Welcome to the North American Subaru Impreza Owners Club Monday May 30, 2016
Old 12-29-2012, 02:31 PM   #1
larrycox3
Member#: 301016
04 Impreza WRX STi
black
Default STi running rough after switching intake
i just switched from my aps 65mm cold air intake to a short ram intake. i reset my ecu and just drove it, now my car is running fine, but when im in 1st thru 3rd gears in low rpm and hit WOT it has a strong hesitation then just kicks in. no its not turbo lag lol its real rough at first...do i need to re tune? no accessport, its open source tuned. do you think the ecu just needs to get used to the short ram? my MAF is installed correctly and theres no leaks. thanks for your help!
larrycox3 is offline   Reply With Quote
Old 12-29-2012, 02:41 PM   #2
JordenP
Member#: 305041
2013 STOCK WRXSDN
Different intakes, require different tunes. Your MAF scaling is probably way off, among other things.
JordenP is offline   Reply With Quote
Old 12-29-2012, 02:42 PM   #3
mattisnotreal617
Member#: 282773
Sonic Yellow
You need a proper retune. Resetting the ECU back to factory isn't going to accommodate for a short ram. Chances are your A/F ratios are harmful levels. I would suggest you put your APS intake back on and use the proper tune for it before you damage your motor.
mattisnotreal617 is offline   Reply With Quote
Old 12-29-2012, 03:02 PM   #4
larrycox3
Member#: 301016
04 Impreza WRX STi
black
yeah i just ran it for a second with the MAF unplugged and it ran way smoother. so i will plug it back in and get a re tune. thanks a lot!
Old 12-29-2012, 08:12 PM   #5
roadtrip1098
Member#: 185688
2006 STi
WR Blue
Sounds like a leak or dirty MAF to me. Usually an aftermarket intake wont make it idle rough. The tune is (mostly) for the boost issues associated with a higher flowing intake.
roadtrip1098 is offline   Reply With Quote
Old 12-30-2012, 12:23 AM   #6
larrycox3
Member#: 301016
04 Impreza WRX STi
black
I think you might be right. I think I may have damage the maf sensor during the swap because the car ran great with out it plugged in.
Old 12-30-2012, 08:12 AM   #7
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
waiting to read the next thread about.."well my car blew up"
Old 12-30-2012, 11:05 AM   #8
larrycox3
Member#: 301016
04 Impreza WRX STi
black
why is that? because i left my maf unplugged for less than 2 minutes?
Old 12-30-2012, 11:10 AM   #9
RoadKillDMD
Member#: 284792
2011 STI
Blurple
This is why \vv/
Old 12-30-2012, 01:00 PM   #10
larrycox3
Member#: 301016
04 Impreza WRX STi
black
Originally Posted by RoadKillDMD View Post
This is why \vv/
thanks for your input, i really appreciate it. please, when you meet someone who has blown their motor by switching intakes, let me know. as far as the problem goes, it was a damaged MAF. i took one off my buddys wrecked car. my car is running fine now.
Old 12-30-2012, 01:58 PM   #11
BlowerWhore
Member#: 342050
2006 forester Xt
you need a fresh Map to compensate the airflow
BlowerWhore is offline   Reply With Quote
Old 12-30-2012, 02:13 PM   #12
larrycox3
Member#: 301016
04 Impreza WRX STi
black
yeah goin in next monday. a local tuner said i will be just fine until then.
Old 12-30-2012, 02:30 PM   #13
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
just curious why the switch from probably one of the best intakes around to a sri??
Old 12-30-2012, 03:10 PM   #14
Decipher
Member#: 262760
2011 WRX Hatch Limtd
Be that as it may, each intake needs to be retuned for the appropriate mapping and A/F ratios. Although your idling issues may have in fact been the MAF, it doesn't change the fact that you're not properly tuned for the intake. If you were switching from one CAI to another, I wouldn't be so concerned for you. Since you changed the intake properties all together by switching to a SRI, I would exercise extreme caution and avoid boosting. I understand your tuner said it would be okay, but time and again it has been proven that it's not. I'm not a professional tuner, so what do I know.
Decipher is offline   Reply With Quote
Old 12-30-2012, 07:45 PM   #15
larrycox3
Member#: 301016
04 Impreza WRX STi
black
Because my CAI is a straw up here in rainy Washington. Going back to CAI during summer.
Old 12-30-2012, 07:45 PM   #16
larrycox3
Member#: 301016
04 Impreza WRX STi
black
Dude. I know.
Old 12-30-2012, 09:43 PM   #17
put the other intake back...do it now
Old 12-30-2012, 09:48 PM   #18
Tripintaz
Member#: 245218
2013 STI Limited
Youze trollin
Old 12-30-2012, 09:59 PM   #19
Decipher
Member#: 262760
Dude...if you know, then this makes no sense.^ There are plenty of documented cases of how different intakes create dangerous lean spots. Just trying to help man.
Old 12-31-2012, 01:45 AM   #20
WaitTheresMore
Member#: 289315
2006 STi
"Frosty"
you need a tune, cobb sri dosent require a tune.
WaitTheresMore is online now   Reply With Quote
Old 12-31-2012, 01:49 AM   #21
larrycox3
Member#: 301016
04 Impreza WRX STi
black
It is a Cobb Sri.
Old 12-31-2012, 03:13 AM   #22
put the stock intake back on...
Old 12-31-2012, 11:27 AM   #23
Tripintaz
Member#: 245218
2013 STI Limited
The Cobb SRI is at the top of the list when it comes to how much MAF scaling INCREASE is needed at WOT to not go lean. Keep running it without the right MAF values and you are at risk of creating a new thread called, " I need help on building a shortblock."
Old 12-31-2012, 10:54 PM   #24
Andrewxxcarlson
Member#: 316415
2006 WRX
Explain!
Old 12-31-2012, 10:55 PM   #25
Andrewxxcarlson
Member#: 316415
2006 WRX
I never noticed my cobb Sri go lean even before my tune at WOT. Which was cobb stage 2, now I have a protune.
