Welcome to the North American Subaru Impreza Owners Club Thursday December 8, 2016
Old 12-26-2012, 11:14 AM   #1
sirCASHalot
Member#: 286885
2007 sti
Default Blown Engine?
i have an 07 sti, 73k miles, i did an oil change 1868 miles ago to correct level, last time i checked it was like a week and 1/2 before this happened
soooo i was driving around 85 mph...
i noticed alot of smoke comming out of my exhaust thru the mirror i slowed down then realized their was also white smoke comming out of my hood
engine light started flashing.
i put in neutral and rolled off the freeway, popped my hood and saw that dip stick was blown out with white smoke comming out, oil was spilled all over that half of the motor
i checked oil dip stick, NO oil in it...
the oil looks like it has coolant in it
its my only car, im a student, not alot of money
how can i fix? without paying 6K at a shop
thanks fo any help
sirCASHalot is offline   Reply With Quote
Old 12-26-2012, 11:42 AM   #2
illestuknow
Member#: 207338
2004 30r STI
JBP
If you have the knowledge(or have friends that do), do all the labor you can yourself.
(I.E. remove block from car, disassemble block, ETC) It'll save you money but rebuild is still gonna cost you lots of money depending on what needs to be replaced.
illestuknow is offline   Reply With Quote
Old 12-26-2012, 11:55 AM   #3
HonduHunter
Member#: 28408
2002 vf48ed WRX
This. Even maybe buy a beater to drive around until its fixed if your that strapped for cash.
HonduHunter is offline   Reply With Quote
Old 12-26-2012, 12:02 PM   #4
samagon
Member#: 26859
of TXIC
I also like (oYo)!!!!
sounds like a headgasket, but whatever, do what hondu says, get something you can drive for $500 (or less) you can sell it for the same when your car is fixed.
Old 12-26-2012, 12:13 PM   #5
sirCASHalot
Member#: 286885
2007 sti
i dont have much knowledge when it comes to that, im sure i can pull the motor tho
and yes i was thinking of buying a new daily
anyonw have a toyota 22r for sale?
Old 12-26-2012, 12:14 PM   #6
sirCASHalot
Member#: 286885
2007 sti
i have not taken to have it checked out, im just expecting the worst
Old 12-26-2012, 12:54 PM   #7
HonduHunter
Member#: 28408
2002 vf48ed WRX
I just did a head gasket. I did a lot of other stuff while I was in there too.
Spent about $1500 but did all they work at my house. (Aside from the valve job)
Old 12-26-2012, 01:04 PM   #8
sirCASHalot
Member#: 286885
2007 sti
does mine sound like a head gasket? i mean their was no oil shown on the dip stick
i know you cant really tell me over the web
i guess i just have to do compresssion/ leak down test?
it wasnt over heating
Old 12-26-2012, 01:04 PM   #9
young j
Member#: 144478
2005 sti
wr blue
Welcome to the world of performance cars ....I learned the hard way about stuff like this my first car was a turbo rotary...
Sounds like a head gasket , you might as well get in there and rebuild the engine at that kind of mileage.
6k is kinda high though shop around first.
young j is offline   Reply With Quote
Old 12-26-2012, 03:38 PM   #10
sirCASHalot
Member#: 286885
2007 sti
any recomendations as to where to shop?
i have asked AWDtuning and engine logics 1st
any private guys out their who know what they are doing?
Old 12-26-2012, 07:12 PM   #11
05subysti
Member#: 268190
2005 STi
6k for an oem rebuild? That's too high.
Hmm just get friends with tools, and do the work yourself.
No use for paying someone 3-4k in labor when you can save that.
Then you'll know how to do it in the future, and have side jobs to get extra cash.
05subysti is offline   Reply With Quote
Old 12-26-2012, 09:42 PM   #12
HonduHunter
Member#: 28408
2002 vf48ed WRX
Yeah. Yank the engine yourself at least. That should save a lot of labor dollars. Then you can see what your working with and decide to rebuild or just buy another engine.
