Old 12-27-2012, 04:06 PM   #4301
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Stock vs. hard plastic vs. solid aluminum are definitely different hardnesses but I really don't think they'll make that much difference in those bushings. Even the stock ones have very little give/play. It is nothing like the front/rear shifter bushings. I'll be doing them anyways, but I really doubt they'll have much of an impact. Like maybe short shift is 70%, shifter bushings are 25%, and the other bushings are 5%. I guess we'll see.
The rear bushing can be done with the exhaust and driveshaft in place. I would remove the tranny "H" brace to have a little more room. Getting the bolts in is a bit tough. You have to keep in mind the that the bolts will NOT be going in straight/perpendicular to the bottom of the bushing. They go in slightly angled. I mentioned this to Kartboy, and they just said deal with it. Lol. Works fine once you get it started, but it's very easy to strip out the threads in the car and then you're hosed.
Old 12-27-2012, 04:11 PM   #4302
Jdub.csu
Member#: 283784
2015 MUSTANG GT PP
GUARD
I did that then just tapped them. But I have all the tools for stuff like that. Like my downpipe bolt that was jacked up from the factory.
Jdub.csu is offline   Reply With Quote
Old 12-27-2012, 04:19 PM   #4303
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Yeah, it's kind of a mediocre design, IMO. But I doubt it will change. People have been dealing with it for years, and doing it right would cost more so people would still probably just buy the current ones.
Depending how bad you mess them up you can probably just run a tap through the threads and clean them up. Worst case you'll have to retap a larger size. Not the end of the world, but still a pain.
Old 12-27-2012, 04:21 PM   #4304
Jdub.csu
Member#: 283784
2015 MUSTANG GT PP
GUARD
I agree it is kind of a pain to get them started but once you do it's not bad and like you said it's been this way for years
Old 12-27-2012, 05:14 PM   #4305
brett192
Member#: 274252
2002 WRX Sedan PSM
VF39, EWG & 6 speed
I also agree that those two rear shifter stay bolts are a pain, after a couple hours of swearing at my car, they went in smoothly as soon as I got the angle right and the threads engaged.
brett192 is offline   Reply With Quote
Old 12-27-2012, 05:34 PM   #4306
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Kartboy cited the fact that everyone has copied that design (which they have), so it must be good. Lol. I agree that it's cheap and it gets the job done once it's installed. I definitely think there's room for improvement on the install side of the design. A two piece design with a polymer bonded to a metal base (similar to the stock design, but a harder compound) would probably be best, but it would probably double the cost.
Old 12-27-2012, 06:05 PM   #4307
dcorn
Member#: 107573
2012 WRX hatch
Ice Silver
I ended up stripping one of mine. They were pretty easy to get to honestly, and I would have been done with the front and rear bushings in less than an hour. Then after getting one bolt in and not being able to get the other one in perfectly, I had stripped one of the threads in the body because the effing holes in the bushings weren't far enough apart to line up both bolts. I had to cut notches in the stock bolt and run it in the threads to 'tap' them back out. Then put one bolt in and push the bushing to the side with a pry bar to get the other bolt started and in correctly. I wanted to murder whoever made that bushing (TWM...). Their response was "oh we don't actually make the bushing, guess the tolerances are slightly off, tough toodles".
dcorn is offline   Reply With Quote
Old 12-27-2012, 06:10 PM   #4308
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
It's partly tolerances but mostly because the mounting surface isn't actually flat so it's designed to have some bend/stretch. If it were designed properly the tolerances would be much less of an issue.
Old 12-27-2012, 07:40 PM   #4309
PearlRex11
Member#: 284420
2011 WRX Sedan
This is really good info, I will be trying to put those bolts in by hand until I can feel that they are starting properly. I think I will also attempt that bushing as soon as I gain access to it to try and keep from getting impatient and cross threading it. I appreciate the info
PearlRex11 is offline   Reply With Quote
Old 01-03-2013, 03:35 PM   #4310
SDsubasaurus
Member#: 290249
2011 WRX limited
Glad to see I'm not the lone weenie for struggling with those bolts. Put line in a couple of days ago. The holes line up exactly top the stock ones, so I don't see it being an issue with the bushing itself. Beautiful car by the way xluben. Been creeping around on here for a while, and have learned a lot.
