Old 12-25-2012, 09:20 AM   #1
fr0st
Member#: 41618
2008 WRX Hatch
wrb
Default stg 1 max hp
I'm running the stock OTS map. the car has a CBE and stock intake.
a tuner here (we don't have many) said i couldn't stretch SAFELY more than 5% more than the stock OTS.
Is this true? how much can you get out of the OTS stg1 with a CBE and stock intake?
fr0st is offline   Reply With Quote
Old 12-25-2012, 09:32 AM   #2
coalslaw
Member#: 324808
2006 IWL Stg2
probably around 227hp to the wheels? i say give it some time for the ecu to learn your driving habits and you will be able to determine its actual potential.
coalslaw is offline   Reply With Quote
Old 12-25-2012, 09:38 AM   #3
fr0st
Member#: 41618
2008 WRX Hatch
wrb
Forgot to add that it's the LWG Stg 1 91 map i'm using..
the normal and HWG were giving me peaks..
Old 12-25-2012, 09:43 AM   #4
fr0st
Member#: 41618
2008 WRX Hatch
wrb
no no, i've been running that map since lat spring with no issues... got a P044 once and switched to LWG and everything is stable..
So you say 227 at the wheels ? is that if i was to get it tuned by a professionnal or just the stock OTS map ?
i didn't get in on a dyno yet so i can't say how much i'm pulling right now.. all i can say is if i compare a bone stock 11 wrx (oem ecu tune) we are equal.
SO i can assume there is some improvement to the 225 stock crank hp.
that's why i'm asking how much left of hidden potential can i get out ..
Old 12-29-2012, 09:16 AM   #5
coalslaw
Member#: 324808
2006 IWL Stg2
you may get more out of a protune than a AP flash.
but i suggest you upgrade to stage 2 by having 3" tbe system, GM EBCS, equal length headers and lastly a protune. you will have a whole different car that is more powerful, better on gas and more fun to drive. but before doing the mods, ensure you are upto the required maintainence.
