Old 12-01-2012, 11:37 PM   #1
05subysti
Member#: 268190
2005 STi
Default anyone do custom wide body? i need advice
hey everyone i start to do a trial n error wide body. I'm just experimenting on how wide and what style wide body i want.
should i use my templates to make the widebody in sheet metal?
or would it be better to make a fiberglass mold and make an overfender?
here are pics:
Old 12-02-2012, 01:50 PM   #2
05subysti
Member#: 268190
2005 STi
so ive decided on fiberglass. it is alot cheaper and easier to shape.
anyone have advice on what fiberglass, resin, gel coat, i should use?
i also read on something named tiger hair.
Old 12-02-2012, 07:08 PM   #3
omiotek
Member#: 272090
Tiger hair won't work for you. Its a heavy bodied filler mixed with glass. You need your initial coat down first. Make a plaster or clay mold fiberglass over it. You need all your contours and what not first. If you don't have a lot of body experience I would have someone help you or don't bother attempting the task yourself.
omiotek is offline   Reply With Quote
Old 12-02-2012, 09:28 PM   #4
05subysti
Member#: 268190
2005 STi
Yeah I'm gonna use styrofoam, and polyurethane expanding foam to cut and shape the width and contour.
Then lay plasticine, resin w/hardener, fiberglass woven cloth, to make the mold.
My goal is to make a rivet on overfender with a flare around 90mm.
Right now I'm just researching. When I get the funds then I'll actually attempt it.
If anyone has advice on what the best quality and reasonably priced products to use. I'm all ears.
Old 12-02-2012, 10:38 PM   #5
madlib
Member#: 16149
2001 impreza 2.5RS
blue
Check out this forum: http://www.fiberglassforums.com/
There are a lot of build threads, advice on what products they prefer, etc. But you are only given a certain amount of threads you can read, then, ask you to register (free).
madlib is offline   Reply With Quote
Old 12-23-2012, 12:32 PM   #6
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
mod some kakumi flairs? I dont know anyone that would need more tire than what a karlton flare will hold though. You could alway tub it and go with a 9" rear.
Old 12-24-2012, 08:45 AM   #7
MattTHEpainter
Member#: 284046
2000 Impreza w/ WRX
The work involved to do this would be staggering.
Old 12-25-2012, 06:55 PM   #8
hoffmanEstates
Member#: 122043
04 wagonier
psm
Bleh..........
hoffmanEstates is offline   Reply With Quote
Old 06-20-2013, 05:16 PM   #9
SexyWRXy43
Member#: 311562
Before this thread gets too old... Just curious if this project ever got done, if it's still in progress, still considering for future build, or if it turned into a bail? It looks like it would be an amazing fitment project.
SexyWRXy43 is offline   Reply With Quote
Old 06-20-2013, 09:27 PM   #10
05subysti
Member#: 268190
2005 STi
It still in consideration. I have many stages on my car to complete before starting the wide body..
Old 06-21-2013, 12:46 AM   #11
SexyWRXy43
Member#: 311562
So you still plan to use the crazy low offset Professors? And I'm assuming you're going to do the front just as aggressive?
Old 06-21-2013, 01:10 AM   #12
05subysti
Member#: 268190
2005 STi
Yes. Btw they're not professors they're work meisters. And the fronts aren't as aggressive.
Old 06-23-2013, 12:11 AM   #13
Sev
Member#: 8364
4.5 STi
dirty
Sev is offline   Reply With Quote
Old 06-23-2013, 09:01 PM   #14
05subysti
Member#: 268190
2005 STi
Thanks for the thread link! Some good work in there lol
Old 06-29-2016, 09:51 AM   #15
orangesti
Member#: 385825
orangesti is offline   Reply With Quote
Old 07-15-2016, 12:48 PM   #16
TURBOTOD
Member#: 97130
2004 WRB WIDE STI
COBB/TIC/CUSCO/DSS/TSSFAB
^ Functional Rally-Style lifting points on the side skirts? Or simply for aesthetics?
Not a fan of the color, but I appreciate all the work put into it.
Peace
-TurboTod
TURBOTOD is online now   Reply With Quote
