#1 |
Member#: 307599
NESIC
Vehicle:2008 WRX 5door SSM |
I know these aren't full RPM range pulls. I've been hearing/feeling an odd noise during light throttle, and only around 2-3500 RPM. Doesnt sound like rod knock, but almost like a heatshield. However I cant find any that are loose. How does this look?
https://docs.google.com/spreadsheet/...k00dUJEZXQtRnc 08 WRX Cobb CB Cobb SF intake Accessport stage 1 +intake 93 cheers, kyle
#2 | |
NASIOC Manufacturer
Member#: 4803
Wide open throttle (WOT) portion of the log is a little short. If you can do so safely, try to get a WOT log in 3rd gear from 2500 RPM on up. But, I would address the fuel trim issue above first before doing any more WOT pulls. You can view the individual fuel trims that make up A/F Learning 1 via the A/F Learning 1 A,B,C,D parameters. Bill |
#3 |
Member#: 307599
NESIC
OK, thank you for looking. Is this something that is caused by gas too? Im running the 93 map, but have been thinking about trying to run 93 in the 91 map. Sorry for the NOOB-ish questions.
cheers, kyle |
#4 | |
NASIOC Manufacturer
Member#: 4803
Bill |
#5 |
Member#: 307599
NESIC
Thank you for the explanation. I'm going to take a look around the intake as well. Just to make sure nothing has fallen off, or anything. Is it ok to drive for now?
cheers, kyle |
#6 | |
NASIOC Manufacturer
Member#: 4803
Bill |
#7 |
Member#: 307599
NESIC
OK, thank you for all your help! Ill try to play around with it.
cheers, kyle |
#8 |
Member#: 307599
NESIC
After a quick look, it looks like the hose clamps on the intake for a few turns loose. Im going to tighten them up, and check everything else. Do you think something that minor would cause that?
cheers, kyle |
#9 | |
NASIOC Manufacturer
Member#: 4803
Bill |
#10 |
Member#: 307599
NESIC
Bill,
I needed to change my air filter, so I cleaned the MAF as well. I had reset the ECU when I did the MAF. This is a log after about 100 miles. Now it seems like there is some knock. Maybe that's because the ecu is still learning? https://docs.google.com/spreadsheet/...U4tWlE2QUkyR0E cheers, kyle |
#11 | |
NASIOC Manufacturer
Member#: 4803
Bill |
#12 |
Member#: 307599
NESIC
Thank you once again. I will run some more gas through it, and take a look at those a/f numbers this weekend. They do look lower, but i've only ran about 100 miles through it since ECU reset.
cheers, kyle |