SDsubasaurus is offline   Reply With Quote
Old 01-03-2013, 03:42 PM   #4311
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Yes, the holes are basically in the right spots, they're just not quite the right angle. It's very close though. Once you get them in it's fine, it's just making sure you get them started properly. Here are some photos I took where you can see the very slight difference:
Old 01-03-2013, 03:56 PM   #4312
SDsubasaurus
Member#: 290249
2011 WRX limited
Yeah makes sense. Your pictures and measurements also made me stick to the OEM "sti" short shifter which feels fine now with just the bushings. I'm so used to Honda trannies and the slop in the wrx shifter was driving me nuts. Problem solved though. Thank you.
Old 01-03-2013, 09:02 PM   #4313
PearlRex11
Member#: 284420
2011 WRX Sedan
Those pictures give me a better idea of what I'm dealing with, looks like you have to get the bushing to flex enough to make that angle of the stock bracket. I should be installing the whole kit this Saturday, crossing my fingers for it to go as smooth as possible.
Old 01-03-2013, 09:04 PM   #4314
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
It's really quite easy. Just take your time and don't damage anything. Should only take 15-20 minutes.
Old 01-03-2013, 09:27 PM   #4315
toph
Member#: 78640
14 KTM SuperDuke R
16 Tacoma | 02 STi Wagon
Have you tuned your car with current mods on 93 octane? If so what were the numbers?
toph is offline   Reply With Quote
Old 01-03-2013, 09:59 PM   #4316
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Sorry. I haven't used pump gas in about 2 years. Since I was Stage 2.
I would guess it would do mid to upper 300's.
Old 01-04-2013, 01:16 PM   #4317
Pearldrummer7
Member#: 277514
2012 WRX & 818R
I'm sure this is in here somewhere, but I couldn't find it. Do you have an easy way to flash back to a pump tune in case you're traveling and can't access e85?
Pearldrummer7 is offline   Reply With Quote
Old 01-04-2013, 03:21 PM   #4318
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Did you read the post immediately before yours?
I'm not tuned on pump and I really don't plan on it.
Old 01-04-2013, 03:27 PM   #4319
luan87us
Member#: 335013
2013 Premium WRX 5dr
I know it has been posted thousands of time but how hard is it to install those kartboy shifter bushings? I already have the STS and if I didn't have to take that out I probably wouldn't have mind going under the car to install these bushings.
Old 01-04-2013, 03:29 PM   #4320
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
You don't have to remove the shifter to do the front and rear bushings. They are discussed on this page and the last. They're really quite easy. Just make sure not to cross thread the bolt holes for the rear bushing.
Old 01-04-2013, 03:32 PM   #4321
Pearldrummer7
Member#: 277514
2012 WRX & 818R
Yes, I did. That actually sparked the question. I realize you don't plan on it but I guess that means you're somewhat limited to where you can drive to, right?
Old 01-04-2013, 03:33 PM   #4322
luan87us
Member#: 335013
Hmm so I don't have to remove the shifter inside the car at all? Not sure why I read I have to remove the whole sts assembly to be able to install these bushings.
Old 01-04-2013, 03:41 PM   #4323
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I don't really drive out of state much at all. But most places in the midwest I could plan ahead and make it on E85. But it's really not common that I would go that far, and if I did it would probably be in my wife's car that gets a lot better mileage. I don't have a Tactrix cable to be able to flash my car anyways.
For the front and rear bushings (the ones that make the most difference) you do it all from under the car. The tranny brace and a heat shield need to be removed or partially removed, but other than that it's not much work.
Old 01-04-2013, 04:35 PM   #4324
luan87us
Member#: 335013
how hard is it to remove the tranny brace and the heatshield? Lol
Old 01-04-2013, 04:38 PM   #4325
rkjunior
Member#: 112220
2011 WRX 5DR Premium
the heat shield was a handful of 12mm bolts. not hard at all. i did mine without taking off the tranny brace. wish I did but it's not impossible.
rkjunior is offline   Reply With Quote
xluben's Pictures and Review of the SPT Exhaust for the 2011 WRX 5 Door Hatch xluben Car Part Reviews 26 11-08-2012 07:55 PM
My first post and my first Subaru, a 2011 WRX 5 door in white. Decade240 Newbies & FAQs 25 06-20-2012 02:48 PM
2011 wrx 5 door hatch with Rota 17"x7.5 +48 5x100 wheels? BretCutler Tire & Wheel 4 01-14-2011 09:05 AM
2011 WRX 5 Door Ruz4life General Community 55 10-14-2010 12:37 AM
2011 WRX 5 Door Ruz4life General Community 10 10-04-2010 05:02 PM
