Old 12-27-2012, 12:08 AM   #1
smurf juice
Member#: 338563
2009 wrx
wrb
Default newbie
I have a 2009 wrx and just installed my cat-less dp and now my car studders at 3,000 rpm any one know why? help much appreciated!
mods: cobb SF intake, invidia cat-less dp, q300 cbe, and im running a cobb stage 2 sf 93 octane map
smurf juice is offline   Reply With Quote
Old 12-27-2012, 12:26 AM   #2
Decipher
Member#: 262760
2011 WRX Hatch Limtd
No codes? Hope you're running the map for that intake. That may have something to do with it.
Decipher is offline   Reply With Quote
Old 12-27-2012, 12:31 AM   #3
smurf juice
Member#: 338563
2009 wrx
wrb
no codes its the stage 2 93 sf map i think its the right one imo?
Old 12-27-2012, 10:17 AM   #4
Decipher
Member#: 262760
My bad. Was a little tired and missed that you said "SF" map. So, does it studder under load, while you're maintaining speed but at 3000 rpm, or when you rev it to 3000 with no load? Need a little more info.
Old 12-27-2012, 11:12 AM   #5
smurf juice
Member#: 338563
2009 wrx
wrb
Under full throttle it will rev through, but under light acelliration it will studder at 3,000. And won't go higher its a very fast studder. It also just threw a code. My ap says no codes found, and I can't get to a auto zone for 3 days. So I won't know untill Sunday what the code is
Old 12-27-2012, 02:48 PM   #6
GrumpyPitbull
Member#: 313311
2012 WRX 5 Door
Plasma Blue
No, it is not the right one. You are running catless on a Cobb tune ... And their tunes are for catted DP's. Which is why you are now getting a CEL.
Old 12-27-2012, 03:14 PM   #7
RoadKillDMD
Member#: 284792
2011 STI
Plasma Blue Pearl
BS... Just stop right there. Without a code, you can't say for sure. Cobb maps compensate for a less efficient catalytic system anyway, so you won't necessarily throw a code for that. Plenty of people are running catless DPs with Cobb stage 2 with absolutely no problems.
OP, the map you are running is the correct map, as long as you fill up with 93 octane. The only thing you need to worry about with your map is the possibility of boost creep. Take a couple of data logs to make sure thinks are running okay. Take some logs too while trying to replicate the 'stuttering' problem. Maybe you can see if anything funky is going on there too.
Old 12-27-2012, 05:21 PM   #8
roadtrip1098
Member#: 185688
2006 STi
WR Blue
Post a datalog of the problem happening and we'll get her figured out.
roadtrip1098 is offline   Reply With Quote
Old 12-27-2012, 06:46 PM   #9
cassinelli23
Member#: 198655
2011 STI
im not sure what year this started but i think its in 2008. they changed the way the fuel system recirculates and has kind of a economy mode that kicks in when driving lightly. on a stock car you dont notice it. you just need a tune that supplies more fuel at those rpms and it will smooth things out or buy a fuel pressure regulator.
cassinelli23 is offline   Reply With Quote
Old 12-27-2012, 09:25 PM   #10
smurf juice
Member#: 338563
2009 wrx
wrb
Thanks for all the help guys I will post a data log soon as I get off.
Old 12-27-2012, 11:09 PM   #11
smurf juice
Member#: 338563
2009 wrx
wrb
Time A/F Learning 1 (%) Boost (PSI) Calculated Load (g/rev) Dyn. Adv. Mult (DAM) Dynamic Adv. () Feedback Knock () Fine Knock Learn () Ignition Timing () MAF Volt. (V) MAF (g/s) RPM (RPM) TD Boost Error (PSI) Throttle Pos. (%) Wastegate Duty (%)
0 0 -7.74 0.49 1 0 0 0 32.5 2.16 29.24 3020 1.76 15.69 40.39
0.34 0 -5.63 0.69 1 1.97 0 0 32 2.3 36.31 3032 1.91 18.43 40.39
0.66 0 -4.61 0.77 1 2.75 0 0 36 2.38 39.83 3058 1.84 19.22 40.39
