#1726 | |
Member#: 103631
Vehicle:2004 STI Black |
Man that add on display thingy looks cool too. I wish I hadn't gone to the link website now.
#1727 |
Member#: 179846
NWIC
Vehicle:07 STi MPS Build EFR 7670 TS |
I had coolant leak on my radiator from drain plug oring, fixed it today and will be doing more pulls, going to send my timing map to dom so he could guide me where should i bump the timing a bit.
#1728 |
Member#: 179846
NWIC
after some more pulls / logs i left timing almost same as before, when i raise it i start to hear little ping noises from headphones.
Valve terrain is lout as **** especially on cylinder 3, so i turned gain on 3 about 30% down so it wouldn't **** up my threshold, everything else looks solid to me. My body was changing oil on his 2011 sti today and showed me interesting test with oil Russians do. You pour oil in metal spoon and start to heat it up with lighter, and some interesting things came up: 1. Castrol 5W50 started to smoke crazy and started to boil quick and then turned all dark. 2. Schaeffer Supreme 9000 "green stuff" did better was holding up for loner but still smoked bad. 3. Eneos was the best, took long time for it to start boiling and almost dint smoke at all! This test might sound stupid to you but i trust it more than all the online sponsored tests ![]() Last edited by Bariga; 12-16-2012 at 08:24 PM. |
#1729 |
Member#: 190729
NWIC
wanna test some motul for me?
#1730 | |
Member#: 190729
NWIC
#1731 |
Member#: 179846
NWIC
what if others will knock, even with less overall timing?
#1732 |
Member#: 190729
NWIC
You can't hear them properly anyway.
Do you see a lot of other Subarus with busted #1 or #3 ringlands? Even built motors on the factory ecu usually only show knock in 4 and 2. it isn't a perfect engine. You can't treat it like it is. If you want to listen to #1 and #3, add a second knock sensor |
#1733 |
Member#: 179846
NWIC
true that! the best way to find good cylinder noise balance is to run down hill in 2nd gear from 7000 down to 2000!
#1734 |
Member#: 134949
VIC
Vehicle:'07 SWP STi Twinscroll ViPec Anti-lag |
#1735 |
Member#: 179846
NWIC
that's what I did to find how loud is valve terrain on each cylinder
#1736 |
Member#: 134949
VIC
Why cant I free rev from 2k to 7k slowly
#1737 |
Member#: 179846
NWIC
more engine load
#1738 |
Member#: 134949
VIC
Why do you need engine load to listen to the valvetrain
#1739 |
Member#: 190729
NWIC
load keeps the pistons firmly against the walls and keeps them from rattling around causing extra noise.
#1740 |
Member#: 134949
VIC
Ahh gotcha
#1741 |
Member#: 200987
MAIC
I gotta say, I like the improvised 'spintron'!!
#1742 | |
Member#: 282204
NESIC
Vehicle:2011 5 Door STi Plasma Blue Pearl |
I was using the 5w-30 oil. I did have to top off, but otherwise the moly count was very high. The last 2 reports were with eneos. I want to go back to it as well. ![]() oil analysis 2012-09-24 by CTSparky, on Flickr |
#1743 |
Member#: 340643
South East
Correct me if i'm wrong, but the main reason for spool/high RPM on a long rod motor is that the piston will sit at top dead center longer which equals more explosion and less load/angle on the engine bearing making them safer and more efficient at high RPMs.
#1744 |
Member#: 195711
MWSOC
Vehicle:STi 04/05/06/07 JBP / OBP for now |
I font know the right answer for sure but for your second post I think you are on track to do well here. Welcome!
#1745 |
Member#: 340643
South East
#1746 | |
Member#: 32669
SCIC
Vehicle:2007 FR TS EFR 7670 LINK G4 hybrid STi |
#1747 |
Member#: 32669
SCIC
Anton,
Are you using idle ignition control to help with your idle? Closed loop or open loop E-throttle idle control? I have the open loop setup pretty good but wanted to try ignition idle control to see if I can get a more stable idle below 1000 rpm. My 272 non-AVCS cams are real finicky below 1000 rpm. |
#1748 | |
Member#: 190729
NWIC
#1749 |
Member#: 179846
NWIC
yeah its on, helps a bit!
not a fan of closeloop fuel control at idle, makes AFR go up and down in wave form. |
#1750 |
Member#: 190729
NWIC
| Thread Tools | |
| Display Modes | |
| Maxwell Power Tuned, 2.35L GT35R 537whp and 9k rpm, 4K rpm power band | Maxwell Power | Proven Power Bragging | 563 | 05-16-2012 08:28 PM |
| Maxwell Power Services aka GetaDomTune | AwaySooner | Vendor Reviews | 7 | 03-11-2010 03:54 PM |
| +1 for Dom/Maxwell Power | Jeff54 | Vancouver Impreza Club Forum -- VIC | 22 | 09-02-2009 02:22 PM |
| My new Maxwell Power Services engine is almost in !!! | leonbmx | North West Impreza Club Forum -- NWIC | 13 | 03-23-2009 10:28 AM |
