#1 |
Member#: 130063
Vehicle:2003 WRX Silb |
I'm looking for a adapter plate for a subaru to GM trans. I've tried various search terms on google and have not found any good results
#2 |
Member#: 130063
Or any other RWD Auto trans that won't cost a arm in and a leg to hold 400whp
#3 |
Member#: 252934
Vehicle:99 |
Stock subaru 4-5speed auto will hold that fine.
#4 |
Member#: 252934
Vehicle:99 |
Also try www.v-eight.com. If you can supply some dimensions ed could draw it up for you ready to give to machinist.
#5 |
Member#: 130063
#6 | |
Member#: 130063
Subaru EJ Adapter plate Subaru transmission Adapter and tons of other variants. I wonder if there are any others out there interested in adapter a GM transmission for RWD subaru use. My 1997 EJ257 18g wagon on wastegate was a blast RWD with a welded center diff and welded rear diff. *03 wrx diff. The diff let go few weeks ago so im going nissan |
#7 |
Member#: 252934
Vehicle:99 |
What's makes you say the auto wont? Plenty of people have them and they work fine. Plenty of supercharged ez30/36's make more torque and do it on stock autos.
Doubt you'll find something off the shelf, hence speak to Ed on that site and it can be drawn. |
#8 |
Member#: 130063
I've been looking for the past 5 months for a solution, I'm so tired of breaking transmissions.
I'm looking into having a part fabbed, if anyone is interested in a similar adapter plate pm me... 400$ for a gearbox that can hold 800hp. |
#9 |
Member#: 327710
NESIC
Vehicle:1999 Impreza OBS Green |
unless you have that th400 beefed up it will not hold anywhere near 800hp.. I've owned many chevy's before coming to Subaru and I know it's just not possible without building the trans...
#10 |
Member#: 267815
South East
Vehicle:EVO Woudve been Cheaper!!!!! |
billsautofab.com
Hes got anything you want, and yes....that TH400 will hold a sheetload more than any stock WRX or STi tranny ever will. |
#11 |
Member#: 248431
have you considered an sti 6spd with a rwd spool? they hold 500+whp on awd i would imagine that you would be just fine with only rwd loads on it. also you won't need any adapter plate made.
i understand you want an automatic transmission though. if you are firmly set on that, make some measurments and take those to a machine shop they should be able to CNC a piece for you. you can make sheet metal templates or something to draw measurements from. Last edited by STIll inspired; 11-07-2012 at 05:54 PM. |
#12 |
Member#: 171837
NWIC
Vehicle:1999 2.5 RS Orange-Black |
I've currently got a build that runs 407 whp and 400 tq through a 2004 STi six speed.
#13 |
Member#: 267815
South East
^^^^Sounds like everyone else on here with a STi.
#14 |
Member#: 130063
six speed swap costs to much and I have a feeling i'd break it.
#15 |
Member#: 341870
A dodge 727 can be built to handle that kind of power for cheap. And those trannies are probably more plentiful
#17 |
Member#: 155358
Vehicle:2008 Forester Steel Silver |
old threads but the members are still some what active. PM might get a response.
http://forums.nasioc.com/forums/show....php?t=1881527 http://forums.nasioc.com/forums/show....php?t=1628337 Other possible leads http://www.ultimatesubaru.org/forum/...splay.php?f=28 http://www.ultimatesubaru.org/forum/...d.php?t=111709 http://www.transmissionadapters.com/ http://www.advanceadapters.com/ |
| Thread Tools | |
| Display Modes | |
| Subaru to GM transmission adapter plate | 99RSTurbo | Drivetrain | 49 | 10-28-2012 10:24 PM |
| Need to locate Burton 3D to 4x adapter plate | QuickSilverSTi | Off-Topic | 0 | 10-11-2004 10:37 AM |
| trim rings and adapter plates. | IA Performance | Car Audio, Video & Security | 40 | 01-15-2003 10:18 AM |
| DMS Golds: Need help with GDA>GC8 adapter plate | mca | Brakes, Steering & Suspension | 15 | 06-12-2002 07:07 PM |
| Blow off valve adapter plate | wrxblitz | Factory 2.0L Turbo Powertrain | 12 | 11-16-2001 05:44 PM |
