Old 12-27-2012, 10:54 PM   #1
300zxturboftw
Member#: 325461
WRB Rotated 35r
Default Odd low throttle issue
I have a rotated 35r EJ257 and I'm having this intermittent problem...
Cruising with about 10 % throttle the AFR's lean out to where its like there is fuel cut when engine breaking (AEM AFR Gauge Reads ---) but vacuum is still pulling about -10 hhg as well as a loss in power like its missing in 1 or 2 cylinders. If I increase throttle or when rpm's reach around 3k rpm + the AFR gauge comes back to 14.7 and power returns to normal.
This is completely random. Sometimes I will have the issue 1 day and not have it reappear for a week. Sometimes it happens multiple times a day. This is why I'm so stumped on the issue.
Anyone have a similar issue? Battery & alt are pulling correct voltages.
No CEL's, and I've gotten them on spark misfire under heavy boost so I know it exists, but would it go off on light load misses?
300zxturboftw is offline   Reply With Quote
Old 12-28-2012, 02:11 AM   #2
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
Does the car have an aem ecu in it? Either way sounds like possibly a tuning issue.
Old 12-28-2012, 02:26 AM   #3
that or maybe a vac leak in the evap system maybe.....valve opens and ya lean out and *p00f*
Old 12-28-2012, 10:03 AM   #4
300zxturboftw
Member#: 325461
WRB Rotated 35r
I have opensource. I don't think it's a tuning issue because of the spontaneity of the issue. I'll try a smoke test or boost leak down test with the compressor. Just seems too odd for a vac leak too, but who knows.
Old 12-28-2012, 10:11 AM   #5
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
Which makes sense. Next option would be the vacuum leak idea ^.
