#7026 | |
Member#: 149262
MWSOC
Vehicle:2003 03WRXw6sp/05FXT PSM |
#7027 | |
Member#: 241216
MWSOC
Vehicle:02 AW WRX w/EWG 95 LX Wagon |
Shortest route would be to Tee in to the coolant feed/return lines for the turbo, but I don't like the thought of using those lines in case they start a leak. I like the throttle body lines idea better. |
#7028 |
Member#: 149262
MWSOC
Yeah I would rather have the tb lines blow before turbo lines. Seems like a lot of overkill for virtually no performance gain.
I can see the benefits if a car was dedicated track car. Still look for a write up curious to see how people are routing them. |
#7029 |
Member#: 195711
MWSOC
Vehicle:STi 04/05/06/07 JBP / OBP for now |
Could also use the return line from the reservoir that goes to the radiator. And daisy chain from one to the other or just tee before and after.
I have dual mvr on mine and I agree with posts above about it being overkill, and more for a track car. Where mine are on the car it would be hard to plumb because it is on the front right corner of motor below the power steering tank. |
#7030 |
Member#: 241216
MWSOC
#7031 |
Member#: 319017
Vehicle:2005 SAABARU 18g xt JDM 6 speed |
#7032 |
Member#: 270699
MWSOC
Vehicle:2005 WRX Wagon OBP |
#7033 |
Member#: 241216
MWSOC
Rob, Aron, and Levon, what spring pressure are you running in your gates, and what's your target boost?
Edit: I had mine set up with 19lbs worth of spring. Took the car out last night and it only opened for about 200rpm near 5000rpm in second and third gear. Took it out again just now and the wastegate didn't even open in first and I hit fuel cut (which is set at about 25psi relative). So, I'll be stepping down spring weight, but I'm not sure how low I should go? I also had a couple questions about the wastegate installation. You guys have my number, so if one of you would give me a call that would be awesome. I'm assuming I have an leak somewhere because the turbo takes til about 5k to hit full boost now, and seems to taper of pretty quickly. I know the headers will make me lose spool, but deleting the TGV assemblies and running the EWG should have nullified that loss... Hopefully it just needs to be tuned. ![]() Last edited by Travisty; 12-31-2012 at 11:56 AM. |
#7034 | |
Member#: 319020
MWSOC
Vehicle:2012 STI Stage 2 |
#7035 | |
Member#: 241216
MWSOC
#7036 |
Member#: 305172
NWIC
Vehicle:2006 Wrx STI Wrb |
Well the Wrx is gone. Officially sold. Now the Sti is on the road and gets the snow tires put on wed. Wed the stock Wrx wheels will be available.
#7037 |
Member#: 241216
MWSOC
LOL! Just found my air line feeding the EWG was loose... No wonder it wasn't venting!
#7038 |
Member#: 166290
MWSOC
Vehicle:04 GT30R 6MT Wagon San Remo Red Wide Body |
#7039 |
Member#: 195711
MWSOC
Mine is 16psi. Decent rule of thumb is half of target, but you found your issue anyway.
#7040 |
Member#: 315241
MWSOC
Vehicle:2012 Subaru WRX Satin White Pearl |
Anybody interested in (4) Stock WRX 235/45/17 Dunlop SP Sport 01s? Have about 7500 Miles on em all of them still in really good shape. Threw Blizzaks on for the winter then going bigger come Spring. Would rather sell them local.
#7041 | |
Member#: 241216
MWSOC
......Aaaaand it works! Yay, EWG is fun! It's not near as loud as other people have said, but then again my car is kinda loud to begin with.... |
#7042 |
Member#: 195711
MWSOC
The rule of thumb i gave was for a maximum spread, obviously im not running 32psi w/ electric control but I also don't want it cracking at low levels.
Just wanted to clarify. And yeah I was expecting it to roar too, and I think between the fact I don't care about the noise because it is foot regulated and the fact I'm only spinning to 4500 right now. I was kinda disappointed |
#7043 |
Member#: 166290
MWSOC
are you running a hybird boost controller? i have to agree with you, its not as loud as i thought it would be either. I guess it might be diff if you have a quite exhaust..
#7044 |
Member#: 241216
MWSOC
Yeah, it's a hybrid setup using a GM EBCS and a Hallman Pro. Right now my WGDC is at zero, and the manual is backed all the way off so I'm just running spring pressure.
#7045 |
Member#: 166290
MWSOC
#7046 |
Member#: 241216
MWSOC
No, I was really looking forward to some MickeyD's rootbeer, but they didn't have their lunch menu up yet.
![]() I rolled by your shop looking to see if I could give you a EWG blast, but apparently you guys are playing hooky today? ![]() |
#7047 |
Member#: 166290
MWSOC
I wish I was playing hooky today. Had to take Down tents downtown from last nights party's.
#7048 |
Member#: 241216
MWSOC
#7049 |
Member#: 241216
MWSOC
Founders meet next Monday.
#7050 |
Member#: 149262
MWSOC
DId you ever get those rails you made flow tested?
| Thread Tools | |
| Display Modes | |
| Anyone here from the Grand Rapids, Holland, or Muskegon MI areas? | Scooby do | Mid West Subaru Owners Club Forum -- MWSOC | 19 | 05-25-2012 02:09 PM |
| Good alignment shops in the Grand Rapids/Muskegon areas? | Paradenu | Mid West Subaru Owners Club Forum -- MWSOC | 3 | 12-08-2006 01:20 PM |
| Anyone close to Grand Rapids going to the Ojibwe ProRally? | penjaja | Mid West Subaru Owners Club Forum -- MWSOC | 4 | 08-13-2002 01:55 AM |
| Grand Rapids | metroplanner | Mid West Subaru Owners Club Forum -- MWSOC | 0 | 06-15-2001 05:00 AM |
| Grand Rapids MI Autocross | Scooby do | General Forum Archive | 0 | 09-27-2000 03:26 PM |
