Old 12-21-2012, 01:07 PM   #26
myrt1987
Member#: 323103
2012 Limited 2.0i
Dreamy Gray Mistress
Originally Posted by SZRimaging View Post
Because they are predictable, loads of traction, and easy to control. The loads of traction allows you higher speeds than a normal FWD or RWD vehicle in things such as snow.
As for regaining control in AWD vs FWD, never had an issue with a properly equipped (Hakkepalettas) with my old Golf. Get her sideways, point the nose, power out.
ok so if its only about traction, is it more fun then dry pavement driving? I cant wait to find out on my own btw. super jealous of you guys.
Old 12-21-2012, 01:11 PM   #27
SZRimaging
Member#: 314053
2012 Impreza
Marine Blue Pearl
Going backwards in the system, it's the pipe right before the input into the exhaust it's self. Trying to come up with the right name, but failing here. So out of the exhaust, there is a small elbow and then a spot where it joins up to the next pipe. That one is completely brown and rusty looking. I need to go in for my second oil change soon, so I'll probably have the dealer look at it then.
SZRimaging is offline   Reply With Quote
Old 12-21-2012, 01:15 PM   #28
SZRimaging
Member#: 314053
2012 Impreza
Marine Blue Pearl
Much more. That said, the TCS is annoying, and basically prevents you from having as much fun as you would have been able to. Even with it clicked "off", it is still there, just weaker. Not to mention, there has been more than one corner where it left me just drifting to the outside instead of allowing me to point the noise and send power to the wheels. I used to be able to drift my Rav4 (gen 1) for about a half a block to a block in the right conditions, but newer cars with their ESC and TCS won't let you do that...
Old 12-21-2012, 02:14 PM   #29
myrt1987
Member#: 323103
2012 Limited 2.0i
Damn I want snow so bad. Stupid global warming.
Old 12-21-2012, 05:25 PM   #30
freefaller25
Member#: 322308
Got out this morning in the second snow this year but the first with my new DWSs on. Major improvement over the stock Yokos. I lost 3 MPG on the highway but gained much more wet and snow/ice traction.
I had the DWSs on my A6 also and they do even better on the Impreza. The weight of the A6 was noticeable in the snow when cornering causing some slides when pushed a bit. The Impreza drives like it is on rails. As soon as you make it slide the stability system goes nuts.
freefaller25 is offline   Reply With Quote
Old 12-21-2012, 09:44 PM   #31
Pickler
Member#: 301247
09 Impreza 2.5i MT
post deleted by user
Pickler is offline   Reply With Quote
Old 12-21-2012, 10:53 PM   #32
BajaGuy68
Member#: 127720
2015 WRX
Lightning Red
Just got home! Fun in the snow for me is; passing people that are doing 20-30mph in cars and SUV's equipped with all-season tires. This is why I always have on winter tires this time of year! ....and I was going around 50mph as I passed them. Yes, I like the look on their faces as I go by them! Subies Rule!
BajaGuy68 is offline   Reply With Quote
Old 12-22-2012, 11:04 AM   #33
ukrainian102
Member#: 296019
2011 WRX Premium
Always had loads of fun like this in my old Corolla (handbrake to initiate slide). Trying to still figure out how to get sideways in the snow with AWD. Well the actual getting sideways is easy enough, if you just turn sharply (though still not as easy as using handbrake in a FWD). But as far as the power-out to return aspect, not sure if pointing the front wheels and hitting the gas will return the car from a sideways slide since the rear wheels are working against you in that case. Anyway so much more control with AWD and snow tires (usually just point where you want to go and push the gas), but the snow drifting aspect still needs to be ironed out coming from being used to FWD techniques.
ukrainian102 is offline   Reply With Quote
Old 12-22-2012, 06:41 PM   #34
aeoporta
Member#: 334126
2016 2.5i Premium MT
Dark Gray Mettallic
Drove from Schenectady to oneonta via rt 88 today snow mountains cars spun out I cruised through them all at 60 with a smile on my face passed a whole lot of SUV and awd vehicles struggling uphill
Old 12-22-2012, 07:01 PM   #35
9925RSTURBO
Member#: 292722
Yeah. I have blizzak snows and they are amazing! Nothing but traction everywhere! I even bring a tow rope with me in the snow cuz people tend to get stuck and u can make a lot of $ towing them out lol.
9925RSTURBO is offline   Reply With Quote
Old 12-22-2012, 07:35 PM   #36
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
Hmmm, I wonder if our trannies/differentials/etc. can handle that kind of work?
Old 12-23-2012, 08:42 AM   #37
Guzzi 1
Member#: 338666
2014 Impreza Limited
SWP/Blk Leather CVT
I have no intention of finding out myself. I'll just smile as I drive away easily as they watch.
