Old 07-11-2012, 11:45 AM   #26
amroof
Member#: 211224
2005 Saabaru
Who knows
Originally Posted by lukeskywrx View Post
The whole point of this is that the stock 32bit ECU is still in charge and driving the JDM motor. Forester ECU-JDM motor. So any WRX or STI from 2002-2007 can do a JDM motor swap, the 16bit cars run the JDM ECU and the 32bit cars keep their standard ECU without having to do a harness swap. As far as the ECU knows it is still a forester and the immobilizer system is still intact.
We are getting full AVCS advance (40 BTDC) using the JDM camgears with the 32bit ecu since the AVCS limit on USDM cars is a physical limit not an ECU limit.
Canbus started in 08 so this does cover the entire GDB series.
luke couldnt of said it better but you missed the biggest point.
BECASUSE RACE CAR!!!
and because there is still doubt
this is how it works
jdm engine being run by forester ecu - which is done using usdm sti cams and cam sensors ( machine work done to make sensors work) usdm sti intake harness, im currently running the usdm avcs solenoids at the moment going to put in the jdms and see if there is a difference between the 2. not expecting a lot from that swap though.
but other than those few parts of the usdm sti engine it is all jdm!
amroof is offline   Reply With Quote
Old 10-16-2012, 09:30 AM   #27
arco
Member#: 57156
2007 V.8 207 STi
Mercedes Polar White
Nice job and sweet! I have been working on the same thing but I haven't gotten to the point of starting it yet. I've been working on the swap since dec 2011 but planning a wedding, working 50 hours, being married, and working on my masters has slowed me down incredibly.
I'm excited to see that I'm on the right path and that nothing else seems to need to be done.
BTW for you or anyone wondering what I'm doing, I'm running the Version 8 JDM EJ207 in my 2007 Sti which is 32 bit of course. I had the engine running before in my 2004 wrx but that wasn't a crazy achievement being 16 bit already. I loved how the response and everything that comes with having a 207 and I wanted to keep it.
arco is offline   Reply With Quote
Old 10-16-2012, 12:01 PM   #28
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
What MAF? -Speed Density!
Amroof just passed CO emissions with this setup, visual, sniffer and OBD
Wooo daily driver
lukeskywrx is offline   Reply With Quote
Old 10-16-2012, 04:36 PM   #29
arco
Member#: 57156
2007 V.8 207 STi
super sweet. wish me luck at CA in the next few weeks
Old 10-16-2012, 06:04 PM   #30
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
you have to add a fake fitting for the evap system, and depending on location your lack TGVs may require a manifold swap.
Old 10-18-2012, 06:38 PM   #31
mystibugeye
Member#: 279996
2002 wrx
WRB-
WOW! awesome swap man, congrats!!
mystibugeye is offline   Reply With Quote
Old 10-18-2012, 10:36 PM   #32
amroof
Member#: 211224
2005 Saabaru
Who knows
Good luck man! I got lucky and all they checked for was cats! they never popped my hood at all. And now i can register my car as a flex fuel vehicle because the gas analyzer picked up that i was running on e85. So that means no more emissions for me .
And arco if you have or can get a hold of a factory sti intake setup do it they wont be able to tell its a 2.0.
Now its time to go back to cat less dp and get my power back!
And thanks guys for the comments this swap at this point has over 6000+ miles on it now as its my dd. Which consists of a 70 mile commute to work daily. I already have another swap in mind here. but not sure when it will go into action. I too am looking to get married soon
Old 12-08-2012, 01:37 PM   #33
Seattle_WrxWagon
Member#: 334326
Awesome forester! I am trying to do the same swap on my 04 wrx with a jdm v9 sti motor but having an issue... I have installed the motor and used my throttle body ac power steering and coil packs from the wrx. I also installed the avcs wiring kit, and a version 8 ecu. When I fired her up she idles extremely hard and inconsistently and the check engine light flickers on and off constantly without stopping... Any idea what is causing this? Did I miss something?
[email protected] 206-708-0312
Giff.f
Seattle_WrxWagon is offline   Reply With Quote
Old 12-10-2012, 07:58 PM   #34
arco
Member#: 57156
2007 V.8 207 STi
^ What ECU are you running? That may be the issue. FYI You should open up your own thread or post in the EJ207 thread instead of here. You'll get more help that way
Old 12-10-2012, 08:00 PM   #35
arco
Member#: 57156
2007 V.8 207 STi
Dude that's sweet. Would the flex fuel vehicle designation work in other states as well? I want to try that to avoid smog in my car and my AE86
Old 12-24-2012, 12:58 PM   #36
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
+1 on the flexfuel...
As I said before, Amazing swap!
Old 12-25-2012, 06:51 PM   #37
JRach
Member#: 78075
98' SF5 STI
93' GF8 (rally)
Nice car!
Does the jdm V9 motor not run the little mini idler pulley (the small one that sits just next to the tensioner?)
