Old 12-13-2012, 11:39 PM   #1726
reid-o
Member#: 103631
2004 STI
Originally Posted by Layvon View Post
How hard has this been to try to pin point Anton? I'm asking you cause I know for Dominic it is probably pretty easy but for someone that hasn't don't it before might not be so easy
And for me reid-o I spoke with Dom and I could get the link with the knock block for better knock control / protection or the vipec with integrated knock control for roughly the same price. I opted to go with a little more precision and get the knock block. I'm almost wishing I had bucked up and got the V88. Seems like inputs on the pnp are at a premium or I'm a dumbass.
Good to know. At least I can say I didn't get a vipec because it wasn't available. Heh
Man that add on display thingy looks cool too. I wish I hadn't gone to the link website now.
Old 12-14-2012, 04:28 PM   #1727
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
I had coolant leak on my radiator from drain plug oring, fixed it today and will be doing more pulls, going to send my timing map to dom so he could guide me where should i bump the timing a bit.
Old 12-16-2012, 07:30 PM   #1728
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
after some more pulls / logs i left timing almost same as before, when i raise it i start to hear little ping noises from headphones.
Valve terrain is lout as **** especially on cylinder 3, so i turned gain on 3 about 30% down so it wouldn't **** up my threshold, everything else looks solid to me.
My body was changing oil on his 2011 sti today and showed me interesting test with oil Russians do.
You pour oil in metal spoon and start to heat it up with lighter, and some interesting things came up:
1. Castrol 5W50 started to smoke crazy and started to boil quick and then turned all dark.
2. Schaeffer Supreme 9000 "green stuff" did better was holding up for loner but still smoked bad.
3. Eneos was the best, took long time for it to start boiling and almost dint smoke at all!
This test might sound stupid to you but i trust it more than all the online sponsored tests
Old 12-17-2012, 01:27 PM   #1729
Maxwell Power
Member#: 190729
wanna test some motul for me?
Old 12-17-2012, 01:28 PM   #1730
Maxwell Power
Member#: 190729
stop listening to the other cylinders.
Old 12-17-2012, 02:26 PM   #1731
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
what if others will knock, even with less overall timing?
Old 12-17-2012, 02:31 PM   #1732
Maxwell Power
Member#: 190729
You can't hear them properly anyway.
Do you see a lot of other Subarus with busted #1 or #3 ringlands? Even built motors on the factory ecu usually only show knock in 4 and 2.
it isn't a perfect engine. You can't treat it like it is. If you want to listen to #1 and #3, add a second knock sensor
Old 12-18-2012, 02:05 AM   #1733
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
true that! the best way to find good cylinder noise balance is to run down hill in 2nd gear from 7000 down to 2000!
Old 12-18-2012, 12:55 PM   #1734
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
What the... Lol
Is that how you set the cylinder gain?
Old 12-18-2012, 02:39 PM   #1735
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
that's what I did to find how loud is valve terrain on each cylinder
Old 12-18-2012, 02:43 PM   #1736
alcoolaid
Member#: 134949
'07 SWP STi
Why cant I free rev from 2k to 7k slowly
Old 12-18-2012, 04:06 PM   #1737
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
more engine load
Old 12-19-2012, 03:04 AM   #1738
alcoolaid
Member#: 134949
'07 SWP STi
Why do you need engine load to listen to the valvetrain
Old 12-19-2012, 12:42 PM   #1739
Maxwell Power
Member#: 190729
load keeps the pistons firmly against the walls and keeps them from rattling around causing extra noise.
Old 12-19-2012, 01:04 PM   #1740
alcoolaid
Member#: 134949
'07 SWP STi
Ahh gotcha
Old 12-19-2012, 01:57 PM   #1741
3MI Racing
Member#: 200987
I gotta say, I like the improvised 'spintron'!!
Old 12-19-2012, 02:54 PM   #1742
CTSparky
Member#: 282204
2011 5 Door STi
Plasma Blue Pearl
I used some eneos in my engine and I loved the results.
I was using the 5w-30 oil. I did have to top off, but otherwise the moly count was very high. The last 2 reports were with eneos.
I want to go back to it as well.
oil analysis 2012-09-24 by CTSparky, on Flickr
CTSparky is online now   Reply With Quote
Old 12-19-2012, 08:23 PM   #1743
induction addiction
Member#: 340643
Originally Posted by godforbid67 View Post
Yeah, defiantly not the cams. I wouldnt even consider 272's "big". I am running 280's my self but a smaller bolt on turbo.
Maybe its just the dyno?
Does it spool the same on the street Bariga?
Either way 500 wheel is 500 wheel
Chris
Correct me if i'm wrong, but the main reason for spool/high RPM on a long rod motor is that the piston will sit at top dead center longer which equals more explosion and less load/angle on the engine bearing making them safer and more efficient at high RPMs.
induction addiction is offline   Reply With Quote
Old 12-19-2012, 09:24 PM   #1744
Layvon
Member#: 195711
STi 04/05/06/07
I font know the right answer for sure but for your second post I think you are on track to do well here. Welcome!
Old 12-19-2012, 10:56 PM   #1745
induction addiction
Member#: 340643
Thanks! If there's anyway shape or form I can help out anyone on here I will try.
Old 12-26-2012, 11:05 AM   #1746
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
I'd PM 3MI/homeadeWRX or maxwell power on this. There are many things that go into it that I don't fully understand but if my understanding is correct the piston acceleration from TDC to BDC is different as is the dwell time at each extreme, and less piston side loading which equals less wear.
Old 12-26-2012, 11:17 AM   #1747
kellygnsd
Member#: 32669
LINK G4 hybrid STi
Anton,
Are you using idle ignition control to help with your idle? Closed loop or open loop E-throttle idle control?
I have the open loop setup pretty good but wanted to try ignition idle control to see if I can get a more stable idle below 1000 rpm. My 272 non-AVCS cams are real finicky below 1000 rpm.
Old 12-26-2012, 12:24 PM   #1748
Maxwell Power
Member#: 190729
Originally Posted by kellygnsd View Post
Anton,
I recommend it.
Old 12-28-2012, 02:35 PM   #1749
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
yeah its on, helps a bit!
not a fan of closeloop fuel control at idle, makes AFR go up and down in wave form.
Old 12-28-2012, 03:25 PM   #1750
Maxwell Power
Member#: 190729
then you have to adjust the gain at low rpm.
Maxwell Power Tuned, 2.35L GT35R 537whp and 9k rpm, 4K rpm power band Maxwell Power Proven Power Bragging 634 06-11-2016 02:34 AM
Maxwell Power Services aka GetaDomTune AwaySooner Vendor Reviews 7 03-11-2010 03:54 PM
+1 for Dom/Maxwell Power Jeff54 Vancouver Impreza Club Forum -- VIC 22 09-02-2009 02:22 PM
My new Maxwell Power Services engine is almost in !!! leonbmx North West Impreza Club Forum -- NWIC 13 03-23-2009 10:28 AM
