#76 |
Member#: 209401
NWIC
Vehicle:2005 Sti Silver |
So what is the final verdict on the blow thru MAF is it worth the hassle or not?
#77 |
Member#: 151260
MAIC
Vehicle:2005 Sti 423whp/422wtq on 93 |
Honestly, it's not needed anymore. If you know a thing or two about roms, or are willing to learn, go speed density. Your 2005 STI is probably supported. Open Source speed density support:
http://http://www.romraider.com/foru...forum.php?f=37 |
#78 | |
Member#: 260314
NESIC
Vehicle:2008 STI hatch silver |
A factor, and one of my unknowns, is what size CAI I need and do I want my MAF there. I will be running a Borg Warner 8374 and a reversed intake off a N/A Impreza and ported, big valve heads. By my calculations, I will be moving 64-68 lbs/min of air at max RPMs. I wonder if I need a 3-1/2" or 4" CAI to match the BW 4" OD compressor inlet? If I run a big cold air inlet, is it all the more reason to run blow-through or can scaling accomodate 4" D where velocity reaches about 15 F/S? Lots of questions. This is a weak area for me. In the past I have just run the Cobb CAI and KS Tech MegaMAF (73mm Big MAF CAI), into my Blouch 2.5XTR. and was fat, dumb and happy. ![]() |
#79 | |
NASIOC Manufacturer
Member#: 4803
Bill |
| Thread Tools | |
| Display Modes | |
| perrin blow thru maf boost tube | Team Pink Taco | Factory 2.5L Turbo Powertrain | 1 | 12-30-2006 02:23 PM |
| Top Speed Blow-thru MAF Adapter Plate( Pics) | Peeblesmx445 | Engine/Power/Exhaust | 16 | 11-30-2006 03:24 PM |
| blow thru MAF flanges??? | PerformanceAutoSolutions | Engine Management & Tuning | 5 | 08-24-2006 08:51 AM |
| Blow thru maf intake | BLUE STINGER | Factory 2.5L Turbo Powertrain | 4 | 07-18-2006 11:55 PM |
| Blow thru MAF, there is HOPE! | tmarcel | Factory 2.5L Turbo Powertrain | 44 | 02-20-2006 09:26 PM |
