Old 12-25-2012, 02:19 AM   #51
SubieSnacks02
Member#: 323545
Old Racekorrrrr!
Multi
I have a 02 Wrx and it doesn't like going in 1st, reverse when daily driving, and sometimes 2nd when WOT. I have a kart boy short shifter also. I use to just think it was my transmission starting to go but after reading the post I know I'm not alone lol merry christmas Subaru brothers!
SubieSnacks02 is offline   Reply With Quote
Old 12-25-2012, 02:31 AM   #52
Coreycarlile911
Member#: 282614
2006 Wrx sti
Black pearl
Does anyone have a good trick to get a good smooth shift when going wot in 1st to 2nd in a sti. You have to shift so fast and it's under so much tq that getting a smooth shift is tricky. It always seems to jerk a bit.
Coreycarlile911 is offline   Reply With Quote
Old 12-25-2012, 03:59 AM   #53
easterbran
Member#: 307359
'05 STi Stage II
You kinda gotta play around with how fast you let the clutch out, especially at wot.
easterbran is offline   Reply With Quote
Old 12-25-2012, 07:20 AM   #54
Dmochowski
Member#: 306478
2012 WRX limited
305whp/360tq TSM tuned
My shifter has a great notchy gated feel I have had two wrx's I love the feel of the 5speed
Dmochowski is offline   Reply With Quote
Old 12-25-2012, 09:15 AM   #55
CrashBandit
Member#: 329543
2003 WRX Wagon
Sonic Yellow
This! I've owned 3 Nissan 240sx's (all 5MT), a Honda Acura (5MT) and the WRX 5MT is by far the best. Yes the Honda and Nissan was easier to drive but I love the gated, notch-y feel. My brother that has an 88' 300zx-T loved the throws on my wagon.
Although the 2nd gear whine does scare me somewhat, so I try to avoid de-accelerating in that gear.
CrashBandit is offline   Reply With Quote
Old 04-09-2015, 12:23 AM   #56
13rown130i
Member#: 416450
2008 Impreza 2.5i
obsidian black pearl
You can,use d.o.t3 brake fluid. It's a hydrolic fluid and is safe.
13rown130i is offline   Reply With Quote
Old 04-09-2015, 07:47 AM   #57
WallyHawk
Member#: 361049
2013 WRX Hatch Ltd
Shifter bushings made all the difference in the world
WallyHawk is offline   Reply With Quote
Old 04-09-2015, 08:02 AM   #58
hudsonvalleybugeye
Member#: 295068
2001 forester
Drive the car...a lot. At least until you can get the smooth shift that you're after.
hudsonvalleybugeye is offline   Reply With Quote
Old 04-09-2015, 08:09 AM   #59
iainb
Member#: 391762
2015 STI Launch Ed.
2016 Golf R (wife's)
Originally Posted by MaddMax View Post
Double clutching and a well matched rev makes getting into 1st from a roll relatively easy.
Double-clutching during up-shifts on a transmission with syncros? Ok Toretto...
The only possible time you'd want to double-clutch in any modern street car is when down-shifting and that's really only if you are making a large leap in RPM change. Even then it's not really any more effective than just rev-matching.
iainb is offline   Reply With Quote
Old 04-09-2015, 08:35 AM   #60
WallyHawk
Member#: 361049
2013 WRX Hatch Ltd
Old 04-09-2015, 08:42 AM   #61
SoapBox
Member#: 204578
S54 E46, N54 E82,
N55 E84, AKA REX8
Perhaps you need to read his post again. He said getting into first, nothing about upshifting. In a WRX, if the car is rolling slowly (say 5-10 mph), it can be a very difficult to get into first. It's a very common issue on the 5-speeds. Double-clutching is the solution given the weak first gear synchro.
Rev matching alone does nothing to ease the load on, or negate the need of, the synchros.
SoapBox is offline   Reply With Quote
Old 04-09-2015, 10:46 AM   #62
iainb
Member#: 391762
2015 STI Launch Ed.
He said going into first from a roll, I took that to mean from a stop. My mistake.
But I specifically said that double-clutching only really needs to be used with down-shifting.
Where did I say that rev matching negated the need for syncros?
Old 04-09-2015, 11:29 AM   #63
SoapBox
Member#: 204578
S54 E46, N54 E82,
N55 E84, AKA REX8
I never claimed you did.
Edit:
But you did say that double clutching isn't any more effective than rev-matching on downshifts. That's simply not the case if you're talking about a weak synchro (which is what he was referring to with regard to getting the car into first when rolling).
But anyway, ok, you thought that when he said "rolling" he meant "stopped" ()...so it's all good.
Old 04-09-2015, 02:23 PM   #64
ramm21
Member#: 416406
So the shifting feel has been an obsession for me, almost.
First thing I did was the Cobb SS and bushings- shifting was more direct, took a little slop out of the shifter. My hand wouldn't hit the hazard light on 2-3 shifts anymore as well.
Next I got a weighted knob- not much difference, looks cool
Switched to Andrewtech cocktail- biggest difference for me. Took a lot of slop out, still feels a little notchy. Downshifts are a breeze now. Good luck 2-1 shifting on stock shifter/fluid. With new trans fluids, just blip throttle and the shifter slides into 1st, no problem, at almost any RPM. Night and Day difference, trust me.
Lastly, I took the helper spring off the clutch assembly- loving it, don't even feel the extra pressure when shifting anymore. And now I can feel the actual engagement point, instead of feeling the spring's tension all the way through the shift.
Future mods to help with this- trans/engine mounts, maybe try to lock down the rear diff..
Hope this helps someone
ramm21 is offline   Reply With Quote
Old 04-09-2015, 04:17 PM   #65
sc00ter
Member#: 117767
2015 WRX
CWP
F*** smooth shifting. Install some polyurethane bushings and enjoy the notchy "sure" shifts in every gear.
sc00ter is offline   Reply With Quote
Old 04-09-2015, 04:34 PM   #66
vinniev
Member#: 409494
2012 WRX
blue
That made me shoot soda out my nose. thanks for the laugh I needed that today bad day at work.
Not making fun of any one, but did just take the kids to see fast 7.
vinniev is offline   Reply With Quote
Old 04-09-2015, 04:40 PM   #67
ears2305
Member#: 377407
2013 STI Hatch
Crystal Black Silica
Talk about resurrected threads!
ears2305 is offline   Reply With Quote