John
Old 12-23-2012, 12:03 PM   #38
tomwi53092
Member#: 316315
2012 Imp HB/Prem/CVT
DCP
I've got the tow rope from my last vehicle, but now with the Impreza, without a hitch on the back, I don't think there is an easy place to attach it on my car. Not gonna put the tow hook in place unless it's to get *me* towed.
tomwi53092 is offline   Reply With Quote
Old 12-23-2012, 10:24 PM   #39
cnlson
Member#: 310098
2012 Impreza PremCVT
Dark Cherry Pearl
on the front right and rear left there is a tiny little square in the bumper you can pry out and in the back with your spare is an eye bolt that screws into the hole and works perfect for towropes, not sure i would try a chain but to each his own. this is expressly for towing either yourself or hooking up to someone else.
if you look in the back first, there is actually a flat blade screwdriver to accomplish this.
cnlson is offline   Reply With Quote
Old 12-24-2012, 07:00 AM   #40
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Tomwi said he doesn't want to use the tow hook unless he's the one getting towed.
Old 12-24-2012, 08:47 AM   #41
LGA2011
Member#: 321173
My impreza is equipped with X-Ice 2 on very cheap 17inch alloy wheel.
It's a bit scary on very icy road to get rear ended, because it is too easy to drive & you see everyone else sliding like no tomorrow. The EBD along with the ABS system work like a charm.
On the snow it provide decent traction but not to the point of saying they are awesome. you clearly see a huge difference in acceleration compare to FWD cars.
I also changed my wiper with Rain X which perform a tad bit better than the OEM one. The OEM one doesn't seem do add enough pressure to wipe the glass properly. The Wiper De-Icer is mostly useful on snowy day. On very low temperature the wiper work even before the windshield is completely de-iced to a point you can crap out the rubber of your wiper if you don't pay attention of the ice over it.
LGA2011 is offline   Reply With Quote
Old 12-24-2012, 09:29 PM   #42
Commander Keen
Member#: 319157
2012 Impreza 4DR 5MT
I'm running X-Ice 2 as well, but on 15s. Excellent tire and quieter than stock. I really had to try hard to lose traction in fresh snow. Acceleration in 2nd was no slower than on dry pavement.
A RWD Pathfinder did a 270 in front of me on a very gentle slope. He drove 20 MPH the rest of the way home, ruining my fun.
Commander Keen is online now   Reply With Quote
Old 12-25-2012, 08:10 AM   #43
Angelus911
Member#: 89967
2012 Impreza Sport
Get to put my snow tires on today, finally! Snowing today here as well, so great timing. I painted stock WRX wheels black, so ill post some pics once I get them on
Old 12-25-2012, 10:16 AM   #44
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
This is what the old stock 16" WRX wheels look like that I bought with used Blizzak WS60 snow tires already installed. Previous owner painted them black.
Old 12-25-2012, 10:23 AM   #45
Guzzi 1
Member#: 338666
SWP/Blk Leather CVT
I headed out after work last night to deliver some presents to my son, his wife, and child. On the way home, the roads got real bad. I dare say I believe the new car does better than my '03 rex did. No doubt the VDC is working well. The going was effortless. Cars in the ditch, people creeping along, me smiling all the way. Strictly for the ability to get around, I'm loving this! It won't be as easy to have a little fun though. One of these days, I too would like to get a set of wheels and some winter tires. For now, the Yoks will have to do.
John
Old 12-25-2012, 10:25 AM   #46
Guzzi 1
Member#: 338666
SWP/Blk Leather CVT
Nice. That should be a tank in the snow!
John
Old 12-25-2012, 10:57 AM   #47
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
John
Thanks! I'm taking her to the Adirondack mountains tomorrow, and will probably find out then just how tank-like she is!
Old 12-25-2012, 04:32 PM   #48
aeoporta
Member#: 334126
Dark Gray Mettallic
Currently in central ny. Sgoldste looks like we have a nice storm tomorrow I have been in the mountains all week it's snowed everyday. Disable vdc when you are climbing in mountains that way traction control doesn't annoy you. I will be taking back roads to oneonta then head back to nj from there hmm they say might get more than a foot it's about time we had some nice winter weather.
Old 12-25-2012, 11:05 PM   #49
ans2k
Member#: 315631
2012 Impreza Sport
What is the deepest the impreza can handle? Currently in little rock, Arkansas and there is about 5 inches and the impreza can handle very well with the DWS on. I am very impress about the tank like characteristic but It is definitely different than the rwd bias the c240 4matic Mercedes. The c240 was joy to drive in the snow. Easy to drift but the impreza is not. oh well. I feel confident in the impreza just like the c240. Hopefully the impreza can handle 8 or 9 inches of snow
Old 12-26-2012, 06:43 AM   #50
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
I would be skeptical that any car can handle a depth of snow that's higher than its ground clearance. Maybe if it's light, fluffy snow. But I wouldn't expect our Imprezas (or even the XV) to handle 9" of heavy snow.
I'd be happy if it could do that, but I wouldn't be surprised if it can't.
