#1 |
Member#: 41618
Vehicle:2008 WRX Hatch wrb |
We have 10 degree F weather here and for some reason the boost onmy WRX is lower ??? (on my previous turbo car it would go higher in cold weather)
I'm running the same stage 1 91 Low wastegate as before, did a reflash, put on a normal wastegate map, atill the same.. all of them gave me a lower boost setpoint of around 10 psi instead of the rock solid 13.1 psi i would see on it during summer.. what gives ?
#2 |
Member#: 72829
W. Canada
Vehicle:2006 HTA68'd wagon Powered by RomRaider |
In the newer cars, boost target drops by quite a bit once temperature drops to 32F and below.
#3 |
Member#: 245218
South East
Vehicle:2013 STI Limited Ice Silver |
IAT Boost Target and IAT WGDC comp tables pull out boost when the intake air temp starts getting below 65F. They get really aggressive at such cold temps as 10F. I would imagine Cobb did not have much ability to tune their OTS maps optimally for such cold temps.
Your choices are to have a protuner tune it, or get ATR and adjust it yourself if you dare. |
#4 |
Member#: 41618
checked it out in accesstuner and it's is that.
and no i won't play with fire...Id need a winter map and a summer map... and in winter having full boost won't change much when there 6 feet of snow everywhere. better to have lower boost in winter than ring lands popping. Last edited by fr0st; 12-26-2012 at 05:31 PM. |
#5 |
Member#: 315961
NWIC
Vehicle:2008 WRX Dark gray metallic |
OP, I was having the same question. Thanks for posting, and finding the answer. I wound up talking to Dom at Maxwell power and he echoed about the same as you just said. What a relief.
#6 | |
Member#: 41618
i went in access tuner and saw that i could disable it but i would need to check afterwards that i don't max out my injectors and run lean.. better off having less boost at -10 or -20 .. don't drive that fast anyways and besides, the 4 wheels spin anyways with 10 psi of boost o snow.. What would i do with the extra HP? ![]() Last edited by fr0st; 12-28-2012 at 05:38 AM. |
#7 |
Member#: 315961
NWIC
Make more noise lol, and be sideways
#8 | |
Member#: 245218
South East
Good point but I'm OCD enough to where I would have to fix the tune. I mean what would you want if you had zombies chasing you in ice cold temps during the winter? I would want that extra 3 PSI! ![]() ![]() |
#9 | |
Member#: 41618
You just need a wagon to carry more stuff like that RPG that's in a wooden crate ![]() |
#10 |
Member#: 245218
South East