1 0 0.88 1.25 1 4.79 0 0 25 2.88 72.45 3081 16.85 100 61.18
1.32 0 3.29 1.55 1 5.78 0 0 21 2.92 87.88 3165 14.4 100 61.57
1.66 0 6.21 1.81 1 5.95 0 0 18 3.22 103.18 3277 11.63 100 61.57
1.98 0 9.71 2.13 1 6.07 0 0 15 3.3 127.8 3393 8.12 100 61.96
2.32 0 13.63 2.51 1 5.97 0 0 13 3.5 152.23 3512 3.64 100 62.35
2.64 0 16.06 2.76 1 5.98 0 0 13.5 3.58 168.71 3674 1.56 100 60
2.98 0 15.74 2.71 1 5.98 0 0 12.5 3.6 170.78 3790 2.03 100 63.14
3.32 0 15.85 2.7 1 5.98 0 0 13.5 3.68 178.46 3975 1.87 100 63.14
3.64 0 16.16 2.71 1 5.98 0 0 13 3.72 184.52 4138 1.68 100 63.53
3.98 0 16.06 2.74 1 5.98 0 0 12.5 3.76 193.02 4306 1.75 100 63.92
4.3 0 15.88 2.75 1 5.98 0 0 12 3.82 201.55 4443 1.94 100 64.31
4.64 0 15.83 2.75 1 5.98 0 0 12 3.84 212.32 4601 1.96 100 64.31
4.96 0 15.78 2.72 1 5.98 0 0 12.5 3.88 213.62 4715 2.1 100 64.31
5.3 0 15.78 2.72 1 5.98 0 0 12.5 3.92 219.35 4909 1.87 100 64.71
5.62 0 15.59 2.69 1 5.98 0 0 12.5 3.94 223.77 5023 1.8 100 64.71
5.96 0 15.58 2.66 1 5.98 0 0 13 3.94 230.1 5150 1.58 100 64.71
6.28 0 15.46 2.63 1 5.98 0 0 13.5 3.96 233.65 5301 1.52 100 64.71
6.62 0 15.34 2.62 1 5.98 0 0 13.5 3.98 238.72 5480 1.43 100 65.1
6.94 0 15.29 2.6 1 5.98 0 0 14 4.02 244.74 5575 1.07 100 65.1
7.28 0 14.93 2.57 1 5.98 0 0 14.5 4.02 244.74 5686 1.16 100 65.49
7.6 0 14.78 2.55 1 5.98 0 0 14.5 4.04 250.25 5873 1.09 100 65.1
7.94 0 14.59 2.52 1 5.95 0 0 14.5 4.04 249.25 5945 1.15 100 64.31
8.26 0 14.2 2.48 1 5.69 0 0 15.5 4.04 251.25 6110 1.38 100 63.53
8.6 0 13.87 2.45 1 5.46 0 0 15.5 4.06 252.25 6193 1.32 100 63.53
8.92 0 13.64 2.41 1 5.05 0 0 16 4.06 254.18 6346 1.56 100 63.53
9.26 0 13.54 2.38 1 4.92 0 0 16.5 4.08 258.5 6450 1.35 100 64.31
9.58 0 -9.06 0.31 1 0 0 0 3 1.88 17.25 6074 -0.94 10.2 0
9.92 0 -10.66 0.17 1 0 0 0 3 1.78 13.99 5169 0.24 9.41 0
10.24 0 -11.15 0.17 1 0 0 0 3 1.7 11.48 4433 0.37 8.24 0
10.58 0 -11.03 0.16 1 0 0 0 23 1.56 8.41 3735 0.44 6.67 0
10.9 0 -10.87 0.14 1 0 0 0 23 1.46 6.94 3176 0.28 5.49 0
11.24 0.78 -11.08 0.13 1 0 0 0 23 1.32 4.62 2637 0.5 4.31 0
11.56 0.78 -11.38 0.13 1 0 0 0 23 1.32 4.71 2138 0.63 3.53 0
11.9 0.78 -10.92 0.15 1 0 0 0 19 1.34 4.96 1646 -0.23 3.92 0
12.22 0.78 -10.24 0.21 1 0 0 0 11 1.36 5.29 1223 -0.39 3.92 0
12.56 0.78 -8.97 0.29 1 0 0 0 11 1.32 4.68 849 -1.47 3.92 0
12.88 0.78 -8.87 0.29 1 0 0 0 11 1.3 4.69 1056 -1.62 3.92 0
13.22 0.78 -9.27 0.27 1 0 0 0 11 1.26 3.92 1078 -1.25 3.53 0
13.54 0.78 -9.36 0.26 1 0 0 0 11 1.32 4.65 1026 -1.17 3.92 0
13.88 0.78 -9.11 0.29 1 0 0 0 11 1.28 4.39 964 -1.41 3.92 0
14.2 0.78 -9.08 0.28 1 0 0 0 11 1.3 4.39 986 -1.42 3.53 0
14.54 0.78 -9.29 0.27 1 0 0 0 10.5 1.26 4.22 1020 -1.23 3.53 0
14.86 0.78 -9.36 0.26 1 0 0 0 10.5 1.28 4.19 1030 -1.16 3.53 0
15.2 0.78 -9.46 0.26 1 0 0 0 10.5 1.3 4.36 1020 -1.05 3.53 0
15.52 0.78 -9.41 0.26 1 0 0 0 11 1.26 3.84 1006 -1.11 3.53 0
15.86 0.78 -9.44 0.26 1 0 0 0 11 1.28 4.09 986 -1.05 3.14 0
16.18 0.78 -9.37 0.26 1 0 0 0 11 1.26 4.13 955 -1.15 3.53 0
16.52 0.78 -9.34 0.26 1 0 0 0 11 1.26 4.06 979 -1.16 3.14 0
16.84 0.78 -9.35 0.26 1 0 0 0 11 1.28 4.28 975 -1.15 3.14 0
17.18 0.78 -9.42 0.26 1 0 0 0 11 1.24 4.06 960 -1.07 3.14 0
17.5 0.78 -9.44 0.26 1 0 0 0 11 1.26 3.92 947 -1.04 3.14 0
17.84 0.78 -9.44 0.26 1 0 0 0 11 1.24 3.82 922 -1.02 3.14 0
18.16 0.78 -9.4 0.26 1 0 0 0 11 1.26 3.92 904 -1.07 3.14 0
18.5 0.78 -9.35 0.27 1 0 0 0 11 1.26 4 877 -1.1 3.14 0
18.82 0.78 -9.3 0.28 1 0 0 0 11 1.22 3.87 852 -1.14 2.75 0
19.16 0.78 -9.3 0.27 1 0 0 0 11 1.26 3.74 874 -1.15 2.75 0
19.48 0.78 -9.35 0.27 1 0 0 0 11 1.24 3.66 843 -1.09 2.75 0
19.82 0.78 -9.26 0.27 1 0 0 0 11 1.22 3.69 823 -1.18 2.75 0
20.14 0.78 -9.24 0.27 1 0 0 0 11 1.2 3.59 824 -1.17 2.75 0
