Old 12-29-2012, 08:32 PM   #1
beanakai
Member#: 339125
2008 WRX w. cb, ap
Default Testing coilpacks
I have an 2008 WRX with individual coil packs on each plug. What is the proper way to test these, I do not have the repair manual yet
beanakai is offline   Reply With Quote
Old 12-29-2012, 08:39 PM   #2
DavC825
Member#: 201736
The 4 door goodluck
Charm
Use a ostilliscope(spelling)..... scope firing voltage and actual burn voltage which should be about 1/4 of the fire voltage.
DavC825 is offline   Reply With Quote
Old 12-29-2012, 08:45 PM   #3
REX8
Member#: 24038
You think you're down a cylinder? Unplug them one at a time, you should feel/hear the cylinder drop if it was working.
REX8 is offline   Reply With Quote
Old 12-29-2012, 09:11 PM   #4
OK Houston
we have an Uncle
you cant test them, really
Old 12-30-2012, 03:33 AM   #5
beanakai
Member#: 339125
2008 WRX w. cb, ap
so basically just replace them?
Old 12-30-2012, 04:00 AM   #6
OK Houston
we have an Uncle
are they 'bloated' or split or 'distorted' or smell burnt????
if so.....they should be replaced
usually...if you move them to other cylinders and the issue follows the move..they are bad
Old 12-30-2012, 04:00 AM   #7
OK Houston
we have an Uncle
and this is in the wrong forum......
Message Board Statistics All times are GMT -4. The time now is 09:46 AM.
