Welcome to the North American Subaru Impreza Owners Club Friday February 27, 2015
Old 12-07-2012, 12:49 AM   #51
SharpTuning
Member#: 333363
Originally Posted by Dirtrace95 View Post
Well that didnt work. I guess i'll have to send the ecm somewhere. Im so mad at myself ...... I never do stupid stuff like that .... Going to delet
that super simular named map so that does not happen again ..... dam .......
Sorry to hear that
You weren't the first and I'm sure you won't be the last.
It's really a shame ECUFlash isn't open source. It would be trivial to implement a failsafe by cross referencing the open Rom image with the ECU ID given by the SSM2 Init. But I suppose if you're making money from recovering bricked ECM's that would be a conflict of interest.
SharpTuning is offline   Reply With Quote
Old 12-07-2012, 02:24 AM   #52
Dirtrace95
Member#: 231315
06 WRX Wgn
Would you know if an 06 WRX ecu ending in 201x "the original" is interchangeable with
06 WRX ecu ending in 200x ???? Im hoping there is not a 16 vers 32bit issue between the two
Dirtrace95 is offline   Reply With Quote
Old 12-07-2012, 04:32 AM   #53
SharpTuning
Member#: 333363
Yep, A8DH200X, A8DH201X, and A8DH202X roms are all cross-compatible for the 06 USDM WRX that use the ecu marked '22611AL350'.
However, you will need to have the car towed to a dealership/shop with SSM3 diagnostic tool (or have them come to you) to have the new ECU paired with the immobilizer and your keys. That will run ~100 something depending on the dealership and you will need the key code that comes with your keys (small plate with etched numbers). It's something like $50 for the dealer to look up the key number if you lost it.
Old 12-07-2012, 07:30 AM   #54
quazimoto
Member#: 70395
/\ Best bet is to send the ECU to Tactrix and have them bench flash it.
Old 12-07-2012, 11:00 AM   #55
Dirtrace95
Member#: 231315
06 WRX Wgn
That sounds like the cheapest way..... How do i find them. What
state are they in ???
Old 12-07-2012, 12:03 PM   #56
gberryhill
Member#: 222308
2004 STi
Honestly i would send it to COBB. They charge almost exactly the same after shipping. COBB was able to fix my ECU after the first brick. Tactrix was not. So i was screwed out of close to 50 in shipping costs.
gberryhill is offline   Reply With Quote
Old 12-07-2012, 07:56 PM   #57
quazimoto
Member#: 70395
How do i find them.
The internet. www.tactrix.com
Old 12-08-2012, 12:39 AM   #58
Dirtrace95
Member#: 231315
06 WRX Wgn
Which cobb shop did you send it to, The place here In Ore. said send it
Texas.....
Old 12-10-2012, 12:43 PM   #59
gberryhill
Member#: 222308
2004 STi
Texas.....
Yeah I sent mine to Austin Texas. You have to fill out this RMA form.
http://www.cobbforums.com/forums/ima...ceForm_2.5.pdf
Old 12-27-2012, 03:04 AM   #60
SimpleWrx
Member#: 315068
2005 wrx
I had trouble with Tactrix cable it wouldnt connect they said my ecu was bricked. but come to find out it was the cable. Possibly the cable is screwing everything up? if that indeed is what your using. if not disregard this post lol
SimpleWrx is offline   Reply With Quote
Old 01-04-2013, 01:33 PM   #61
gberryhill
Member#: 222308
2004 STi
Thanks for the info. I will see if I can borrow a friends cable to try and flash the next time.
Old 01-15-2013, 12:31 AM   #62
gberryhill
Member#: 222308
2004 STi
Success! I finally got my car running again. I got another ECU and flashed the map i need without problems. After following advice on here, I pulled the stock tune from the ECU then copied the tables from the pro tune over in RR. Flashed it back and it worked perfectly! Thanks for all the help from everyone. I am still not really sure what caused the problem was with my first ECU. I still plan on sending it to sharptuning to see if he can unbrick so i will have a spare.
Old 01-15-2013, 12:45 AM   #63
chappell943
Member#: 297718
2001 V7 Sti Prodrive
Good news!! glad to hear the car is running again, must be an awesome feeling. I just bought a spare ecu for my car incase something like this happens!
chappell943 is offline   Reply With Quote
Old 01-17-2013, 12:31 PM   #64
SpongeBobSquarePants
Member#: 296048
2011 STI
Blurple
I would beat the first ecu with my ball peen hammer, before I spent more money on it. Seems like that ecu may have been your problem
SpongeBobSquarePants is offline   Reply With Quote