20.48 0.78 -9.47 0.26 1 0 0 0 11 1.24 3.39 888 -0.99 3.14 0
20.82 0.78 -9.39 0.27 1 0 0 0 11 1.2 3.44 804 -1.02 2.35 0
21.14 0.78 -9.04 0.29 1 0 0 0 11 1.26 4.19 741 -1.43 3.14 0
21.48 0.78 -9.08 0.29 1 0 0 0 11 1.14 3.07 828 -1.28 1.96 0
21.8 0.78 -9.89 0.21 1 0 0 0 23.5 1.22 3.69 1324 -0.88 3.14 0
22.14 0 -10.91 0.15 1 0 0 0 7.5 1.5 7.5 2765 1.32 6.67 40.39
22.46 0 -10.63 0.19 1 0 0 0 34 1.76 10.79 3188 1.69 11.37 40
22.8 0 -3.79 0.76 1 2.41 0 0 34.5 2.5 47.22 3364 5.04 23.92 40
23.14 0 -7.54 0.53 1 0 0 0 40.5 1.76 13.21 3309 -3.03 8.63 0
23.46 0 -10.29 0.21 1 0 0 0 20.5 1.68 11.25 3351 -0.3 8.24 0
23.8 0 -10.24 0.2 1 0 0 0 16 1.66 10.9 3239 -0.36 8.24 0
24.12 0 -10.22 0.2 1 0 0 0 23 1.68 11.02 3201 -0.39 8.24 0
24.46 0 -10.24 0.2 1 0 0 0 23.5 1.66 10.78 3148 -0.37 7.84 0
24.78 0 -10.24 0.2 1 0 0 0 23.5 1.64 10.09 3093 -0.36 7.84 0
25.12 0 -10.23 0.2 1 0 0 0 23.5 1.64 7.7 3023 -0.39 7.45 0
25.44 0 -10.24 0.2 1 0 0 0 23.5 1.64 10.04 2987 -0.36 7.45 0
25.78 0 -10.27 0.2 1 0 0 0 23.5 1.64 9.9 2914 -0.32 7.45 0
26.1 0 -10.34 0.2 1 0 0 0 23.5 1.62 9.51 2864 -0.26 7.06 0
26.44 0 -10.38 0.19 1 0 0 0 23.5 1.6 9.41 2834 -0.23 7.06 0
26.76 0 -10.42 0.2 1 0 0 0 23.5 1.6 9.46 2771 -0.18 7.06 0
27.1 0 -10.41 0.2 1 0 0 0 23.5 1.58 9.02 2719 -0.19 6.67 0
27.42 0 -10.41 0.2 1 0 0 0 23.5 1.6 9.31 2672 -0.19 6.67 0
27.76 0 -10.41 0.2 1 0 0 0 23.5 1.6 9.16 2637 -0.19 6.67 0
28.08 0 -10.27 0.23 1 0 0 0 23.5 1.54 8.19 2169 -0.48 5.88 0
28.42 0 -10.05 0.23 1 0 0 0 19.5 1.44 6.39 1657 -1.1 4.71 0
28.74 0.78 -10.01 0.24 1 0 0 0 12 1.3 4.28 1147 -0.54 3.14 0
29.08 0.78 -9.32 0.28 1 0 0 0 12 1.24 4 882 -1.13 2.75 0
29.4 0.78 -9.95 0.23 1 0 0 0 12 1.18 2.99 1073 -0.51 2.35 0
29.74 0.78 -10.58 0.17 1 0 0 0 21.5 1.3 4.36 1592 -0.49 3.92 0
30.06 0 -10.52 0.18 1 0 0 0 24 1.52 7.8 2305 -0.08 6.27 0
30.4 0 -11.12 0.16 1 0 0 0 24 1.66 10.37 3711 1.62 8.24 0
30.72 0 -10.63 0.2 1 0 0 0 24 1.66 10.78 3476 1.14 8.24 0
31.06 0 -10.48 0.21 1 0 0 0 34 1.68 11.08 3221 1.1 8.24 40
31.38 0 -10.44 0.22 1 0 0 0 45 1.72 12.01 3220 1.56 8.63 40
31.72 0 -9.68 0.28 1 0 0 0 45 1.86 16.29 3282 2.03 10.98 40
32.04 0 -9.53 0.31 1 0 0 0 45 1.82 17.87 3284 1.45 9.8 40
32.38 0 -10.17 0.25 1 0 0 0 43.5 1.7 12.11 3284 0.82 8.63 0
32.7 0 -10.48 0.2 1 0 0 0 30.5 1.66 10.55 3184 0.98 7.84 0
33.04 0 -10.5 0.2 1 0 0 0 24 1.66 10.72 3154 0.98 7.84 0
33.36 0 -10.23 0.2 1 0 0 0 29 1.72 12.23 3070 2.19 9.8 40.39
33.7 0 -8.87 0.35 1 0 0 0 38 1.94 19.06 3054 2.76 11.76 40.39
34.02 0 -7.92 0.48 1 0 0 0 35 2.06 24.75 3148 2.59 13.73 40.39
34.36 0 -7.81 0.5 1 0 0 0 31.5 2.1 26.87 3221 3.03 14.51 40.39
34.68 0 -6.41 0.61 1 0.99 0 0 33.5 2.32 37.03 3348 5.25 18.82 40
35.02 0 -3.24 0.88 1 2.91 0 0 35.5 2.62 54.89 3546 8.82 24.71 49.8
35.34 0 -1.15 1.09 1 2.93 0 0 33 2.86 76.76 3863 22.67 31.37 50.2
35.68 0 3.83 1.54 1 4.92 0 0 24 3.38 129.85 4287 23.92 61.57 63.14
36 0 12.87 2.47 1 5.98 0 0 14 3.98 237.22 5164 3.02 100 64.71
36.34 0 13.66 2.51 1 5.6 0 0 16 4.08 256.36 6247 1.67 100 61.96
36.66 0 12.54 2.32 1 4.92 0 0 18.5 4.08 257.2 6676 1.96 87.06 64.31
37 0 -9.66 0.25 1 0 0 0 43.5 2.88 69.57 6130 20.44 49.41 60.78
37.32 0 8.1 1.85 1 5.62 0 0 19.5 3.54 153.95 4353 9.59 100 64.31
37.66 0 15.55 2.63 1 5.98 0 0 12.5 3.82 203.33 4392 2.27 100 62.75
37.98 0 15.95 2.75 1 5.98 0 0 13 3.88 214.73 4722 2.01 100 64.71
38.32 0 15.42 2.68 1 5.98 0 0 13 3.94 229.09 5080 1.78 100 64.71
38.64 0 15.16 2.63 1 5.98 0 0 14 3.98 238.72 5386 1.56 100 64.71
38.98 0 14.82 2.57 1 5.98 0 0 15 4.02 243.68 5742 1.44 100 65.1
39.3 0 14.47 2.53 1 5.96 0 0 15.5 4.04 248.69 6006 1.23 100 64.31