JRach is offline   Reply With Quote
Old 04-11-2013, 12:19 AM   #38
amroof
Member#: 211224
2005 Saabaru
Who knows
Just as an update. I just finished my second 32 but v9 swap on another forester.
second one up and running
Old 04-11-2013, 11:44 AM   #39
25rsti
Member#: 166324
Hot damn you! haha
25rsti is offline   Reply With Quote
Old 04-15-2013, 10:27 PM   #40
02 Scoob-TN
Member#: 176010
2005 WRX sdn ver8'ed
Phat-Tuned RIP Bugeye
Are you guys sure the version 9 is not dual avcs, I thought it was..
02 Scoob-TN is offline   Reply With Quote
Old 04-16-2013, 12:37 AM   #41
amroof
Member#: 211224
2005 Saabaru
Who knows
Pretty positive. The v10 is the dual avcs
Old 04-16-2013, 04:10 PM   #42
25rsti
Member#: 166324
I'm on my 2nd V9, 100% it's not. The change over to the GRB body style in America and Japan was the start of the Dual AVCS.
Old 06-03-2014, 08:20 AM   #43
rexworx
Member#: 103232
How are things going on these swaps? How did cam sensor location need to be machined? Hole opened up? Mating surface machine down for a tighter clearance?
Old 06-05-2014, 02:51 PM   #44
amroof
Member#: 211224
2005 Saabaru
Who knows
My swaps are all still on the roads. 3 of this swap done by myself and 4 lending a hand. Ranging from 5000-60000miles on the swaps. I sold my forester with this swap to a buddy. It out down 295whp and 342ft lbs on corn at 20psi. In Denver.
You have to open up the he in the drivers side and cut the sensor down on the passenger side. If you need more info pm me or kplutien.
Old 02-16-2015, 02:14 PM   #45
maximus88
Member#: 99103
2003 WRX STI ej207
Yellow
IS there a write up for doing the jdm swap to 32 bit ecu Subarus?
maximus88 is offline   Reply With Quote
Old 03-29-2015, 09:25 AM   #46
04wrbscooby
Member#: 369079
2004 Wrx sti
Wrb
Yeah there is do a search. Its really pretty easy. Removing material from the heads for the cam sensors to line up and swapping usdm intake cams is the worst part.
OP is that how you did it or did you find another way?
I have an 05 sti with a version 7 swap running the full usdm intake tgv deletes fully opened up and polished dw 1000s on e85 running great. I swapped in the usdm intake cams revalve clearanced everything and milled the heads for the usdm cam sensors and tig welded the caps. Runs beautifully tuned for just under 400 whp
NVM Op i seen that this was exactly what you did. Great job man 207 for the win. Doing a RHD conversion on my 04 wrx which is full sti now with a v7 ej207 lol
04wrbscooby is offline   Reply With Quote
Old 07-23-2015, 04:49 PM   #47
supersuby2
Member#: 161678
2002 wrx V5 RA swap
Default "usdm 32 bit ecu running jdm V9 engine, in 2005 fxt"
I'm currently working on a similar setup. Version 8 jdm Sti 207 into a 2004 usdm STI. I'm looking for more info on the head milling process and also wondering if there is a possibility of using cam sensors from another vehicles that would fit the ver8 heads without machine work. For example I noticed one of out fleet vehicles has a very similar 3 wire cam sensor and low and behold it turns out that it fits in the hole in the head very well and when compared to the stock ver 8 cam sensor the tip of the sensor to mounting flange length is almost spot on. I'm not far enough into it to know but it's something I'm looking into. Amroof, can you get me more info on the head work needed, and if it was due to the depth of the usdm Sti cam sensor being shorter then the vers 8 sensor, or due to change in the diameter on the cam at the pickup point, or a combination of both that is why the head needs to be milled.
Thanks,
supersuby2 is offline   Reply With Quote
Old 05-06-2016, 03:55 PM   #48
Bosque
Member#: 326081
2005 Saabaru STi
I am needing to do this to my 207 heads and haven't found quite the right answers. I haven't found a good guide yet. I will keep looking.
Thanks,
Any results on this?
Link Please
Bosque is offline   Reply With Quote
Old 05-06-2016, 05:05 PM   #49
Bosque
Member#: 326081
2005 Saabaru STi
http://forums.nasioc.com/forums/show...sensor&page=14
This was the one that I have been looking for for weeks.
Found it.
Old 05-08-2016, 02:37 AM   #50
amroof
Member#: 211224
2005 Saabaru
Who knows
Sorry guys it's been a while. Anyways I'm going to be helping a buddy mod a 207 for his 05 Sti. I'll try and get better pictures but reference the link above.
Differences between JDM V9 STI, JDM V9 Spec-A/B/C, & JDM V8 Spec-C (Heads)??? nomorem3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 04-06-2013 08:57 PM
64 Bit OS vs 32 Bit OS MarcsRX Off-Topic 53 08-07-2009 02:17 PM
FS/MN: Sealed Windows Vista Ultimate - Full Version: 32 bit/64 bit! WRXEcho Non-Subaru Stuff 1 12-03-2008 12:41 AM
What version of Vista should I run 32 bit vs 64 bit? Jsunn Off-Topic 14 05-08-2007 10:44 PM
Another VMWare Server question: 64 bit host or 32 bit host OS? -=C=- Off-Topic 31 04-16-2007 07:07 PM
