Old 12-23-2012, 11:29 AM   #1
cnlor
Member#: 233120
03 wrx
yellow
Default help! primed car over too much.
Okay, so my car is running rich and I tried cranking the car over a couple times and it didnt turn over.
Is there a way for me to get most of the gasoline out?
Any tricks?
I can push start it but its way too slippery to push it with the snow.
cnlor is offline   Reply With Quote
Old 12-23-2012, 11:34 AM   #2
cnlor
Member#: 233120
03 wrx
yellow
Will drying out my plugs work?
Old 12-23-2012, 11:49 AM   #3
EROCS04SBRUSTI
Member#: 234397
2004 WRX STI WRB
15 DGM FXT
let it sit a few hrs sometimes that works or remove plugs and ignition fuse and crank it over and it will blow everything out then try it if you can't wait.
EROCS04SBRUSTI is offline   Reply With Quote
Old 12-23-2012, 11:51 AM   #4
cnlor
Member#: 233120
03 wrx
yellow
Hi!
Yes I checked plug 1 and it was covered with gas. Which one is the ignition fuse? Is it under inside the driver seat?
Old 12-23-2012, 11:59 AM   #5
EROCS04SBRUSTI
Member#: 234397
2004 WRX STI WRB
15 DGM FXT
like mine should be on the left side of the dash look underneath and at the owners manuel not sure if the same of my 04 sti
Old 12-23-2012, 12:00 PM   #6
EROCS04SBRUSTI
Member#: 234397
2004 WRX STI WRB
15 DGM FXT
Old 12-23-2012, 12:03 PM   #7
EROCS04SBRUSTI
Member#: 234397
2004 WRX STI WRB
15 DGM FXT
acctually do the fuelpump here's a link!
http://www.rs25.com/forums/f106/9819...-switch-4.html
Old 12-23-2012, 12:09 PM   #8
cnlor
Member#: 233120
03 wrx
yellow
Ok thanks!
I took all the plugs out. Wouldnt doing the fuse be easier?
Old 12-23-2012, 12:12 PM   #9
cnlor
Member#: 233120
03 wrx
yellow
I have a 06 wrx. Maybe i can just google the ignition fuse
Old 12-23-2012, 12:13 PM   #10
mccanixx
Member#: 60566
2005 XT 5sp, 02 WRX
01 Legacy 95 Impreza L
Fuel pump/ignition should be 11
mccanixx is offline   Reply With Quote
Old 12-23-2012, 12:15 PM   #11
EROCS04SBRUSTI
Member#: 234397
2004 WRX STI WRB
15 DGM FXT
fuses and plugs out to blow everything out the cylinders
Old 12-23-2012, 12:29 PM   #12
cnlor
Member#: 233120
03 wrx
yellow
Ok. I just undid the plug on the FP.
What are the procedures now? Just put the plugs back in and keep starting it?
Old 12-23-2012, 12:30 PM   #13
cnlor
Member#: 233120
03 wrx
yellow
Can you explain it a bit more please. I kind of got confused.
Old 12-23-2012, 12:39 PM   #14
EROCS04SBRUSTI
Member#: 234397
2004 WRX STI WRB
15 DGM FXT
sorry typing fast,find out where your fuel pump fuses are from the factory service manual ,it could be linked to the ignition fuse but I don't think so.Pull out the spark plugs then as there is gas in the cylinders per say.Once all the plugs are all out and fuses for the pump turn the car over more than a few times to wash out/blow out the gas filled cylinders.Then reinstall new gapped plugs to spec or reinstall your old ones if not all fouled up if you can burn the gas off with a lighter.Then reinstall the coils and harness and fuses and hopefully its starts without pumping the gas first,if not try half throttle hopefully it works out bud.
Old 12-23-2012, 12:56 PM   #15
cnlor
Member#: 233120
03 wrx
yellow
Ok thanks! I disconnected the FP plug. I'll give it a shot
Old 12-23-2012, 12:59 PM   #16
cnlor
Member#: 233120
03 wrx
yellow
Success! Thanks guys! Come over for some pizza!
Old 12-23-2012, 02:28 PM   #17
EROCS04SBRUSTI
Member#: 234397
2004 WRX STI WRB
15 DGM FXT
awesome glad I can help as others as well.
Old 12-23-2012, 04:35 PM   #18
jziegler
Member#: 275858
2004 Wrx Sti
Java Black Pearl
I would change the oil also
jziegler is offline   Reply With Quote
Old 12-23-2012, 06:18 PM   #19
danger1138
Member#: 279525
04 rex luger!
Can u prime the car too much? I usually, especially on cold mornings, would pull the ignition fuse the step on clutch and turn the key as if i was gonna normally start it. I do this to get things a lil lubricated on cold mornings. Im using 15w40 btw..
danger1138 is online now   Reply With Quote
Old 12-23-2012, 08:12 PM   #20
Larimer
Member#: 205191
2006 Saab 9-2X Aero
Seems kind of ridiculous to go to those lengths to keep it lubricated with thicker oil. Switch it in the winter, maybe?
But priming it shouldn't hurt, it'll just drain your battery and put more strain on your starter.
Larimer is offline   Reply With Quote
Old 12-24-2012, 10:47 AM   #21
cnlor
Member#: 233120
03 wrx
yellow
Ohhh. I am using VR1 (20w-50) suggested by the guy who built my motor. I'm guessing I just need to find the ignition fuse next time huh?
Old 12-26-2012, 01:36 AM   #22
i would NOT use 15w40 in winter
Old 12-26-2012, 01:37 AM   #23
and if the idiot who build your motor to the wrong specs for a street motor thinks it needs 20w50....its because he dont know what he is doing building a motor
20w50 is RACE engine oil...not street engine oil
Old 12-26-2012, 02:03 AM   #24
z
Member#: 41762
04 STi
CT-DE-FL rinse+repeat
FYI, if you have the throttle down at 100% while cranking, it cuts fuel and you can achieve the same effect without bothering to pull the ignition fuse.
(and not dumping a bunch of fuel into the cylinder without starting... unless you're also pulling the fuel pump relay)
z is offline   Reply With Quote
Old 12-26-2012, 04:11 AM   #25
pulling the IGN fuse disables the injectors
