Old 04-11-2011, 02:44 PM   #176
Harley2390
Member#: 275378
Default I'm Having Issues with Loading my Stock Ecu Map
NEED HELP DAILY DRIVER IN NEED OF INFO!!!! lol
Alright so i have Romraider downloaded with ECU def's downloaded. I also have Logger Def's Downloaded with ECU Flash, I am driving a 2008 Subaru Legacy Gt 2.5, i connected the test wires and what seems to be a log with ecu flash. It saved as "Read Image.hex" Now i am trying to open it up in romraider but is not allowing me to, nor can i open it back up in ecuflash. I sent it to a buddy Via Mediafire and he couldnt open it in his either. Is there something like some software im missing thats not allowing me to open it or log???
i have Tactrix openport 2.0 and i have the logger def's configured into romraider. just having the issue of why cant i open my test log that i did with ecuflash
this is what it showed that i logged:
http://www.mediafire.com/?6xdhyhlr6ddx5sd
Call me: 407-451-9981
Harley
_____Or Post_____
Harley2390 is offline   Reply With Quote
Old 07-23-2011, 03:29 PM   #177
BuGS
Member#: 81353
06 STI
Blackness...
BUMP for update with VAGCOM cable info. I think that would help a lot of ppl.
BuGS is offline   Reply With Quote
Old 07-31-2011, 09:52 AM   #178
daddyphatsax304
Member#: 248075
02' WRX Wagon
Harley
_____Or Post_____
I realize this was a few months ago and i would hope you figured this out by now but maybe this will help some others as well...you are trying to open ur map w/ romraider. ECUflash gets and sends maps to your ECU...you did not log anything...in order to log you have to run romraider set your parameters.. WITHOUT green plugs connected and log some data...this gives you the necessary input to then do some calculations and make changes the map you downloaded via ECUflash.
log files are in .csv
maps are in .hex
green plugs are only required to send and recieve maps
daddyphatsax304 is offline   Reply With Quote
Old 05-20-2012, 01:21 AM   #179
JohnnyWas
Member#: 91010
2002 Subaru WRX
OG Blueberry
Great thread! Looking forward to take a crack at all this tomorrow.
JohnnyWas is offline   Reply With Quote
Old 08-24-2012, 09:35 PM   #180
jdiwatts
Member#: 302836
2006 WRX
Did it and now I truly love driving my 06 WRX wagon!
jdiwatts is offline   Reply With Quote
Old 09-01-2012, 05:59 PM   #181
JDM_J03
Member#: 258435
06 STi
Hey guys,
Having a bit of trouble running the program. I have followed the steps very closely.. The problem I am having is everytime I open the RomRaider Logger it keeps telling me: "logger definition not configured". I have unzipped the file and resaved the .xml file to the romraider directory. I have also did the whole settings-> Logger definition location->selected the file.. But it KEEPS bringing up the window: "logger definition not configured" this is very irritating and annoying. can anyone please help?!
JDM_J03 is offline   Reply With Quote
Old 09-02-2012, 09:29 AM   #182
ckswanecamp
Member#: 299861
2002 Impreza WRX
Metallic Silver
Is it the "cars" file stated in the error window? Because my RomRaider says that every time i open my logger. But all the parameters are listed on the left side of the app, and it works perfectly.
ckswanecamp is offline   Reply With Quote
Old 10-29-2012, 12:47 PM   #183
frederik
Member#: 64405
2003 WRX Sedan
WRB - Cobb Stg 2
Originally Posted by Tea cups View Post
If it is Accessport ver 1 cable, then you can log with RomRaider if you get a serial to USB converter (Belkin is a good one). However, that is it. You will not be able to flash your ECU (i.e. tune).
Is this still true? Until now when I (rarely) had to log something I was logging with EcuExplorer and my serial Accessport V1 cable, and I want to do the switch to RomRaider. No need to flash, only logging.
