Welcome to the North American Subaru Impreza Owners Club Tuesday July 7, 2015
Old 12-25-2012, 12:49 PM   #1
justinxecushyn
Member#: 190615
2004 WRX
Default Idle drop and occasionally dies
Built Morrie ej257. Cams, dom 2.5, fmic, 3inch tbe.
It's been driving like crap for a week or so. Speed dencity tuned.
Here's a video of it with a small rev.
justinxecushyn is offline   Reply With Quote
Old 12-25-2012, 02:53 PM   #2
Tripintaz
Member#: 245218
2013 STI Limited
Way to vague. Got any logs when it stalls? Who tuned the car for the cams?
Old 12-25-2012, 03:42 PM   #3
justinxecushyn
Member#: 190615
2004 WRX
I need to upload some logs. I took a quick one while driving. I don't think it's the tune. I'm going clean MAF etc to see if anything there could be the issue.
Old 12-25-2012, 05:02 PM   #4
DHRDAN
Member#: 204358
01 2.5RS W/ EJ257
ask your tuner.
we know nothing.
DHRDAN is offline   Reply With Quote
Old 12-25-2012, 05:50 PM   #5
jthatch12
Member#: 321715
03 Big 16G WRX
Originally Posted by justinxecushyn View Post
I need to upload some logs. I took a quick one while driving. Doug@Topspeed tuned it. I don't think it's the tune. I'm going clean MAF etc to see if anything there could be the issue.
If its speed density tuned then the MAF shouldn't matter
Old 12-26-2012, 07:33 AM   #6
Tripintaz
Member#: 245218
2013 STI Limited
I thought you said you were speed density tuned? Why bother with the MAF if that is the case. You are way off.
Old 12-26-2012, 07:36 AM   #7
Visiting NASIOC Timeout
has it got a vac leak??
and if doug tuned it...call him and ask him
Uncle Scotty is online now   Reply With Quote
Old 12-26-2012, 08:36 AM   #8
WRXSteye20008
Member#: 175565
2014 Sport Premium
Past: 351awhp Sti
Mine used to do this, it would idle around 900 and then just shut off, usually when coming to stops. I had an AP at the time and raised my idle by 300 and it solved the issue, but later found out the MAF needed a cleaning. That said, call your tuner
WRXSteye20008 is offline   Reply With Quote
Old 12-26-2012, 08:57 AM   #9
xDRAN0x
Member#: 163085
2009 3.0R Legacy
Urban gray
had that on my 07 WRX when the adjustable wastegate was opening just way too much, just screwed it back properly and it went away
xDRAN0x is offline   Reply With Quote
Old 12-26-2012, 09:00 AM   #10
tuzzio
Member#: 292532
05 STI
Check your fmic piping.
tuzzio is offline   Reply With Quote
Old 12-26-2012, 12:16 PM   #11
justinxecushyn
Member#: 190615
2004 WRX
Contacting Doug would be the last step for now i'm not convinced that it's the tune yet. Checking the piping, couplers, and any vac leaks.
I have a log but i'm not sure how to post it.
Old 12-26-2012, 08:13 PM   #12
unpossible....totally and completely unpossible
not in this galaxy, no
adjustable kiddie f00-f00 valve....OK....yeah
wastegate???
not
Old 12-27-2012, 09:00 AM   #13
roadtrip1098
Member#: 185688
2006 STi
WR Blue
My guess is an intake leak, small one at that. If you can't find one, you may want to do the compression and leakdown tests. If all that is good, then bother your tuner.
roadtrip1098 is offline   Reply With Quote
Old 12-27-2012, 01:16 PM   #14
justinxecushyn
Member#: 190615
2004 WRX
I'm thinking that too. It's probably a leak somewhere. I hear a hollow sound breifly if I tap/rev the motor to 1500-1700k
Old 12-28-2012, 04:04 PM   #15
Strider327
Member#: 131280
2004 Impreza WRX
Did you fix the issue?
Strider327 is offline   Reply With Quote
Old 12-28-2012, 04:19 PM   #16
xDRAN0x
Member#: 163085
2009 3.0R Legacy
Urban gray
wastegate???
not
yes its the blowoff valve indeed, not the waste gate. Good point. It was an AP I think.
Old 12-28-2012, 08:28 PM   #17
noonagon
Member#: 159745
2007 drunkman tuned
mega meth
noonagon is offline   Reply With Quote
Old 12-28-2012, 09:20 PM   #18
justinxecushyn
Member#: 190615
2004 WRX
Not yet. Parked it and will be getting on with troubleshooting soon.
Old 12-29-2012, 12:17 PM   #19
Tripintaz
Member#: 245218
2013 STI Limited
Have you checked for boost leaks yet or if any vacuum lines popped off any sensors?