39.64 0 13.63 2.44 1 5.36 0 0 16.5 4.06 251.54 6247 1.57 100 63.53
39.96 0 13.24 2.38 1 4.92 0 0 17.5 4.08 256.36 6550 1.65 100 64.31
40.3 0 -3.1 0.75 1 0.15 0 0 3.5 2.34 39 6533 -2.7 10.98 0
40.62 0 2.04 0.97 1 3.57 0 0 13.5 3.52 152.48 5684 12.83 100 64.71
40.96 0 -5.73 0.72 1 0 0 0 16.5 2.2 31.19 6909 -2.66 10.2 0
41.28 0 -10.33 0.18 1 0 0 0 4.5 1.92 20.44 5862 -0.01 10.98 0
41.62 0 -10.62 0.2 1 0 0 0 4.5 1.9 17.09 5025 0.11 10.2 0
41.96 0 -10.84 0.2 1 0 0 0 23.5 1.78 13.92 4232 0.13 9.02 0
42.28 0 -10.23 0.21 1 0 0 0 23.5 1.74 12.5 3543 -0.45 8.63 0
42.62 0 -9.02 0.31 1 0 0 0 19 1.96 19.91 3621 0.05 12.16 39.22
42.94 0 -10.11 0.34 1 0 0 0 31.5 2 22.11 4347 1 16.86 38.43
43.28 0 -1.34 1.08 1 2.16 0 0 29 3.06 93.28 4446 18.79 49.8 54.9
43.6 0 6.46 1.8 1 5.6 0 0 21 3.54 154.68 4476 11.36 100 64.31
43.94 0 15.55 2.7 1 5.98 0 0 12 3.9 221.36 4600 2.51 100 60.78
44.26 0 16.19 2.77 1 5.98 0 0 12.5 3.88 215.83 4750 1.88 100 63.92
44.6 0 15.53 2.7 1 5.98 0 0 12.5 3.9 221.91 4915 1.93 100 64.71
44.92 0 15.95 2.74 1 5.98 0 0 12.5 3.94 228.49 5022 1.35 100 64.71
45.26 0 15.72 2.7 1 5.98 0 0 13 3.96 232.2 5153 1.39 100 64.71
45.58 0 15.57 2.68 1 5.98 0 0 13.5 3.96 235.21 5285 1.37 100 64.71
45.92 0 -4.57 0.76 1 0 0 0 16 2.18 29.34 5226 -5.85 10.59 0
46.24 0 -10.13 0.23 1 0 0 0 5 1.84 15.86 4594 -0.68 9.8 0
46.58 0 -10.3 0.21 1 0 0 0 3.5 1.76 13.21 3918 -0.34 8.63 0
46.9 0 -10.07 0.2 1 0 0 0 23.5 1.68 10.96 3300 -0.57 7.84 0
47.24 0 -10.22 0.19 1 0 0 0 23.5 1.58 8.87 2782 -0.36 6.27 0
47.56 0 -10.58 0.18 1 0 0 0 23.5 1.46 6.61 2274 -0.09 5.1 0
47.9 0.78 -10.56 0.18 1 0 0 0 22 1.32 4.83 1808 -0.46 3.92 0
48.22 0.78 -10.38 0.18 1 0 0 0 14 1.36 5.28 1348 -0.44 3.92 0
48.56 0.78 -9.44 0.26 1 0 0 0 11.5 1.32 4.81 921 -1.29 4.31 0
48.88 0.78 -8.83 0.29 1 0 0 0 11.5 1.32 4.8 1121 -1.63 3.92 0
49.22 0.78 -9.45 0.27 1 0 0 0 11.5 1.32 4.87 1158 -1.13 3.92 0
49.54 0.78 -9.55 0.27 1 0 0 0 11.5 1.34 5.09 1149 -1.04 3.92 0
49.88 0.78 -9.46 0.27 1 0 0 0 11 1.3 4.84 1102 -1.1 3.92 0
50.2 0.78 -9.39 0.28 1 0 0 0 11 1.34 5.02 1082 -1.17 3.92 0
50.54 0.78 -9.4 0.28 1 0 0 0 11 1.34 4.9 1093 -1.16 3.92 0
50.88 0.78 -9.59 0.26 1 0 0 0 11 1.3 4.51 1120 -0.98 3.92 0
51.2 0.78 -9.69 0.26 1 0 0 0 11 1.34 4.74 1110 -0.87 3.53 0
51.54 0.78 -9.69 0.26 1 0 0 0 11 1.3 4.45 1087 -0.86 3.53 0
51.86 0.78 -9.58 0.26 1 0 0 0 11 1.3 4.59 1006 -0.93 3.53 0
52.2 0.78 -9.36 0.28 1 0 0 0 11 1.3 4.59 978 -1.14 3.53 0
52.52 0.78 -9.35 0.28 1 0 0 0 11 1.3 4.45 1005 -1.16 3.53 0
52.86 0.78 -9.52 0.26 1 0 0 0 11 1.24 4.08 1024 -0.99 3.14 0
53.18 0.78 -9.59 0.26 1 0 0 0 11 1.28 4.28 1015 -0.92 3.14 0
53.52 0.78 -9.54 0.26 1 0 0 0 11 1.26 4.13 986 -0.96 3.14 0
53.84 0.78 -9.54 0.26 1 0 0 0 11 1.26 4.11 988 -0.96 3.14 0
54.18 0.78 -9.54 0.26 1 0 0 0 11 1.28 4.22 979 -0.96 3.14 0
54.5 0.78 -9.54 0.26 1 0 0 0 11 1.28 4.11 977 -0.96 3.14 0
54.84 0.78 -9.6 0.25 1 0 0 0 11 1.26 3.97 987 -0.86 3.14 0
55.16 0.78 -9.63 0.25 1 0 0 0 11 1.24 3.97 952 -0.87 3.14 0
55.5 0.78 -9.6 0.25 1 0 0 0 11 1.26 3.89 932 -0.89 3.14 0
55.82 0.78 -9.52 0.26 1 0 0 0 11 1.24 3.84 891 -0.97 3.14 0
56.16 0.78 -9.42 0.27 1 0 0 0 11.5 1.24 3.84 878 -1.03 2.75 0
56.48 0.78 -9.49 0.26 1 0 0 0 11.5 1.24 3.71 899 -0.97 2.75 0
56.82 0.78 -9.49 0.26 1 0 0 0 11.5 1.26 3.82 888 -0.97 2.75 0
57.14 0.78 -9.49 0.26 1 0 0 0 11.5 1.26 3.9 890 -0.97 2.75 0
57.48 0.78 -9.55 0.26 1 0 0 0 11.5 1.24 3.71 911 -0.88 2.75 0
57.8 0.78 -9.65 0.25 1 0 0 0 11.5 1.2 3.51 880 -0.81 2.75 0
58.14 0.78 -9.54 0.26 1 0 0 0 11.5 1.24 3.69 841 -0.89 2.75 0
58.46 0.78 -9.41 0.27 1 0 0 0 11.5 1.24 3.64 818 -1.01 2.75 0
58.8 0.78 -9.42 0.26 1 0 0 0 11.5 1.22 3.39 833 -1.03 2.35 0