Edit: nevermind. I thought you were saying romraider absolutely needs usb connection or something. I have a serial port on my work laptop (for older applications and stuff) so I'm all good.
frederik is offline   Reply With Quote
Old 12-18-2012, 12:25 PM   #184
AWDkidRS
Member#: 254133
2001 RS *EJ205*
I know this has probally been covered in here a million times but i just dont have time to go through the pages but is the opensource tactrix cable the only cable that works? The regular vagcom ones dont? Sorry and thanks
AWDkidRS is offline   Reply With Quote
Old 12-18-2012, 12:44 PM   #185
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
Wow... You suck, seriously.
You don't have time to research, but you found enough of it to post this pile of crap.
Good job. I'm sure someone will be along to spoon feed you shortly. #damnlazykids
Old 12-18-2012, 01:51 PM   #186
cosseywrx
Member#: 276443
2005 2.1 stroker WRX
Hash tag **** is childish.
And yes you should read the whole thread. Or search key words
cosseywrx is offline   Reply With Quote
Old 12-19-2012, 10:47 AM   #187
AWDkidRS
Member#: 254133
2001 RS *EJ205*
I was at work but read through and found out thanks for your "lame" help though.
Old 12-19-2012, 11:00 AM   #188
ozunadel
Member#: 313772
1992 Skyline r32
work in progress
is there any to convert the .hex file you get from ecuflash,so i can send it via email to my tuner. once i leave ecuflash i cannot seem to find the file at all.
i dont think this was discussed in any of these 8 pages
ozunadel is offline   Reply With Quote
Old 12-19-2012, 11:38 AM   #189
cosseywrx
Member#: 276443
Try and do a search for it? Make sure the folder its suppose to be in that in the properties no folders are being hidden. Make sure you actually saved it to the computer. To channge the file just edit it
Old 12-19-2012, 02:03 PM   #190
ozunadel
Member#: 313772
1992 Skyline r32
work in progress
ive done all of the above but the .hex file seems to vanish but when i do a search it shows up but i cant do anything with it
Old 12-29-2012, 06:42 AM   #191
my0six
Member#: 341826
2005 WRX MY06
Light Bluish Silver
Okay, so I don't know if this is the right place to write this, but can anybody tell me; would it be considered acceptable for a person with no tuning experience to go out and buy a tactrix and start learning how to use it?
I have an MY06 and the air pump has died. After weeks of speaking to my mechanic mates, dealerships and looking through these and other Subaru forums, I've decided to remove the pump and delete the CEL codes...
I've already wasted $50 having a tuner that didn't listen to me "clear" my CEL codes 4 times in a row, and then tell me after I said "I specifically asked for the codes GONE and the thing REFLASHED" that he couldn't do that, but I still had to pay for what he had done... And another tuner has quoted me a few hundred to do this...
If I can get the tools to do a job myself for cheaper than to have the service performed, I always try to do it myself.
So when I found out I could get the Tactrix OpenPort 2.0 for less than the cost of the tune (reminder, this is just some CEL codes for a secondary air pump delete, not a performance tune or anything), I decided that I'd look into doing it myself.
Anyway, I tend to waffle on a bit, but basically, what I'm asking is this:
Is this thread for qualified tuners? Or are there people out there teaching themselves to do this stuff??
my0six is offline   Reply With Quote
Old 12-29-2012, 09:32 AM   #192
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
IMHO, your best bet would be to buy a Cobb Accessport. You can quickly and easily remove the CEL codes, and learn how to tune with its software. Once you have a good handle on what you are doing, you can sell the AP... Recoup your money and tune open source if you want to.
You will get much better support from the guys at Cobb, you will be less likely to brick your ECU, and don't need to keep a laptop in the car to gather datalogs. (I know the OP2.0 can too... but you can't view data without a pc.)
Old 12-29-2012, 10:32 AM   #193
my0six
Member#: 341826
2005 WRX MY06
Light Bluish Silver
Thanks bro, but no Cobb in Australia
Not sure why, but that's the word...
