.
Old 12-25-2012, 09:44 AM   #8166
Tentonted
Member#: 303864
My exhaust:
Will post videos and installed pix soon
I eliminated any muffler and run only a second resonator. Sounds good, will sound better with headers, and I may eliminate the first (factory resonator) later. Not much drone only around 60 in 5th gear if I accelerate at which I usually drop to 4th if I am passing anyhow, other than that I like it. Took my father on a trip (he is 65) and said it sounded fine (i.e. didn't bother him a bit).
-Ten
Old 12-25-2012, 12:01 PM   #8167
Sellars21
Member#: 304055
2008 2.5i Rallisport
UEL Headers Magnaflow CBE
Gf painted a mug for Christmas. Couldn't find wrb so she went with plasma blue pearl.
Old 12-25-2012, 12:17 PM   #8168
Digital Dillon
Member#: 288727
2008 WRX premium
Obsidian Black Pearl
Looks closer to WRB to me
PBP is definitely purple
Old 12-25-2012, 12:26 PM   #8169
Sellars21
Member#: 304055
PBP is definitely purple :lol;
It changes color in the sun just like pbp. It's just a bad direct sunlight pic on my part. Here's a better one next to an old wrb Mirra shirt.
Old 12-25-2012, 03:47 PM   #8170
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
LOL I have that same shirt..^ Two of them actually- the "team" one and the one with less stuff on it too.
BWX is offline   Reply With Quote
Old 12-25-2012, 06:40 PM   #8171
Digital Dillon
Member#: 288727
2008 WRX premium
Woooooot! I got OEM crossbars
Old 12-26-2012, 03:01 PM   #8172
theoutbackdream
Member#: 301179
2013 WRX Limited
I believe my CV Axels are going out at 46k....
taking left turns i hear a hard clicking sound and my only guess is the CV axel. Anyone know how much it will cost to replace?
Old 12-26-2012, 04:28 PM   #8173
alphaproject
Member#: 147588
Make sure your wheel isn't just coming loose...happened to me before, lol.
alphaproject is offline   Reply With Quote
Old 12-26-2012, 06:10 PM   #8174
Digital Dillon
Member#: 288727
2008 WRX premium
Check if anything is rubbing on the fender liner!
Old 12-26-2012, 07:47 PM   #8175
premier00000
Member#: 251060
Mine went at about 38-40k and at a local repair shop it cost around $200 including parts and labor and a 'performance' alignment to my specs.
It would have been over $400 without an alignment at the dealer.
08 2.5i and 08 Sti Suspension WRXbrother Brakes, Steering & Suspension 7 03-24-2012 03:14 PM
Will an 08 WRX intake fit an 08 2.5i? Racing101 Normally Aspirated Powertrain 26 01-19-2012 12:57 PM
08 STI Wing on 08 2.5i impreza juny102004 Interior & Exterior Modification 13 01-18-2012 10:46 AM
Will 08+ WRX gauges swap into 08+ 2.5i? Simeon Priest Interior & Exterior Modification 10 03-26-2010 03:17 PM
08 2.5i mod question deunique1 Impreza Forum 1 10-03-2007 03:35 PM
