Old 12-23-2012, 04:37 AM   #1
Ronen91
Member#: 324810
2013 STi
Default Bridgestone Blizzak LM-60's Defective??
So on 12/18/2012 I put on a pair of new Bridgestone Blizzak LM-60s on my '13 STi. 225/45/17 with '06 Gold BBS wheels. What a NIGHTMARE. On the way home (we just had a little haill the day before), I was driving on the highway and the car felt disconnect from the car when moving lanes at 55MPH. It felt like hydroplaning. I have nearly collided with a car because the tires just don't turn well. I took the tires in the day after I got them to make sure they were put on right, and tightened to right properly.
Even at low 35mph speeds I feel like the tires are losing traction. On 2nd gear on all roads I lose traction and have to force shift myself into third to get going.
It has been really scary with these things on the car.
My question is:
Is this NORMAL for the LM-60? Even if it is I'm requesting an exchange with Discount tire.
The DOT# is 0312 (3rd week 2012?)
How can this be? Is there something wrong with my STi?
Ronen91 is offline   Reply With Quote
Old 12-23-2012, 05:14 AM   #2
WaterfordRex
Member#: 311224
2011 Impreza WRX
Thats not normal. I am 100% confident in mine 235/45/R17 whether im on ice snow etc. Sounds like a defective tire. I would see if the place that installed them would give you another set.
The car will feel a little different because its a softer rubber and the tread flexes alot but you definitely shouldnt be having those issues.
WaterfordRex is offline   Reply With Quote
Old 12-23-2012, 05:25 AM   #3
what pressure is in them???
sounds way overinflated
Old 12-23-2012, 05:50 AM   #4
Ronen91
Member#: 324810
2013 STi
I'll go check but I think from the order sheet 35 F 36R
Old 12-23-2012, 06:25 AM   #5
Ronen91
Member#: 324810
2013 STi
35 all around.
Old 12-23-2012, 07:38 AM   #6
35 all around.
drop them to 31psi
Old 12-23-2012, 09:05 AM   #7
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
There is nothing wrong with your tires u need to adjust yourself and proper tire pressure. I'm on my second season with mine and one thing for sure is proper tire pressure makes all the difference. For highway 36 front, 35 rear except in really bad snow and ice drop them down to 33 front 32 rear.
What I meant by adjusting yourself is that u were use to a certain way of how your suby handled and now has drastically bin changed and u will have to change your driving habits. The lm-60's r a great performance winter tire as I have no complaints but I know exactly what u r experiencing hope this helps
Edit: if this issue still persist then I would look at getting an alignment. Also is your suspension stock??
Old 12-23-2012, 01:04 PM   #8
SubLGT
Member#: 207528
2005 Legacy GT
So on 12/18/2012 I put on a pair of new Bridgestone Blizzak LM-60s on my '13 STi. ...............Is there something wrong with my STi?
You only put on a pair of LM60s, instead of four LM60s???? Bad idea!
SubLGT is offline   Reply With Quote
Old 12-23-2012, 04:57 PM   #9
Ronen91
Member#: 324810
2013 STi
Haha, no. set is the word I was looking for a i guess...
Someone told me that it could just be a break-in process of the new tire. Told me to give it 100 miles. Thing is I have driven 100 miles.
Old 12-23-2012, 05:14 PM   #10
krzyss
Member#: 8365
2013 Ford Focus SE
LM-60 is not great performance winter tire. There are much better tires but probably not available in the USA this winter.
What was the weather like when you experienced such terrible handling? Dry? Wet? Temperature?
Are you sure you have LM-60 and not WS-60?
Krzys
Old 12-23-2012, 06:15 PM   #11
SubLGT
Member#: 207528
2005 Legacy GT
Give it another 200 miles and see if it improves.
Since these are directional tires, are all the tires correctly mounted and rotating in the correct direction?
Old 12-25-2012, 06:25 PM   #12
tekfoc
Member#: 21392
2014 45 AMG MB
WHITE /MB C300 4MATIC
2 winters on my lm60's no problems .
give it a couple 100 miles more .
tekfoc is offline   Reply With Quote
Old 12-25-2012, 07:01 PM   #13
Ronen91
Member#: 324810
2013 STi
I took them out yesterday and today, and I think they have adjusted! I'm so happy! They worked great on the snow we got today too!
Thanks for the advice guys..
Old 12-25-2012, 07:47 PM   #14
tekfoc
Member#: 21392
2014 45 AMG MB
Good to hear.
Enjoy.
Old 12-25-2012, 07:56 PM   #15
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
Ya tires are pretty greasy at first too
Old 12-26-2012, 01:59 PM   #16
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Think "dirt bike" when you are driving on snow tires, not "go kart"...
Everything needs to loosen up, including you... Let the car move and find grip, don't try forcing it... You'll start to get it...
Explore the limits somewhere safe... Once you start getting it down, it's soooooooooooooooooooooooo much fun...
Old 12-27-2012, 01:06 AM   #17
SubLGT
Member#: 207528
2005 Legacy GT
So true. Apparently, a lot of people don't realize that winter tires need breaking in for several hundred miles before they can achieve maximum traction.
Case in point, this customer review at tirerack of Michelin X-Ice Xi3 tires with only 100 miles on them:
"I checked Consumer Reports before I ordered these tires: Michelin X-Ice Xi3's. ............ We just had a snow, then rain, freeze overnight, with snow again. So, this is the first time today that I have actually used them on snow and ice. They are great on snow, but not so much on ice. I slid about 10 feet on one road, and when I started to go on a green light, the tires spun and went sideways. I learned very quickly to stop about 20 feet behind another car and to not go over 20 mph on the ice!..........."
Old 12-27-2012, 02:03 AM   #18
Ronen91
Member#: 324810
2013 STi
It's one of those things in the back of your head though. Because if they are defective, and you are past a certain grace period, especially if you don't drive those few hundred miles right after you get them, you may never get your money back. You never know =) I'm glad it worked out.
Old 12-27-2012, 05:36 AM   #19
defective tires????
ok....even with a few hundred miles on them, they are fully warrantyable from any reputible dealer
Old 12-27-2012, 12:27 PM   #20
Ronen91
Member#: 324810
2013 STi
defective tires????
First set of snow tires so im not sure how the warranties work on those. I had a defective set of dws continental's back during their first generation of them on my caddy. It happens. Regardless of whether
Old 12-27-2012, 12:46 PM   #21
Ronen91
Member#: 324810
2013 STi
defective tires?????!!
First set of snow tires so im not sure how the warranties work on those. I had a defective set of dws continental's back during their first generation of them on my caddy. It happens. Regardless of whether it's working or not. Better safe than sorry.
Old 12-27-2012, 02:34 PM   #22
Ronen91
Member#: 324810
2013 STi
Does anyone know what the proper PSI would be for these tires? I think it's 35 all around currently. It's about 20-30*F where I live right now.
Old 12-27-2012, 04:38 PM   #23
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
As I've already mentioned for highway 36f and 35r except in heavy snow drop them down to 33f and 32 rear.
Old 12-27-2012, 09:20 PM   #24
that may be too much pressure for these tires
that is why i suggested WAY UP TOP, here to try dropping the pressure
glad to see that nobody is paying attention
jesus
Old 12-27-2012, 10:47 PM   #25
pon55
Member#: 338546
2003 Impreza RS
Someone said snow. Isn't it wonderful.
pon55 is offline   Reply With Quote
