Old 12-26-2012, 10:30 PM   #1
scootarida1
Member#: 154534
2005 Forester XT
Borg Warner S261
Default Power Wagon Build Thread
I figured I should put some pictures of the setup I am running.
[Original Post Detail]
So I recently did a compression test since my 05 FXT was consuming about a qt of oil every 500 miles or so.
Here are the results (completed within 30 min of shutdown)
3---134 psi 4---125 psi
1---129 psi 2---121 psi
Unfortunately I was not able to run a leak down test because I couldn't find a socket for the crank. But from the compression test, it looks like its time for a rebuild. Let me know what everyone one else thinks.
My plan so far for the motor is:
Manley 8.5:1 99.75 Pistons
Manley H Rods or Eagle H Rods (Not Sure Yet)
King Race Bearings
ARP Head Studs
I am also looking to convert to top feed injectors. Im looking at the Five-O Black Ops 1400cc injectors.
The car is a DD and am looking for about 425-450 WHP on 93. So I plan on running tighter clearances since the car will only see a spirited pull here and there.
I'm thinking around 0.0028" for the PW clearance and I'm not sure for the rod and main clearances yet.
Anything I'm missing?
scootarida1 is offline   Reply With Quote
Old 12-26-2012, 10:54 PM   #2
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
ACL Race Bearings
ARP Head Studs
For 93 on a dd with forged pistons and no constant beat, but with 400-425 awhp I would do:
PWC minimum .003 with a happy spot of .0035
mains at .0012-.0014
rods at .0002 more than the mains.
top rings at .014-.015
second at .017 - .018
OCR rails at min spec of .015
At least that would be my starting point.
Just do the manley rods - there's a thread on this very subject going right now.
If you were burning that much oil you WILL have to at least clean the valves, and you will have to check the seats as I'm betting you have a good bit of carbon buildup going on with those.
Old 12-26-2012, 11:16 PM   #3
scootarida1
Member#: 154534
2005 Forester XT
Borg Warner S261
Yeah I've been reading that thread on the manley's. I will get the heads checked out for sure. Thanks for the input on the specs. I will take them into consideration when I am assembling the block.
Old 12-26-2012, 11:25 PM   #4
05_wRex
Member#: 170097
2007 WRX STi PTE6266
Is your current engine stock internals?
05_wRex is offline   Reply With Quote
Old 12-26-2012, 11:26 PM   #5
scootarida1
Member#: 154534
2005 Forester XT
Borg Warner S261
yes current is stock
Old 12-26-2012, 11:46 PM   #6
05_wRex
Member#: 170097
Gotcha. I figured. My compression numbers are pretty close to yours, but my engine is built.
Old 12-26-2012, 11:49 PM   #7
scootarida1
Member#: 154534
2005 Forester XT
Borg Warner S261
Yeah I felt that they were kind of low. Fairly consistent but Cyl 2 is to low for my liking.
Old 12-26-2012, 11:55 PM   #8
yetogetanrs2
Member#: 153106
Look into the Manley Turbo Tuffs. A bit on the heavier side but! Very strong.
I know for my build we are running .0038-.0041. From the research we've done that was a good happy median for a forged piston I am using.
I also plan to do a little more than just a few pulls here and there.
To add onto what TiC said. I was burning quite a bit of oil before my engine failed (seized ring). I had to get my heads at least refreshed and cleaned, but decided to just get them rebuilt for the extra bit of cash. I had ALOT of build up on the exhaust side, I mean ALOT.
yetogetanrs2 is offline   Reply With Quote
Old 12-27-2012, 11:22 AM   #9
oldandslowjim
Member#: 259570
Default clearance
to turn in concepts do you really mean .003+ rod clearance or was that a typo or did i read it wrong
oldandslowjim is offline   Reply With Quote
Old 12-27-2012, 11:36 AM   #10
kakarot09
Member#: 182375
08 Sti
Wrbm
I think they really meant to say .002 and that it was bigger than the mains. Not mains + .002. They don't need to be that loose.
kakarot09 is offline   Reply With Quote
Old 12-27-2012, 11:38 AM   #11
kakarot09
Member#: 182375
08 Sti
Wrbm
TIC it's interesting that you say .0014-.0015 top ring gap. Would you be okay with that for road racing 400whp?
