![]() Tire & Wheel Forum sponsored by The Tire Rack |
#1 |
Member#: 324810
MWSOC
Vehicle:2013 STi DGM |
So on 12/18/2012 I put on a pair of new Bridgestone Blizzak LM-60s on my '13 STi. 225/45/17 with '06 Gold BBS wheels. What a NIGHTMARE. On the way home (we just had a little haill the day before), I was driving on the highway and the car felt disconnect from the car when moving lanes at 55MPH. It felt like hydroplaning. I have nearly collided with a car because the tires just don't turn well. I took the tires in the day after I got them to make sure they were put on right, and tightened to right properly.
Even at low 35mph speeds I feel like the tires are losing traction. On 2nd gear on all roads I lose traction and have to force shift myself into third to get going. It has been really scary with these things on the car. My question is: Is this NORMAL for the LM-60? Even if it is I'm requesting an exchange with Discount tire. The DOT# is 0312 (3rd week 2012?) How can this be? Is there something wrong with my STi?
#2 |
Member#: 311224
MWSOC
Vehicle:2011 Impreza WRX SWP |
Thats not normal. I am 100% confident in mine 235/45/R17 whether im on ice snow etc. Sounds like a defective tire. I would see if the place that installed them would give you another set.
The car will feel a little different because its a softer rubber and the tread flexes alot but you definitely shouldnt be having those issues. |
#3 |
Vehicle:OK Houston we have an Uncle |
what pressure is in them???
sounds way overinflated |
#4 |
Member#: 324810
MWSOC
#5 |
Member#: 324810
MWSOC
#6 |
#7 |
Member#: 280572
E. Canada
Vehicle:2011 sti sedan plasma blue pearl |
There is nothing wrong with your tires u need to adjust yourself and proper tire pressure. I'm on my second season with mine and one thing for sure is proper tire pressure makes all the difference. For highway 36 front, 35 rear except in really bad snow and ice drop them down to 33 front 32 rear.
What I meant by adjusting yourself is that u were use to a certain way of how your suby handled and now has drastically bin changed and u will have to change your driving habits. The lm-60's r a great performance winter tire as I have no complaints but I know exactly what u r experiencing hope this helps Edit: if this issue still persist then I would look at getting an alignment. Also is your suspension stock?? Last edited by trev762; 12-23-2012 at 08:13 AM. |
#8 |
Member#: 207528
Vehicle:2005 Legacy GT |
#9 |
Member#: 324810
MWSOC
#10 |
Member#: 8365
Vehicle:2005 Legacy GT Ltd Atlantic Blue |
LM-60 is not great performance winter tire. There are much better tires but probably not available in the USA this winter.
What was the weather like when you experienced such terrible handling? Dry? Wet? Temperature? Are you sure you have LM-60 and not WS-60? Krzys |
#11 | |
Member#: 207528
Since these are directional tires, are all the tires correctly mounted and rotating in the correct direction? |
#12 |
Member#: 21392
Tri-State
Vehicle:2007 IMPREZA WRX STI urban gray |
2 winters on my lm60's no problems .
give it a couple 100 miles more . |
#13 |
Member#: 324810
MWSOC
#14 |
Member#: 21392
Tri-State
#15 |
Member#: 127745
NWIC
Vehicle:06 WRX 30r 6 speed 99L EJ255 6 Speed |
Ya tires are pretty greasy at first too
#16 |
Member#: 1026
MWSOC
Vehicle:'00 RS/WRX Stg5 '98 RS Stock |
Think "dirt bike" when you are driving on snow tires, not "go kart"...
Everything needs to loosen up, including you... Let the car move and find grip, don't try forcing it... You'll start to get it... Explore the limits somewhere safe... Once you start getting it down, it's soooooooooooooooooooooooo much fun... |
#17 |
Member#: 207528
So true. Apparently, a lot of people don't realize that winter tires need breaking in for several hundred miles before they can achieve maximum traction.
Case in point, this customer review at tirerack of Michelin X-Ice Xi3 tires with only 100 miles on them: "I checked Consumer Reports before I ordered these tires: Michelin X-Ice Xi3's. ............ We just had a snow, then rain, freeze overnight, with snow again. So, this is the first time today that I have actually used them on snow and ice. They are great on snow, but not so much on ice. I slid about 10 feet on one road, and when I started to go on a green light, the tires spun and went sideways. I learned very quickly to stop about 20 feet behind another car and to not go over 20 mph on the ice!..........." |
#18 | |
Member#: 324810
MWSOC
#19 | |
![]() defective tires???? ok....even with a few hundred miles on them, they are fully warrantyable from any reputible dealer |
#20 |
Member#: 324810
MWSOC
First set of snow tires so im not sure how the warranties work on those. I had a defective set of dws continental's back during their first generation of them on my caddy. It happens. Regardless of whether
#21 |
Member#: 324810
MWSOC
First set of snow tires so im not sure how the warranties work on those. I had a defective set of dws continental's back during their first generation of them on my caddy. It happens. Regardless of whether it's working or not. Better safe than sorry.
#22 |
Member#: 324810
MWSOC
Does anyone know what the proper PSI would be for these tires? I think it's 35 all around currently. It's about 20-30*F where I live right now.
#23 |
Member#: 280572
E. Canada
#24 | |
that may be too much pressure for these tires that is why i suggested WAY UP TOP, here to try dropping the pressure glad to see that nobody is paying attention ![]() jesus ![]() |
#25 |
Member#: 338546
Vehicle:2003 Impreza RS Silver |
Someone said snow. Isn't it wonderful.
