Old 09-02-2012, 05:12 AM   #1
jjppmm29
Member#: 330918
1999 metro
Broken Heart Black
Default EJ20H swap for a Chevy Metro(Help + Project Updates)
so it has begun... as the title says I am going to be swapping the little I3 for a EJ20H from a Subaru Legacy with the twin seq turbo's...
I have already bought the engine and transmission. I have taken some measurements and the only part I should need to major fabrication is the center console witch needs to be razed about 3".
I managed to nag myself a service manual and most the parts i need i could just bolt right into my metro with a few new holes for nuts and bolts
ok so the part where I need help...
will the ECU from any other manual turbo EJ work or do i need a more specific ECU
And idk if the manuals I have include vacuum tube placement and everything because some of them on the engine are cut...
I will be posting some photo's tomorrow of my engine and my car
jjppmm29 is offline   Reply With Quote
Old 09-02-2012, 08:59 AM   #2
dexterous
Member#: 23553
2005 STI - Insanity!
2014 WRX - Daily
Are you serious? How could you possibly fit the layout of the EJ into a Metro? Are you making this rear wheel drive? The Subaru motor hangs in front of the drive shafts, wouldn't that extend beyond the front of the car?
dexterous is offline   Reply With Quote
Old 09-02-2012, 06:31 PM   #3
jjppmm29
Member#: 330918
1999 metro
Broken Heart Black
from what measurements I have taken it should fit just fine...
maybe I will have to for-go making it AWD but again from what I can see the linkage will work
the measurements for my engine bay are 34"wide and 24"-25" long
the engine is 33-34"across the timing belt cover and only 22-23" long from the timing belt cover to the back of second cat past the turbo
another the cv is 2" or so in front of that...
I have some project pictures on he way I just have to crop them and upload them on the net witch i will do tomorrow
Old 09-02-2012, 08:51 PM   #4
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
I recommend directing this to the Subaru Conversions forum.
Old 09-03-2012, 02:53 PM   #5
jjppmm29
Member#: 330918
1999 metro
Broken Heart Black
how would i move it... or would i have to start a new thread
Old 09-03-2012, 03:13 PM   #6
biodude
Member#: 271720
Pm a moderator and ask to have it moved
biodude is offline   Reply With Quote
Old 09-03-2012, 05:11 PM   #7
jsquared
Member#: 212052
2005 STi
You better be good with a welder...
jsquared is offline   Reply With Quote
Old 09-04-2012, 12:07 PM   #8
Paidfor
Member#: 267815
Be in awe
dont hate .)
^^^^And a hammer
Old 09-05-2012, 02:04 PM   #9
jjppmm29
Member#: 330918
1999 metro
Broken Heart Black
I have some skills
so I have taken some more measurements
I have to figure out what I am going to do about the second cat.. because as it is right now it is going to be in the way of the firewall... so do I cut the fire wall or try to move the cat around...
here are some project photo's
For the engine bay
Metro
A=24 1/2
B=41
C=35 3/8
D=34 1/2
PICT0062-mesurements by luv4eva_42084069_what_freek, on Flickr
For the engine
EJ20H
A=31 1/4 across Timing belt cover
B=24 From Timing belt cover to back of Turbo Shroud
C=24 From Inter-cooler to bottom of Oil Pan
D=21 1/2 from Timing belt cover to the front spline
PICT0042-Mesurements by luv4eva_42084069_what_freek, on Flickr
PICT0091-Mesurements by luv4eva_42084069_what_freek, on Flickr
So.... I am having trouble finding a decently priced cross-member for my engine... anyone got any ideas
Old 09-06-2012, 12:21 AM   #10
TRinityMtrSprts
Member#: 43720
2002 mbp WRX
97 Ford Ranger on Bags
if he can pull this off, it'll be the fastest Metro that ever lived!
TRinityMtrSprts is offline   Reply With Quote
Old 09-06-2012, 01:28 AM   #11
jjppmm29
Member#: 330918
1999 metro
Broken Heart Black
it will be a (98)Geubaru Megacy GT
Old 09-06-2012, 01:31 AM   #12
jdblock
Member#: 235211
2004 STi
The measurements are showing that you're going to be mounting the engine transversely, and that it won't fit.
If you are planning on mounting the engine longitudinal, you need to measure between the frame rails and not from the center of the strut tops.
jdblock is offline   Reply With Quote
Old 09-06-2012, 01:43 AM   #13
jjppmm29
Member#: 330918
1999 metro
Broken Heart Black
measurement (C) on the photo is actually the width of the engine bay... well really close to it... like 1" at most over... ill have to post another picture once I get the engine out... i am waiting till i get a crossmember before i pull her out
Old 09-06-2012, 09:35 AM   #14
suberdave
Member#: 101865
88 GL-10 STi
if this guy did it into a Justy, you could do it into a metro...
http://www.cardomain.com/ride/3163356/1993-subaru-justy
but like said before i hope you have fabrication skills...
If you want it bad enough... and you have Time Talent and Money, you will make it happen.
People laughed at me when i told them i was going to mid mount my Subaru with a supercharge 6 cylinder... then i did it and showed them it could be done...
http://forums.nasioc.com/forums/show....php?t=2380691
-=Suberdave=-
suberdave is offline   Reply With Quote
Old 09-06-2012, 03:13 PM   #15
Hondaslayer
Interpretively Paraphrasing
Member#: 4562
1995 Legacy LSi
1998 Declasse Moonbeam
-=Suberdave=-
We already knew you were crazy, that just cemented the diagnosis
Old 09-08-2012, 08:38 PM   #16
jjppmm29
Member#: 330918
1999 metro
Broken Heart Black
Suberdave
I appreciate that little bit of information it was amazing no joke
though I have to say my metro build is a little easier then that justy build
for instance I should to be able to use the front and rear cross member from almost any EJ car
I have to thank you... cause up until now i had no idea what drive shaft i was going to use but a justy's drive shaft should work just fine...