Old 12-27-2012, 12:53 PM   #12
Turn in Concepts
Member#: 93646
Many Track Records
Nope. I would go bigger for road racing.
Given what he's doing, and it's the occasional blast to top power, not all the time at WOT that's what I would go with.
Old 12-27-2012, 12:54 PM   #13
Turn in Concepts
Member#: 93646
Many Track Records
typo. meant to say .0002 bigger than mains. so if mains are .0014 rods are .0016.
Fixing that now.
Old 12-27-2012, 01:57 PM   #14
oldandslowjim
Member#: 259570
Default clearance
thanks for answer tic jim
Old 12-27-2012, 04:23 PM   #15
Turn in Concepts
Member#: 93646
Many Track Records
No prob. Sorry about the typo.
Old 12-27-2012, 07:27 PM   #16
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Quick question... Were those compression numbers cold or hot?
Old 12-27-2012, 08:26 PM   #17
scootarida1
Member#: 154534
2005 Forester XT
Borg Warner S261
Those numbers were hot.
Old 01-04-2013, 04:48 PM   #18
scootarida1
Member#: 154534
2005 Forester XT
Borg Warner S261
Well just an update, this thread is becoming a build thread. I have ordered a bunch of parts and will have pictures in the next few days.
Old 01-05-2013, 06:36 PM   #19
scootarida1
Member#: 154534
2005 Forester XT
Borg Warner S261
Some goodies came in. I received my pistons and rods. I also received a bunch of measuring tools and a scale to balance out the components. Here is a teaser pictures along with many more as I measure and weigh the items.
Old 01-05-2013, 08:05 PM   #20
scootarida1
Member#: 154534
2005 Forester XT
Borg Warner S261
Measuring and Weighing the pistons using a micrometer good to 0.0001". Its been a while since I did some measuring with a micrometer so I took a bunch of measurements until they were consistent.
Piston 1:
Weight: 397.5 g (picture is lying, re-weighed with the piston skirt facing the same as the others)
Diameter: 3.9237 "
Piston 2:
Weight: 397.7 g
Diameter: 3.9237 "
Piston 3:
Weight: 397.6 g
Diameter: 3.9235 "
Piston 4:
Weight: 397.8 g
Diameter: 3.9237 "
So far the pistons seem fairly well balanced and the diameters are within the tolerances I would accept. I will see how the piston pins weigh out to see if I can balance the pistons closer and bring piston 1 closer to the others.
Old 01-06-2013, 11:52 AM   #21
scootarida1
Member#: 154534
2005 Forester XT
Borg Warner S261
Did some more weighing today:
Pin 1:
Weight: 131.9 g
Pin 2:
Weight: 132.0 g
Pin 3:
Weight: 131.7 g
Pin 4:
Weight: 131.8 g
All of the rings weighed 26.4g. However I think they will change slightly when I need to gap them so I am not taking them into account for picking the correct combination for balancing.
But it looks like my piston weight issue can be solved. The final combinations of pistons and pins are:
Piston 1---Pin 2
Piston 2---Pin 4
Piston 3---Pin 1
Piston 4---Pin 3
This brings all of the pistons+pins to a weight of 529.5 g.
Old 01-08-2013, 01:12 AM   #22
scootarida1
Member#: 154534
2005 Forester XT
Borg Warner S261
So I am going to be balancing the rods in the next couple of days. I figure I'll balance the big ends and then do the small ends.
Where is everyone removing material on the big ends? The only area that seems feasible is around the sides by the bolts and just following the contour on a belt sander.
Old 01-08-2013, 01:28 AM   #23
808-wrx
Member#: 151703
2002 wrx 6speed son!
I talked to one of the tech reps (at the manley booth) at subiefest and he said it was not a good idea to shave or grind any of there rods. It weakens/takes off the strength coating and causes a weak link. Im not a pro motor builder just thats what the guy said.
Im in your same boat rite now. Just did my leak down and found lots of air coming out of the dipstick and oil fill tube.
808-wrx is offline   Reply With Quote
Old 01-08-2013, 08:47 AM   #24
mboulton
Member#: 174433
Not a pro, but.......
Balances small ends first, then big ends.
mboulton is offline   Reply With Quote
Old 01-08-2013, 10:01 AM   #25
scootarida1
Member#: 154534
2005 Forester XT
Borg Warner S261
okay thanks.