59.12 0.78 -9.72 0.24 1 0 0 0 11.5 1.18 3.25 899 -0.69 2.35 0
59.46 0.78 -9.87 0.23 1 0 0 0 11.5 1.18 3.3 903 -0.59 2.75 0
59.78 0.78 -9.88 0.23 1 0 0 0 11.5 1.2 3.4 853 -0.57 2.75 0
60.12 0.78 -9.73 0.24 1 0 0 0 11.5 1.2 3.4 801 -0.68 2.35 0
60.44 0.78 -9.59 0.25 1 0 0 0 11.5 1.2 3.2 779 -0.82 2.35 0
60.78 0.78 -9.43 0.26 1 0 0 0 4 1.28 3.77 748 0.79 3.53 0
61.1 0.78 -9.62 0.24 1 0 0 0 20 1.38 5.59 1510 0.56 5.1 34.51
61.44 0 -9.72 0.25 1 0 0 0 32.5 1.64 10.2 1912 1.09 8.24 45.1
61.76 0 -8.34 0.36 1 0 0 0 35.5 1.92 18.2 1887 3.62 14.12 45.88
62.1 0 -3.82 0.77 1 1.39 0 0 22.5 2.16 29.07 1883 1.92 17.65 68.63
62.42 0 -2.52 0.93 1 2 0 0 20 2.2 31.78 1875 1.84 19.61 68.24
62.76 0 -1.86 1 1 2.82 0 0 21.5 2.22 32.16 1903 1.51 20 68.24
63.08 0 -1.75 1.01 1 3.57 0 0 24 2.22 32.49 1909 1.27 19.61 68.24
63.42 0 -1.61 1.02 1 4.29 0 0 27 2.22 32.58 1911 0.84 19.22 68.24
63.74 0 -2.13 0.96 1 4 0 0 29.5 2.2 31.29 1929 0.59 17.65 68.24
64.08 0 -2.27 0.93 1 3.82 0 0 31 2.16 29.91 1935 0.27 16.86 67.84
64.4 0 -4.82 0.69 1 2.03 0 0 40 1.76 13.62 1928 -2.76 9.02 57.65
64.74 0 -6.47 0.45 1 0 0 0 43.5 1.76 13.47 1945 -1.18 9.41 56.47
65.06 0 -4.78 0.64 1 1.35 0 0 39.5 2.08 26.44 1955 0.96 14.51 57.25
65.4 0 -4.62 0.65 1 1.48 0 0 41 1.86 16.75 1941 -2.45 9.8 57.25
65.72 0 -6.22 0.48 1 0 0 0 44 1.82 15.61 1954 -0.78 10.2 58.04
66.06 0 -5.76 0.53 1 0.17 0 0 43.5 1.92 18.48 1959 -0.18 11.37 60
66.38 0 -5.12 0.58 1 0.63 0 0 41 1.94 19.91 1949 -0.55 12.16 59.61
66.72 0 -4.53 0.65 1 1.14 0 0 33.5 2.14 28.06 1957 1.63 16.86 65.49
67.04 0 -2.68 0.87 1 2.1 0 0 25 2.16 29.71 1976 0.63 17.25 67.45
67.38 0 -2.66 0.92 1 2.04 0 0 22.5 2.2 31.34 1988 0.61 17.65 67.06
67.7 0 -2.62 0.94 1 2.11 0 0 22.5 2.16 29.59 1999 -0.57 15.69 65.88
68.04 0 -3.06 0.88 1 1.91 0 0 23.5 2.18 30.22 2016 0.22 16.47 66.67
68.36 0 -4.39 0.78 1 1.33 0 0 26 1.9 17.93 2015 -2.14 10.59 67.06
68.7 0 -7.18 0.46 1 0 0 0 36.5 1.74 13.03 2023 -0.65 9.41 66.27
69.02 0 -7.47 0.42 1 0 0 0 36 1.78 14.34 2027 -0.28 9.41 66.67
69.36 0 -7.74 0.42 1 0 0 0 36 1.78 14.28 2013 -0.01 9.41 66.67
69.68 0 -8.15 0.39 1 0 0 0 35.5 1.62 12.59 2009 -1.6 6.27 67.06
70.02 0 -9.9 0.26 1 0 0 0 34 1.5 7.72 2006 -0.51 5.88 66.67
70.36 0 -10.23 0.22 1 0 0 0 29.5 1.48 7.02 1995 -0.53 5.49 0
70.7 0 -10.27 0.22 1 0 0 0 24 1.5 7.37 2001 -0.54 5.49 0
71.02 0 -10.3 0.21 1 0 0 0 24 1.5 7.46 1997 -0.47 5.49 0
71.36 0 -10.19 0.21 1 0 0 0 24 1.48 7.29 1992 -0.63 5.49 0
71.68 0 -10.12 0.21 1 0 0 0 24 1.48 7.16 1968 -0.73 5.49 0
72.02 0 -10.14 0.22 1 0 0 0 24 1.48 7.16 1924 -0.72 5.49 0
72.34 0 -10.19 0.21 1 0 0 0 24 1.44 6.57 1897 -0.71 5.1 0
72.68 0 -10.19 0.21 1 0 0 0 24 1.46 6.61 1854 -0.74 5.1 0
73 0 -10.19 0.21 1 0 0 0 24 1.42 6.2 1798 -0.8 4.71 0
73.34 0 -10.24 0.21 1 0 0 0 23 1.42 6.09 1760 -0.8 4.71 0
73.66 0 -10.28 0.21 1 0 0 0 22 1.4 5.89 1710 -0.8 4.31 0
74 0 -10.31 0.21 1 0 0 0 21 1.38 5.6 1654 -0.8 4.31 0
74.32 0.78 -10.44 0.2 1 0 0 0 20 1.36 5.28 1606 -0.73 3.92 0
74.66 0.78 -10.48 0.19 1 0 0 0 20 1.36 5.09 1551 -0.65 3.92 0
74.98 0.78 -10.53 0.19 1 0 0 0 19 1.32 4.93 1515 -0.52 3.53 0
75.32 0.78 -10.53 0.19 1 0 0 0 18.5 1.32 4.59 1460 -0.45 3.53 0
75.64 0.78 -10.53 0.18 1 0 0 0 18 1.28 4.25 1415 -0.38 3.14 0
75.98 0.78 -10.53 0.18 1 0 0 0 17 1.28 4.13 1386 -0.32 3.14 0
76.3 0.78 -10.51 0.18 1 0 0 0 15 1.26 4.05 1323 -0.29 3.14 0
76.64 0.78 -10.37 0.2 1 0 0 0 12 1.24 3.56 967 -0.11 2.35 0
76.96 0.78 -10.1 0.22 1 0 0 0 12 1.2 3.3 936 -0.39 2.35 0
77.3 0.78 -10.17 0.21 1 0 0 0 12 1.2 3.2 880 -0.28 2.35 0
77.62 0.78 -9.96 0.23 1 0 0 0 12 1.2 3.35 821 -0.48 2.35 0
77.96 0.78 -9.77 0.24 1 0 0 0 12 1.18 3.18 762 -0.67 2.35 0
