#1 |
Member#: 322963
Vehicle:04 wrx psm |
Ok so I got a question, I got a 04 wrx with intake/inlet, full 3" tbe, uppipe, grimspeed ebcs, tgv deletes, 3mm phenolic spacers, intercooler and bov and wanted to know when is the best time of the year to tune? I had it tuned back in Florida in August be jester tuning but it was a hot day and now I moved to New York and its freezing and I can tell I need to tune again...
Thanks in advance
#2 |
Member#: 32669
SCIC
Vehicle:2007 FR TS EFR 7670 LINK G4 hybrid STi |
If you set up your temp compensations it shouldn't matter what season it is tuned in. More than anything you probably need a map tweek not a full retune.
#3 |
Member#: 70395
MAIC
It is also kind of hard to get the temp compensations dialed in if the temps are not present. You can guesstimate what you need but that's not the same as having it dialed in. I agree that the whole car doesn't need to be retuned and just simple tweaking of the compensations is all that is needed.
#4 |
Member#: 322963
Cause it feels 'weird' maybe due to such a high altitude and freezing weather compared to flat seal level hot Florida temps...
#5 | |
Member#: 330625
NESIC
Vehicle:2006 WRX WRB |
#6 | |
Member#: 53665
NESIC
Vehicle:2011 STI Stg2 w/EBCS 2012 Tribeca Ltd. |
#7 |
Member#: 51961
RMIC
Vehicle:2005 STi 2012 WRX |
Your numbers will be more impressive in the cold, but that's about it. A good tune should work in any temp at any elevation, if you find that yours has issues in certain conditions then you need to get the necessary compensations tweaked. This is the case regardless of what season you get the baseline tune done in.
#8 | |
Member#: 70395
MAIC
#9 | |
Member#: 59837
SWIC
Vehicle:2004 Spec-C Type RA What MAF? -Speed Density! |
Aftermarket boost solenoids need significantly more temperature compensation than the stock system. Very few tuners spend any time on this and I would doubt even more so in Florida. Out here in the desert where the temperature swings from 30-110°F during the year many professional tuners encourage two maps for the extremes. I rebuilt the compensations for my car but it took a ton of logging every day over the course of the seasons. |
#10 | |
Member#: 274499
NESIC
Vehicle:2007 CGM VF'd WRX 12.9 @ 105mph |
#11 | |
Member#: 330625
NESIC
#12 |
Member#: 237145
SCIC
Vehicle:02 WRX 12 FXT |
Nice ^ point. But things can be linearly approximated like pv=nrt. Can't they. Odes and Pdes should be solved to just algebra.
Btw I'm still in for the answer of which is the best season. |
#13 |
Member#: 330625
NESIC
IMO, it doesnt matter. But I know up here in New England, November and December are the slowest months for dyno shops. Thats when they have the most free time in the shop so you can normally just get whatever time slot you want.
#14 | |
Member#: 53665
NESIC
I have tuned several cars over the last few years. I am a much better tuner now than I was a year ago. I expect to be a better tuner a year from now than I am today, assuming I am still doing this. I am not solving differential equations while I am tuning to figure out what I need to dial in. My experience along with solid technical base allow me to make reasonable and fairly accurate assertions while I am tuning. The rest is just feedback and refinement. The more you do it, the faster you can dial in these numbers. This is what you should be paying for when you're hiring a tuner. Granted, the more unusual your setup is, the more your tuner may actually have to think. But again, how many of these configurations would you really see? Intakes, EWG, meth injection, exhaust, EBCS probably accounts for 95% of customers that walk through the door. Ever wonder how some of these mail-order tuners can do a pretty good job on your car without actually having to touch just by knowing what you have? Amazing. Imagine if you were doing your job at the same pace and performance as you did the day you started. How long would you last? |
#15 | |
Member#: 53665
NESIC
BTW, we both live in a good area for tuning. In the last 12 months, my maps saw IATs between 20F and 140F. That just about covers most scenarios most people will see. Not too shabby. |
#16 | ||
Member#: 70395
MAIC
#17 | |
Member#: 53665
NESIC
I guess we can leave it at that.We are digressing from the original question. I posted my opinion on the season in my previous post. Any thoughts on this? |
#18 |
Member#: 323379
Vehicle:06 WRX |
I disagree with the summer tuning. But that also depends on where your summer is.
If you see drastic climate changes going into winter then I would tune in spring/fall. But this whole conversation is kinda pointless. As said tune anytime. A real tune will work anytime. But to get dialed in the best, tune compensation tables and retune them in the season the compensation it supposed to account for. Or have tunes for the seasons. |
#19 | |
Member#: 330625
NESIC
On a street tune I dont normally feel all that comfortable pushing that close to the edge for it to make that big of a difference. |
#20 | |
Member#: 53665
NESIC
#21 |
Member#: 268354
NESIC
Vehicle:02 WRX 05 LGT Slow Automatics |
If it means anything to anyone, I have found that summer vs. winter tuning wasnt too much different. Very minute differences. I could run most timing when ambients were between 50-80*. When IATs get into the 100's, I have to drop timing and and add fueling, and same in the winter. I believe it has something to do with fuel grade in the winter being slightly different. Or the fact my load swings quite a bit. Again, not huge swings in how the car runs, but enough to make a slight difference. And of course WGDC changes with seasons as well.
My $.02 |
#22 | |
Member#: 53665
NESIC
#23 | |
Member#: 268354
NESIC
![]() I still bet there is a slight difference in fuel quality for different months. How much, that I do not know |
#24 |
Member#: 32669
SCIC
And you're more prone to overboosting in the cooler weather especially if you were tuned in warmer weather.
#25 |
Member#: 155412
NWIC
Vehicle:2004 WRX Wagon PSM |
During the summertime I was seeing engine loads of 2.12 @ 15.47 lbs of boost. As the temps dropped this winter I was seeing loads upward of 2.7 g/rev with slight overboost to above 16lbs. I adj the max WGDC tables for WOT and comp tables and rescaled the timing load axis. My logs are looking better, but I'll need to mess around with the comp tables more. Tune in winter and comp for summer is what it's looking like for me.
