Welcome to the North American Subaru Impreza Owners Club Wednesday August 31, 2016
Old 12-28-2012, 03:51 PM   #1
RicersWetDream
Member#: 245581
2009 WRX
2014 Forester XT
Exclamation WRX Won't Crank After Clutch Swap
Well I just got done pulling the engine in and out to swap the clutch on my 09 WRX. I got everything back together, and when I went to turn it on for the first time I get nothing..... Doesn't even try to start.
It also has the temp gauge pegged all the way hot, which I've always thought was an ECU thing. Everything else works electrically, just no crank.
I put my multimeter across the starter and it's getting power, but for some reason it won't crank at all.
Any help is appreciated, I'm going through and double check for any grounds or connectors I missed.
The first thing I did was pull the battery out of the car, and it was the last thing to go back in. The fuse for the starter is also fine.
RicersWetDream is offline   Reply With Quote
Old 12-28-2012, 04:15 PM   #2
LIChuck
Member#: 266122
2007 WRX Limited
UGM
Check for a bad ground. If you missed reinstalling the ground strap to the block, that would do it.
LIChuck is offline   Reply With Quote
Old 12-28-2012, 04:39 PM   #3
RicersWetDream
Member#: 245581
2009 WRX
2014 Forester XT
Herr derr moment of the whole process... I plugged the main engine harness in but didn't snap the connector. Moved the latch and started right up.
I can honestly say that was the only thing I messed up during the whole process. Engine-pull clutch job solo in 17 hours.
Thanks for the input though!
Old 12-28-2012, 10:28 PM   #4
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
2.0 hours on a lift..
Old 12-28-2012, 11:21 PM   #5
Juice66
Member#: 340526
2004 WRX STi
HTA86
Pulled the motor to replace clutch?!!?!?
Juice66 is offline   Reply With Quote
Old 12-28-2012, 11:31 PM   #6
thatderekguy
Member#: 301501
black
I solo pulled my tranny and replaced clutch with no lift In 5 hours. Getting the tranny matched back to the motor was a pita.
thatderekguy is offline   Reply With Quote
Old 12-29-2012, 02:08 AM   #7
SenorDucK
Member#: 327511
13' WRX 6 Speed
11sec VF52 EL-EWG-E85
This. lol
SenorDucK is offline   Reply With Quote
Old 12-29-2012, 02:17 AM   #8
darksc00by
Member#: 102140
Originally Posted by SenorDucK View Post
This. lol
It is easier to pull the motor than to pull the transmission if you don't have a lift.
darksc00by is offline   Reply With Quote
Old 12-29-2012, 02:25 AM   #9
SenorDucK
Member#: 327511
13' WRX 6 Speed
I suppose that's subjective..
Old 12-29-2012, 10:55 AM   #10
darksc00by
Member#: 102140
I guess. Maybe I meant to say that many people would prefer to work on their car standing up than laying on their back.
Old 12-29-2012, 10:55 AM   #11
RicersWetDream
Member#: 245581
2009 WRX
2014 Forester XT
Yeah no way I'm dropping the trans to do the clutch. Some guys are able to get enough separation by dropping the drive shaft and pulling the trans back, but I had a few other things to do on the engine while it was out.
Plus I'd much rather wrestle an engine back in from up top than lay on my cold concrete garage floor trying to get a trans lined up by myself.
Old 01-14-2013, 01:29 AM   #12
5050GRIP
Member#: 343562
Default I did a few clutch changes in cars including subarus
I have seen all sorts of other jobs performed by DIYfers, check to make sure your clutch was proerly lined up in addition to your bell housing the motor. If is misaligned it will not crank and may damage your main output shaft.
5050GRIP is offline   Reply With Quote
Old 01-14-2013, 07:34 AM   #13
sense of nature
Member#: 112759
2002 STi Mikey Tuned
SexyRP
It sure is!
Thats the easiest way how it's done IMO
Old 01-14-2013, 07:42 AM   #14
RicersWetDream
Member#: 245581
2009 WRX
2014 Forester XT
See post #3.
New clutch already has almost 1k miles on it