78.28 0.78 -9.56 0.26 1 0 0 0 12 1.16 3.3 687 -0.9 2.35 0
78.62 0.78 -9.2 0.29 1 0 0 0 12 1.22 3.47 685 -1.21 2.75 0
78.94 0.78 -9.14 0.29 1 0 0 0 12 1.22 3.49 779 -1.27 2.75 0
79.28 0.78 -9.5 0.26 1 0 0 0 12 1.16 3.2 893 -0.95 2.35 0
79.6 0.78 -9.99 0.23 1 0 0 0 12 1.18 3.11 938 -0.49 2.35 0
79.94 0.78 -10.12 0.22 1 0 0 0 12 1.18 3.35 881 -0.34 2.35 0
80.26 0.78 -9.94 0.23 1 0 0 0 12 1.2 3.39 824 -0.5 2.35 0
80.6 0.78 -9.78 0.24 1 0 0 0 12 1.16 3.18 787 -0.64 2.35 0
80.94 0.78 -9.71 0.25 1 0 0 0 12 1.2 3.23 767 -0.7 2.35 0
81.26 0.78 -9.71 0.25 1 0 0 0 12 1.18 3.18 783 -0.7 1.96 0
81.6 0.78 -9.76 0.24 1 0 0 0 12 1.14 3.09 806 -0.66 1.96 0
81.92 0.78 -9.82 0.24 1 0 0 0 13.5 1.16 3.07 783 -0.58 1.96 0
82.26 0.78 -9.79 0.24 1 0 0 0 13.5 1.18 3.09 766 -0.62 1.96 0
82.58 0.78 -9.74 0.24 1 0 0 0 15.5 1.16 3.09 770 -0.67 1.96 0
82.92 0.78 -9.79 0.24 1 0 0 0 13.5 1.16 3 783 -0.62 1.96 0
83.24 0.78 -9.8 0.23 1 0 0 0 13.5 1.14 2.97 782 -0.6 1.96 0
83.58 0.78 -9.83 0.23 1 0 0 0 14 1.18 2.98 778 -0.58 1.96 0
83.9 0.78 -9.85 0.23 1 0 0 0 14 1.14 2.93 778 -0.56 1.96 0
84.24 0.78 -9.85 0.23 1 0 0 0 14 1.14 2.93 762 -0.57 1.96 0
84.56 0.78 -9.82 0.24 1 0 0 0 14 1.18 3 753 -0.59 1.96 0
84.9 0.78 -9.82 0.24 1 0 0 0 13.5 1.14 2.91 750 -0.58 1.96 0
85.22 0.78 -9.79 0.23 1 0 0 0 13 1.14 2.89 758 -0.62 1.96 0
85.56 0.78 -9.78 0.23 1 0 0 0 14.5 1.16 2.91 747 -0.63 1.96 0
85.88 0.78 -9.77 0.24 1 0 0 0 14 1.18 2.91 738 -0.64 1.96 0
86.22 0.78 -9.76 0.24 1 0 0 0 14.5 1.18 2.95 736 -0.65 1.96 0
86.56 0.78 -9.73 0.24 1 0 0 0 13.5 1.16 3.04 743 -0.68 1.96 0
86.88 0.78 -9.73 0.24 1 0 0 0 12 1.14 2.95 746 -0.68 1.96 0
87.22 0.78 -9.75 0.24 1 0 0 0 11 1.18 3.02 761 -0.65 1.96 0
87.54 0.78 -9.78 0.24 1 0 0 0 12.5 1.14 2.97 748 -0.63 1.96 0
87.88 0.78 -9.77 0.24 1 0 0 0 13 1.14 2.97 739 -0.65 1.96 0
88.2 0.78 -9.72 0.25 1 0 0 0 14.5 1.12 2.98 719 -0.69 1.96 0
88.54 0.78 -9.61 0.25 1 0 0 0 15.5 1.14 3.04 698 -0.82 1.96 0
88.86 0.78 -9.55 0.26 1 0 0 0 15 1.16 3.14 699 -0.87 1.96 0
89.2 0.78 -9.52 0.26 1 0 0 0 13.5 1.18 3.18 715 -0.88 2.35 0
89.52 0.78 -9.49 0.27 1 0 0 0 10.5 1.16 3.23 747 -0.92 2.35 0
89.86 0.78 -9.53 0.27 1 0 0 0 12 1.16 3.23 738 -0.87 2.35 0
90.18 0.78 -9.51 0.27 1 0 0 0 12.5 1.18 3.25 744 -0.9 2.35 0
90.52 0.78 -9.51 0.27 1 0 0 0 12 1.22 3.27 754 -0.9 2.35 0
90.84 0.78 -9.53 0.27 1 0 0 0 12 1.18 3.27 756 -0.88 2.35 0
91.18 0.78 -9.53 0.27 1 0 0 0 10.5 1.16 3.27 762 -0.87 2.35 0
91.5 0.78 -9.57 0.26 1 0 0 0 12.5 1.2 3.23 756 -0.84 2.35 0
91.84 0.78 -9.56 0.27 1 0 0 0 13 1.2 3.27 744 -0.85 2.35 0
92.16 0.78 -9.57 0.26 1 0 0 0 12.5 1.16 3.23 752 -0.84 2.35 0
92.5 0.78 -9.58 0.26 1 0 0 0 14 1.2 3.23 759 -0.82 2.35 0
92.84 0.78 -9.58 0.26 1 0 0 0 13 1.2 3.23 760 -0.82 2.35 0
93.16 0.78 -9.58 0.26 1 0 0 0 10.5 1.18 3.23 761 -0.82 2.35 0
93.5 0.78 -9.63 0.26 1 0 0 0 11.5 1.2 3.18 759 -0.77 1.96 0
93.82 0.78 -9.67 0.26 1 0 0 0 12 1.16 3.18 756 -0.74 1.96 0
94.16 0.78 -9.65 0.26 1 0 0 0 13.5 1.18 3.18 758 -0.75 2.35 0
94.48 0.78 -9.63 0.26 1 0 0 0 13.5 1.2 3.18 751 -0.77 2.35 0
94.82 0.78 -9.64 0.26 1 0 0 0 13.5 1.16 3.14 756 -0.76 1.96 0
95.14 0.78 -9.62 0.26 1 0 0 0 13.5 1.16 3.18 746 -0.79 2.35 0
95.48 0.78 -9.59 0.26 1 0 0 0 13 1.18 3.23 741 -0.81 2.35 0
95.8 0.78 -9.61 0.26 1 0 0 0 12 1.2 3.18 748 -0.8 2.35 0
96.14 0.78 -9.62 0.26 1 0 0 0 13.5 1.18 3.18 736 -0.77 1.96 0
96.46 0.78 -9.58 0.26 1 0 0 0 13 1.16 3.18 732 -0.82 2.35 0
96.8 0.78 -9.58 0.26 1 0 0 0 13 1.16 3.18 729 -0.82 2.35 0
97.12 0.78 -9.58 0.26 1 0 0 0 12 1.18 3.23 743 -0.82 2.35 0
97.46 0.78 -9.56 0.26 1 0 0 0 13 1.2 3.23 742 -0.85 2.35 0
97.78 0.78 -9.58 0.26 1 0 0 0 10.5 1.18 3.23 768 -0.82 2.35 0
