Old 12-25-2012, 09:15 PM   #1
fr0st
Member#: 41618
2008 WRX Hatch
wrb
Default boost lower in colder weather ?
We have 10 degree F weather here and for some reason the boost onmy WRX is lower ??? (on my previous turbo car it would go higher in cold weather)
I'm running the same stage 1 91 Low wastegate as before, did a reflash, put on a normal wastegate map, atill the same..
all of them gave me a lower boost setpoint of around 10 psi instead of the rock solid 13.1 psi i would see on it during summer..
what gives ?
fr0st is offline   Reply With Quote
Old 12-26-2012, 02:08 PM   #2
Airboy
Member#: 72829
2006 WRX
2015 WRX
In the newer cars, boost target drops by quite a bit once temperature drops to 32F and below.
Airboy is online now   Reply With Quote
Old 12-26-2012, 04:22 PM   #3
Tripintaz
Member#: 245218
2013 STI Limited
IAT Boost Target and IAT WGDC comp tables pull out boost when the intake air temp starts getting below 65F. They get really aggressive at such cold temps as 10F. I would imagine Cobb did not have much ability to tune their OTS maps optimally for such cold temps.
Your choices are to have a protuner tune it, or get ATR and adjust it yourself if you dare.
Old 12-26-2012, 04:55 PM   #4
fr0st
Member#: 41618
2008 WRX Hatch
wrb
checked it out in accesstuner and it's is that.
and no i won't play with fire...Id need a winter map and a summer map... and in winter having full boost won't change much when there 6 feet of snow everywhere.
better to have lower boost in winter than ring lands popping.
Old 12-27-2012, 02:05 AM   #5
Allen Horton
Member#: 315961
2008 WRX
Dark gray metallic
OP, I was having the same question. Thanks for posting, and finding the answer. I wound up talking to Dom at Maxwell power and he echoed about the same as you just said. What a relief.
Allen Horton is offline   Reply With Quote
Old 12-27-2012, 05:28 PM   #6
fr0st
Member#: 41618
2008 WRX Hatch
wrb
Well i give credit to Bill @ Cobb. I posted on their forum and he answered to me about this.
i went in access tuner and saw that i could disable it but i would need to check afterwards that i don't max out my injectors and run lean..
better off having less boost at -10 or -20 .. don't drive that fast anyways and besides, the 4 wheels spin anyways with 10 psi of boost o snow.. What would i do with the extra HP?
Old 12-29-2012, 08:38 AM   #7
Allen Horton
Member#: 315961
2008 WRX
Dark gray metallic
Make more noise lol, and be sideways
Old 12-29-2012, 12:22 PM   #8
Tripintaz
Member#: 245218
2013 STI Limited
Good point but I'm OCD enough to where I would have to fix the tune. I mean what would you want if you had zombies chasing you in ice cold temps during the winter? I would want that extra 3 PSI!
Old 01-06-2013, 07:56 AM   #9
fr0st
Member#: 41618
2008 WRX Hatch
wrb
Because their blood freezes, zombies run slower in very cold weather so you don't need more boost
You just need a wagon to carry more stuff like that RPG that's in a wooden crate
Old 01-06-2013, 08:01 AM   #10
Tripintaz
Member#: 245218
2013 STI Limited
Touche lol