Old 12-27-2012, 12:21 AM   #13
aggarcia
Member#: 330146
2013 STI Limited
Yes you need to run a compression and then leakdown test to determine what is wrong with your STI. Everything else is a guess.
AG
aggarcia is offline   Reply With Quote
Old 12-27-2012, 12:27 AM   #14
WaitTheresMore
Member#: 289315
2006 STi
"Frosty"
as uncle Scotty says "its done, stick a fork in it" on a side note, I think that the oil pickup tube cracked
WaitTheresMore is offline   Reply With Quote
Old 12-27-2012, 12:35 AM   #15
yetogetanrs2
Member#: 153106
Sounds like a case of the head gaskets.
Yeah can, get a good short block w forged rods and pistons for 2.5-3.5k. Depending on the builder. Another 1-1.5k in misc parts. I am anal so I'd put all new parts on a built motor.
You have yourself a solid 475-500hp capable motor. Considering you do the work yourself.
Otherwise you are at the pitty of crappy machine shops that chase you out of their shop w a cam shaft for telling them that they do half ass work.
yetogetanrs2 is offline   Reply With Quote
Old 12-27-2012, 12:39 AM   #16
Jacobs11
Member#: 268948
04 WRX
PSM Sold :(
[quote/] its my only car, im a student, not alot of money
thanks fo any help[/quote]
Rather ironic when I looked at your username my vote's for the friends and tools option though. You'll learn a lot, save a lot, and feel pretty good afterwards
Jacobs11 is offline   Reply With Quote
Old 12-27-2012, 05:34 AM   #17
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
what oil was in iy..psecifically and exactly???
and the dipstick being blown out means its all DONE
Old 12-27-2012, 08:02 AM   #18
Anub1s
Member#: 81106
2014 Baby Mobile
Whitey White
Uncle McDrunky, is that you?!
Anub1s is offline   Reply With Quote
Old 12-27-2012, 08:52 AM   #19
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
blown oil dip stick..way excessive crank case pressure.
totaled head gasket or cracked cylinder..depending on if
you oil is still good or chocolate milk shake..
either way it not going to be cheap..
Old 12-27-2012, 09:41 AM   #20
Uncle Scotty
OK buy Nates beans
havnt been drunk in years and years
Old 12-27-2012, 10:46 AM   #21
roadtrip1098
Member#: 185688
2006 STi
WR Blue
Try checking the oil again, but this time pull the rubber o-ring off before sliding the dipstick back down. There's a well known Subie issue with the air pressure caused by the o ring seating causes inaccurate readings. Just make sure you put it back on when you're done. White smoke is never good, no oil is never good, smoke in the engine bay is never good. A new shortblock will run you about $2000, may want to have the heads sent out and port and polish while you have it apart.
Take your oil pan off the old motor and check for metal shards, if you find any, start shopping for a new turbo as well because there's a decent chance some have made it through the oil lines.
roadtrip1098 is offline   Reply With Quote
Old 12-27-2012, 11:39 AM   #22
sirCASHalot
Member#: 286885
2007 sti
6k built motor with labor, said he will install my 30r rotated kit at that price too, plus tune
yea thats my best bet, but the friends/family that can dont have time
Old 12-27-2012, 11:41 AM   #23
sirCASHalot
Member#: 286885
2007 sti
thanks fo any help
Rather ironic when I looked at your username my vote's for the friends and tools option though. You'll learn a lot, save a lot, and feel pretty good afterwards[/quote]
haha funny guy, i thought that would be one of the 1st comments i got when i posted
yea i might as well learn since i got a daily driver until i can fix the subi the right way
Old 12-27-2012, 11:43 AM   #24
sirCASHalot
Member#: 286885
2007 sti
damn, if turbo is pooped i will just install the 30r
thanks for the help
whats the best place i can get a block, as in have any of yall got one from online with success?
Old 12-27-2012, 12:55 PM   #25
FXTRunner
Member#: 104289
05 Forester
CGM
These guys have new shortblocks for the lowest price i've ever found:
https://www.flatironstuning.com/p-97...hortblock.aspx
FXTRunner is offline   Reply With Quote