98.12 0.78 -9.62 0.26 1 0 0 0 11.5 1.16 3.21 759 -0.79 2.35 0
98.44 0.78 -9.63 0.26 1 0 0 0 11.5 1.2 3.18 763 -0.77 2.35 0
98.78 0.78 -9.65 0.26 1 0 0 0 13 1.18 3.18 755 -0.75 2.35 0
99.1 0.78 -9.6 0.26 1 0 0 0 14.5 1.16 3.23 727 -0.81 2.35 0
99.44 0.78 -9.57 0.26 1 0 0 0 13 1.16 3.21 738 -0.85 2.35 0
99.76 0.78 -9.58 0.26 1 0 0 0 13 1.2 3.21 756 -0.82 2.35 0
100.1 0.78 -9.6 0.26 1 0 0 0 12.5 1.2 3.18 762 -0.8 2.35 0
100.42 0.78 -9.61 0.26 1 0 0 0 13.5 1.16 3.23 760 -0.77 2.35 0
100.76 0.78 -9.6 0.26 1 0 0 0 13 1.18 3.18 760 -0.79 2.35 0
101.08 0.78 -9.63 0.26 1 0 0 0 12 1.2 3.18 741 -0.77 2.35 0
101.4
Old 12-27-2012, 11:11 PM   #12
smurf juice
Member#: 338563
2009 wrx
wrb
okay idk if that is what yall are looking for? let me know if its the right numbers or not.
Old 12-27-2012, 11:49 PM   #13
Coreycarlile911
Member#: 282614
2006 Wrx sti
Black pearl
There are some really silly posts back on here, some people should just keep to themselfs when they have no idea what they are talking bout.
I'm gonna say you have a vacuum leak somewhere but can't assume without a code or car to look at. I say take it to nearby tuner and they can fix it all up for ya. Btw you need to send your datalogs to google docs and then post it up here and make sure to change the privacy setting so it's open for everyone to see.
Coreycarlile911 is offline   Reply With Quote
Old 12-28-2012, 12:04 AM   #14
GrumpyPitbull
Member#: 313311
2012 WRX 5 Door
Plasma Blue
OK, lets see if his CEL ends up being the rear O2 sensor.
Old 12-28-2012, 12:05 AM   #15
smurf juice
Member#: 338563
2009 wrx
wrb
okay thanks man
Old 12-28-2012, 12:07 AM   #16
smurf juice
Member#: 338563
2009 wrx
wrb
btw the check engine light went back off. idk why
Old 12-28-2012, 01:52 AM   #17
Coreycarlile911
Member#: 282614
2006 Wrx sti
Black pearl
My car had an injector wire come loose when the car would be above 3000rpms and would pop a cel for sec then pop off. I highly dought it's that but might just make sure all the injector wires are nice and snug in place.
Old 12-28-2012, 02:34 AM   #18
scx89
Member#: 269388
2011 Impreza WRX
obp
you sure it's the CEL light?
does it say CEL? have you checked the owners manual?
Upload your data onto google docs spreadsheet and make it public so we can see it.
WOT in 3rd gear and only select that part of the data to show us.
add in as much detail to your experience as well
scx89 is offline   Reply With Quote
Old 12-28-2012, 12:34 PM   #19
smurf juice
Member#: 338563
2009 wrx
wrb
Okay will do all post it tonight when I get home thanks for all the help
Old 12-28-2012, 04:16 PM   #20
nappingcub
Member#: 222725
2006 WRX
Actually if you bothered to read the notes on Cobb's documentation of the maps, Grumpypitbull is correct that the stage 2 maps are not meant to be run with a catless downpipe. Whether it is causing the CEL, can't tell until it's pulled. Maybe you should take your own advice and stop right there?
https://static.cobbtuning.com/cobbtu...-13+Intake.pdf
Straight from that PDF file.
** The Stage2 maps were developed using a COBB Tuning turbo-back exhaust system with a high-flow catalytic
converter. An equivalent turbo-back exhaust system could also be used. If a lesser flowing turbo-back exhaust
system is used then boost targets may not be achievable. These maps are NOT designed to be used with an
aftermarket race downpipe that does not have a catalytic converter (i.e. catless). Doing so greatly increases the
chance for boost spikes and boost creep.
To the op: pretty much anything can be going on, so everyone is just guessing at this point without a CEL code.