...and everybody's heard...
Old 12-29-2012, 02:07 PM   #194
frederik
Member#: 64405
2003 WRX Sedan
WRB - Cobb Stg 2
I think it is perfectly fine to equip with the cable even if you dont intent to actually tune or change anything. It is a great maintenance and diagnosing tool.
If you look at romraider forum you will find detailed explanation of what to install, how it works, and what to log. There is also different explanations depending if you want to only datalog or actually tune. I read the part for datalog and diagnosing and I thing it is a great tool to be able to do the basic. Then when you have an issue and someone asks if you have a datalog you can say yes and post the information and get better help.
Resetting the ecu will clear the check engine light, but if your issue is still there (which is likely if you didnt do any change to the car) the check engine will come back.
Old 12-31-2012, 12:57 AM   #195
hunterjm
Member#: 314744
As Black94Snake mentioned, the OpenPort 2.0 has a micro SD slot for standalone logging. I created an online tool that will take a RomRaider profile.xml file and generate the required logcfg.txt from it. It makes it really easy to take your RomRaider profiles and create a config for standalone logging without having to match addresses from the definitions yourself. It also supports calculated parameters. I built it for myself, but figured I would polish it up and put it out there in case it would be useful for anyone else.
http://subaru.hunterjm.com/
If it gains enough traction (or upon recommendation) I can create a separate post, but I thought it related pretty well to this FAQ. To learn more about what you need to do to get your Tactrix configured for standalone logging, visit: http://forums.openecu.org/viewtopic.php?f=57&t=4319
hunterjm is offline   Reply With Quote
Old 01-02-2013, 06:34 PM   #196
my0six
Member#: 341826
2005 WRX MY06
Light Bluish Silver
Okay, having a little trouble guys, I'm trying to get "The latest RomRaider ECU definitions", as instructed on RomRaider's site, but in their list on the below page, I cannot find my car. It's an ADM (aussie) MY06 WRX
http://www.romraider.com/forum/viewtopic.php?t=360
I am sure RomRaider supports my car, as I can see it in black and white on their "supported ECUs" page, where it states my year as having two models (06 A8DH200O (MT)*, A8DH200U (MT)*)...
My question is, does anybody know where I might find the specific RomRaider ECU definitions for my car??
Or should I be posting this on the RomRaider site?
Old 01-02-2013, 08:45 PM   #197
quazimoto
Member#: 70395
The definitions will work.........
quazimoto is online now   Reply With Quote
Old 01-03-2013, 05:38 AM   #198
my0six
Member#: 341826
2005 WRX MY06
Light Bluish Silver
Thanks very much. Does anybody have any idea WHERE I might find the definitions for an AMD MY06 WRX?
Old 01-03-2013, 08:09 AM   #199
quazimoto
Member#: 70395
Yeah,right here............
http://www.romraider.com/forum/topic360.html
The definitions are bundled together. If your ECU is shown as supported then the definition is there. The ones listed on the definition page are new ones that have been added..........
Old 01-03-2013, 08:55 AM   #200
my0six
Member#: 341826
2005 WRX MY06
Light Bluish Silver
Okay, sorry Quaz, I didn't mean to be painful... I TOTALLY misread something and was looking for a download... Hahah, nice emoticon
romraider/ecuflash? weaponstroop Open Source Reflashes 8 10-21-2008 10:04 AM
reading logs - FAQ or getting started guide? jmc9809 Newbies & FAQs 2 08-05-2005 06:40 PM
I want to get started racing! Where to start? wayne_rx Motorsports 27 12-23-2004 03:00 AM
Auto-Xing Newbe, How to get started? Ed_RS New England Impreza Club Forum -- NESIC 7 01-31-2001 11:34 AM
how to get started jjp New England Impreza Club Forum -- NESIC 5 11-09-2000 06:26 AM