I am hopefull that i should be able to get a parts car this week... then i can start tearing apart my metro
Old 09-08-2012, 09:37 PM   #17
jjppmm29
Member#: 330918
1999 metro
Broken Heart Black
side note I was looking up subaru justy and it should be pretty easy to throw in something like a RB26 from a skyline.... just a kool thought...
I know I cant fit a RB in my metro... but a justy looks just right
maybe I might do this after my ej swap
Old 09-27-2012, 05:24 AM   #18
jjppmm29
Member#: 330918
1999 metro
Broken Heart Black
So I bought my self a legacy... a little 650$ car so I can salvage parts I need... figured it was better then going to a junk yard... or spending X amount of money that I dont have... now the only problem I am having is the electrical components... because I dont know what ecu goes with my engine... or even where to go and get a wire guide...
it is an twin sequential ej20 790253 with a 5sp manual trans 9R-TY752VBCAA
apart from the electrical issues I should have everything I need to throw this motor in
Old 09-29-2012, 05:21 PM   #19
charliew
Member#: 125304
I bought a jhots 96 tt motor, tranny and all the control stuff several years ago. The control box and all the hoses is a real nightmare. I'm sure when it was new it was neat but now it's a lot of questionable parts.
charliew is offline   Reply With Quote
Old 10-02-2012, 08:26 AM   #20
BODYSHOPSUBI
Member#: 333795
05 lotus
orange
this thing would be fun to drive gl
BODYSHOPSUBI is offline   Reply With Quote
Old 12-29-2012, 08:47 PM   #21
jjppmm29
Member#: 330918
1999 metro
Broken Heart Black
Sorry for the long delay its winter and not having a heated garage means I cant put in any work ATM. tough to work when your wrench is shaking in your hand and all your thinking about is the wrench shaking in your hand.
bought an ecu finally. took me 3 months to track one down that will work in my car. I hope they give me a diagram or pin out would be nice. because although I have some diagrams the pin out's usually change from box to box. Or at least for alot of things like this I dont know how much congruency Subaru has with there ECU/ECM's. (I should look into this)
http://www.ebay.com/itm/290829366524...84.m1497.l2649
I will be posting some project pictures latter for parts I pulled.
Old 01-12-2013, 12:38 AM   #22
jjppmm29
Member#: 330918
1999 metro
Broken Heart Black
so I have started the laborious task of rewiring everything
this is an image of me trying to figure out if the pinouts are right
PICT0099-2 by luv4eva_42084069_what_freek, on Flickr
I have around 12 different pinout diagrams I know I am missing a plug for the ecu... I plan on visiting the junk yard to grab one that will fit... I wish I could find a complete wire loom it might make this easyer as I am going to have to fabricate the whole thing... while at the junk yard I will also try and pull as many plugs and harness wires as possible... if someone would be so kind as to let me know witch pin out is right for my ecu I would be forever great-full.
So I finally got some batteries for my camera so here are some more pictures of the parts I pulled for my project
Front Crossmember(no turbo model will need fabrication work)
PICT0098-2 by luv4eva_42084069_what_freek, on Flickr
Front Control Arms, Rotors, Calipers, & Knuckles
PICT0094-2 by luv4eva_42084069_what_freek, on Flickr
MAF Sensor(I will possibly have to get a different one)
PICT0096-2 by luv4eva_42084069_what_freek, on Flickr
I am not sure what this is I think it is an accelerometer for the ABS idk why I pulled I dont know if i want to go through the trouble of putting ABS on her
PICT0097-2 by luv4eva_42084069_what_freek, on Flickr
Old 01-15-2013, 04:58 AM   #23
Dori Ninja
Member#: 73974
04 RSTi
so im planning to swap an EJ into a FC chassis, and the only valid point brought up by the nay sayers is the steering column...i know this is a completely diff set up, but just wondering if u are finding any issues there or will the motor be in front of that as it is in the subaru chassi (is that plural for chassis???hahahaha)
Dori Ninja is offline   Reply With Quote
Old 01-18-2013, 12:27 PM   #24
jjppmm29
Member#: 330918
1999 metro
Broken Heart Black
For myself it is actually going to be the master brake cylinder and the brake booster. If you need to you can actually re plumb most of the exhaust pipes to fit. eventually I plant to use a stainless steel for the exhaust since it is all custom there is no point in me using all or even most of it. all in all the only parts I need are the manifold and the up pipe. as for the brake system witch I talked about earlier I am probably going with a remote setup where the brake booster and master brake cylinder are not attached directly to the brake pedal.
Ultimately if you know what your doing there is no reason you could not re plumb the entire engine to mirror the turbo setup. this would essentially move all the clearance from the right to the left and vice verse. if your willing to put in the work there is nothing you cant do with it. but a word of caution it is alot of work you need a decent welder and a good supplier for the ducting IE blow off valve return and you will have to re work the plumbing under the intake manifold. all in all if you know what your doing and have the supplies it could work out really well.
so to Dori Ninja the clearance issues should be taken into account there is one with regards to the steering linkage but there is ways around it if you are interested and willing to put in the work.
Old 01-18-2013, 02:32 PM   #25
Badler
Member#: 133597
So what were the frame rail dimensions? Seems to me like you will have to raise/pull the engine to access the plugs.
