Welcome to the North American Subaru Impreza Owners Club Wednesday September 2, 2015
Old 12-29-2012, 05:19 PM   #26
cnlor
Member#: 233120
03 wrx
yellow
Originally Posted by Uncle Scotty View Post
and if the idiot who build your motor to the wrong specs for a street motor thinks it needs 20w50....its because he dont know what he is doing building a motor
20w50 is RACE engine oil...not street engine oil
So what are suggesting? Wouldnt the viscosity be better for it? So I should use 5W-30? I just moved to Iowa and it gets pretty chilly here
cnlor is offline   Reply With Quote
Old 12-29-2012, 05:19 PM   #27
cnlor
Member#: 233120
03 wrx
yellow
Originally Posted by z View Post
FYI, if you have the throttle down at 100% while cranking, it cuts fuel and you can achieve the same effect without bothering to pull the ignition fuse.
(and not dumping a bunch of fuel into the cylinder without starting... unless you're also pulling the fuel pump relay)
I will try that.
Old 12-29-2012, 08:17 PM   #28
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
dunno d00000d....but you gonna blow that motor sky high using 20w50 in the winter thats for sure
and using ANY 5w30 would be as bad or worse
id try the 5w40 rotella t6....and there is only ONE 5w40 rotella in the bluie jug....any other rotella is the wrong one
Uncle Scotty is online now   Reply With Quote
Old 12-30-2012, 05:43 AM   #29
GrumpyPitbull
Member#: 313311
+1 on Scotty's advice.
OP, the 5w40 will be fine for Iowa winters. I live in MN, and run it year round.