nappingcub is offline   Reply With Quote
Old 12-29-2012, 12:16 AM   #21
smurf juice
Member#: 338563
2009 wrx
wrb
0 -8.59 9.13 3.05 1 5.98 0 0 14 3.52 155.04 2790 8.07 100 50.2
0.34 -10.94 11.91 3.69 1 5.98 0 0 12.5 3.82 193.44 2938 4.82 100 49.8
0.68 -10.94 13.32 3.89 1 5.98 0 0 12.5 3.86 209.96 3101 3.66 100 49.41
1 -10.94 12.89 3.9 1 5.98 0 0 12.5 3.9 215.28 3241 3.73 100 49.02
1.34 -10.94 13.06 3.9 1 5.98 0 0 13 3.9 224.67 3386 3.92 100 49.02
1.66 -10.94 13.06 3.9 1 5.98 0 0 14 3.96 234.21 3491 3.9 100 48.63
2 -10.94 13.32 3.9 1 5.98 0 0 14 4 242.23 3632 3.67 100 48.63
2.32 -10.94 12.92 3.85 1 5.98 0 0 14.5 4 242.23 3819 3.95 100 48.63
2.66 -10.94 12.81 3.8 1 5.98 0 0 14.5 4.04 249.19 3924 4.11 100 48.24
2.98 -10.94 12.65 3.76 1 5.98 0 0 14.5 4.1 259.71 4094 4.27 100 48.24
3.32 -10.94 12.61 3.74 1 5.98 0 0 14 4.12 263.91 4237 4.32 100 48.24
3.64 -10.94 12.56 3.67 1 5.98 0 0 14 4.16 269.78 4409 4.39 100 48.24
3.98 -10.94 12.56 3.61 1 5.98 0 0 14 4.18 274.12 4539 3.97 100 47.84
4.3 -10.94 12.41 3.54 1 5.98 0 0 14.5 4.2 274.08 4701 3.82 100 47.45
4.64 -10.94 12.34 3.49 1 5.98 0 0 14.5 4.2 280.88 4804 3.43 100 46.27
4.96 -10.94 12.11 3.44 1 5.98 0 0 14.5 4.22 283.37 4971 3.28 100 45.49
5.3 -10.94 12.05 3.37 1 5.98 0 0 14.5 4.22 288.17 5104 2.87 100 44.31
5.62 -10.94 11.85 3.32 1 5.98 0 0 14.5 4.24 287.85 5226 2.64 100 43.53
5.96 -10.94 11.69 3.27 1 5.98 0 0 14.5 4.24 290.66 5344 2.45 100 42.35
6.28 -10.94 11.52 3.23 1 5.98 0 0 15 4.26 293.22 5453 2.41 100 41.18
6.62 -10.94 11.27 3.17 1 5.98 0 0 15 4.26 293.46 5595 2.44 100 40
6.94 -10.94 11.01 3.12 1 5.98 0 0 15.5 4.26 294.58 5710 2.36 100 40
7.28 -10.94 10.85 3.08 1 5.98 0 0 16 4.28 297.39 5769 2.58 100 40.39
7.6 -10.94 10.68 3.02 1 5.98 0 0 16.5 4.28 297.7 5941 2.2 100 40.39
7.94 -10.94 10.51 2.99 1 5.98 0 0 16.5 4.28 294.83 5974 2.31 100 40.39
8.26 -10.94 10.31 2.94 1 5.98 0 0 17 4.3 300.19 6127 2.24 100 40.39
8.6 -10.94 10.34 2.91 1 5.98 0 0 17.5 4.28 294.51 6233 2.11 100 40.39
8.92 -10.94 10.21 2.87 1 5.98 0 0 18 4.3 301.35 6347 1.77 100 40
9.26 -10.94 10.08 2.82 1 5.98 0 0 18.5 4.28 301.35 6392 1.8 100 40
9.6 -10.94 10.09 2.8 1 5.98 0 0 19 4.3 301.91 6446 1.79 100 40
9.92 -10.94 9.97 2.76 1 5.91 0 0 19.5 4.28 300.19 6533 1.83 100 40
10.26 -10.94 10.03 2.73 1 5.84 0 0 20 4.3 304.47 6623 0.33 100 40
10.58 -10.94 -9.51 0.8 1 0 0 0 5.5 2.7 62.37 6403 -0.13 9.8 0
Old 12-29-2012, 12:20 AM   #22
smurf juice
Member#: 338563
2009 wrx
wrb
this was wot in third gear idk if its public or not? how do i do that?
Old 12-29-2012, 12:24 AM   #23
smurf juice
Member#: 338563
2009 wrx
wrb
0 -10.94 5.59 2.82 1 5.28 -0.7 0 15.5 3.4 138.84 3102 10.09 28.24 38.82
0.34 -10.94 6.18 2.89 1 5.28 -0.7 0 14.5 3.52 153.21 3073 9.82 29.8 38.82
0.66 -10.94 6.96 3.08 1 5.28 -0.7 0 13 3.58 162.73 3099 9.17 29.8 39.22
1 -10.94 7.24 3.14 1 5.98 0 0 13.5 3.54 156.51 3065 8.9 30.2 40
1.32 -10.94 6.87 3.06 1 5.98 0 0 13.5 3.56 163.83 3201 9.02 30.59 38.82
1.66 -10.94 5.86 2.92 1 5.98 0 0 14.5 3.52 151.38 3094 9.38 28.24 38.82
1.98 -10.94 5.18 2.77 1 5.98 0 0 16.5 3.46 145.12 3187 9.92 27.84 38.82
2.32 -10.94 5.12 2.76 1 5.98 0 0 16 3.5 143.7 3209 9.64 28.24 38.82
2.64 -10.94 5.19 2.8 1 5.98 0 0 16.5 3.48 149.94 3295 9.64 28.24 38.82
2.98 -10.94 4.07 2.67 1 5.98 0 0 16.5 3.4 136.13 3193 5.86 24.71 38.82
3.3 -10.94 4.56 2.66 1 5.98 0 0 16.5 3.48 147.01 3303 10.04 28.63 38.82
3.64 -10.94 5.59 2.81 1 5.98 0 0 16.5 3.5 152.84 3327 9.85 29.02 38.82
3.96 -10.94 5.82 2.88 1 5.98 0 0 16 3.56 160.17 3357 9.34 29.41 39.22
4.3 -10.94 5.84 2.88 1 5.98 0 0 16 3.52 154.31 3371 9.64 29.41 39.22
This was in forth gear while the car was stuttering. the stutter goes away when i go to WOT.
Old 12-29-2012, 12:46 AM   #24
Coreycarlile911
Member#: 282614
2006 Wrx sti
Black pearl
Log, send to google documents, set to public. No one can help you with the scattered numbers. Btw I ran a cobb stage 2 map not even the sf with catless and a k@n intake for three months with no problems and called cobb and they said it was all good I wouldn't worry to much bout being catless. You really should figure out the code tho
Old 12-29-2012, 07:56 AM   #25
smurf juice
Member#: 338563
2009 wrx
wrb
okay i tried dragging and drooping it from ap manager into Google doc and it automatically opened it in a acell spread sheet, so i tried to copy and past it into Google doc but it wouldn't let me. is their another way to get it over into Google doc?
Message Board Statistics All times are GMT -4. The time now is 02:53 AM.
