Welcome to the North American Subaru Impreza Owners Club Wednesday December 7, 2016
Old 12-25-2012, 11:08 PM   #1
jbrewer10
Member#: 341547
2012 WRX Hatch
Default Do I need larger injectors for 2012 WRX Stage 2?
Hello all,
I've been thinking about getting a stage 2 protune on my 2012 wrx and have a couple of questions:
Do I need to upgrade from the stock 565cc injectors in order to not run too lean and damage my engine?
How much does a protune generally cost?
Mods
Invidia catless DP
Invidia catless UP (also, do I really need this??)
K&N Typhoon SRI
SPT catback
Cobb AP
Thanks!
jbrewer10 is offline   Reply With Quote
Old 12-26-2012, 10:21 AM   #2
bluemax189
Member#: 137405
2011 WRX 6spd
GTX3076r
no injectors needed for stage 2 at all. protunes are typically around $500 around me plus the pre dyno inspection.
bluemax189 is offline   Reply With Quote
Old 12-26-2012, 03:42 PM   #3
Cobb Tuning
Member#: 4803
Actually, many Stage2 2009-2013 WRXs max out their injectors with fully catless exhaust components, especially in colder climates and near sea level because they are extremely prone to boost creep. Many cars here in Oregon are untunable without an EWG to keep boost under control, or upgraded injectors/pump to keep up with the excessive boost creep. OP, you will want to work with your tuner to find out if you'll have the adequate fueling available
Cheers
Lance
Old 12-26-2012, 10:42 PM   #4
kris5597
Member#: 341546
2015 WRX
CWP
Hi Lance,
How much on average does the boost increase during boost creep? Does it ever spike to 20psi or more there in Oregon? I live in Louisiana at sea level, just trying to get a ball park of what I should expect from the different elevation and modifications. I will be running the Perrin DP to help with the boost creep and to also maintain a catalytic converter.
Kris
kris5597 is offline   Reply With Quote
Old 12-30-2012, 05:19 AM   #5
jbrewer10
Member#: 341547
2012 WRX Hatch
Thanks guys!
I've decided to drop the SRI as it will just further lean out my car, and since the stock intake is more than adequate. Instead, in order to keep boost levels constant (and safe), I'm focusing on the following mods:
Invidia catless DP
Invidia catless UP
SPT catback
GFB BOV/BPV
GS EBCS
Cobb AP
