#10101 |
Member#: 151739
Vehicle:2003 WRX wagon WRB |
Pretty stoked about my Christmas presents this year. Nothing high end, but wife got me this tripod and ball head : http://www.bhphotovideo.com/c/produc...um_Tripod.html
I then took the cash that I got from various relatives and bought myself a D300. Now the question is, sell Old Faithful (My d70s) for all of $75 or so or keep it for crazy stuff like rig shots?
#10102 | |
Member#: 341480
#10103 | |
Member#: 15341
Vehicle:2012 Borderline Pro Photographer of the Year |
You could keep the D70s for rig shots, but I've never tried to use an older camera for rig shots so I'm not sure how well it'll work for you. Worth a try I suppose! |
#10104 | |
Member#: 151739
Thanks! The camera finally arrived from B&H last night. First impression is that it's COMPLETELY different than my old camera. I had to go through the manual to understand most of the new settings! For example, the 51 point versus 3D 51 point autofocus: I need to understand when to use one over the other. Seems like the 3D is better for moving objects, but it appears that there are times when I would not want it enabled. |
#10105 | |
Member#: 15341
#10106 | |
Member#: 151739
![]() Looks like I may not want to use all 51 points, but perhaps the 21 or even 9 point depending on the situation. This blog item was very helpful: http://thephotographysite.org/how-to...300-autofocus/ This is definitely a camera body that I can grow into. Now I just need to start buying better glass. ![]() |
#10107 |
Member#: 151739
First time out with the new camera!
I know that a few of these are a bit soft (Next time I'm bringing the tripod), and I could use some advice on the white balance, as I was also having a bit of trouble with that. Other than that, I'm actually pretty happy with these (As always, let me know what I need to work on, as I still think that they're a bit "centered"). ![]() ![]() ![]() ![]() ![]() Last edited by DNut; 12-30-2012 at 03:57 PM. |
#10108 | |
Member#: 15341
As far as white balance goes, when it comes to snow photos specifically, you can really go either way. If you keep it on the colder (blue) side, it works since the whole scene is cold anyway. However, if you move it toward the warmer (orange) side, the colors tend to have a little more pop and saturation, which is also important when your scene is mostly white in the first place. It really is a judgement call by you the photographer...I tend to go with a tiny bit more on the warm side overall. |
#10109 | |
Member#: 151739
I think I ended up with a color temp around 6500 or so. |
#10110 |
Member#: 238919
Vehicle:007 LGT LTD DGM stg1 |
^^^ In regards to color temp in the snow. That was something I had a lot of trouble with myself. I used my white rex as a model often and in the snow would usually end up converting it to b&w and cooling it in pp. It was regarded by Armin as too cool if I remember his c&c correctly, but I liked the look. I wanna make the viewer say 'brrrrrrrr'
![]() I finally have full access to my flickr account again, so I have been diggin' through last summers shots. I have noticed that my panning/rolling shots all (most anyway) have something in common, blur on the subject. And idk if it's a depth of field issue or camera shake or both? Here is an example, only really looking for C&C on the blur on the rear of the car. Rolling ![]() Panning ![]() If it is camera shake, how do you fix it in rolling shots? Drink less coffee? Softer suspension?? |
#10111 |
Member#: 267837
Vehicle:2011 WRX GR Lightning Red |
To go along with the snow theme...It was snowing heavily and my camera was getting wet so I didn't have much time to set up and compose as much as I wanted.
![]() I went for the de-saturated and darker look on purpose on this one ![]() |
#10112 |
Member#: 151739
Digging the second one!
Little weird, but I like how the rock wall continues right where the bumper stops. That and the falling snow seems to "pop" more. I'm curious as to how the first one would look if you processed it in the same manner. |
#10113 |
Member#: 267837
Thanks! I wish the car was cleared off a little more but I literally just drove home from work and wanted to get some shots in before it got dark. Here is the first one re done in the same style as the second one as you mentioned.
![]() And here's one more from the set ![]() Last edited by INKMAN; 12-30-2012 at 10:27 PM. |
#10114 | |
Member#: 15341
#10115 | ||
Member#: 15341
#10116 |
Member#: 15341
On my blog, I posted my "2012 Year in Review" that has my favorite photos taken over the past year. You can see them all (77 of them) here:
2012 Year in Review | Armin Ausejo Photography Since NASIOC only allows 10 photos per post, here are 10 photos from my 2012 Year in Review that you probably haven't seen here on this thread (mostly because they aren't automotive-related): ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() I hope everyone has a safe and happy new year! |
#10117 | |
Member#: 238919
However I do believe it was shot in landscape mode, sooooo, you might have a point. |
#10118 | |
Member#: 15341
But yeah if the panning shot was at ƒ5, it's most likely a DOF thing combined with a bit of camera shake. I've had a similar experience with this photo for example...the rear is sharp, but the front isn't because I didn't lead the car enough in my shot...this is 1/160 sec @ ƒ5.6: ![]() But then when you've got it all working for you, even at ƒ2.8 the focus can be spot-on: ![]() |
#10119 | |
Member#: 267837
#10120 |
Member#: 232519
advice? I know I need a polorizer and the snow on the lip (snowplow more like) and the bottom of the windshield bother me a bit but I was in a hurry
#10121 | |
Member#: 238919
In other news, I have a new model to shoot. Picking up an 07 DGM LGT LTD tomorrow ![]() |
#10122 |
Member#: 116351
VIC
Vehicle:2009 CFRP GR WRB STI 2006 EVO IX MR |
#10123 |
Member#: 267837
Well after a little over a year of starting photography I finally got a tripod. I only got to play around with it for about 15 minutes but I love it and can't believe I've waited this long to get one! This shot was at ISO 100, f/2.8, 85mm, and .3s. I know this shot needs multiple polariaztions but I don't have Photoshop.
#10124 |
Member#: 15341
I actually don't mind the snow on the lip and windshield so much since...well, it's snow. Perfectly clean cars in the snow just don't really make much sense realistically, and it's not like the snow that's there is really distracting. The composition and location are good (I might move the car just a tiny bit to the right in the frame though), but I think overall it's a bit underexposed. Since snow is white, it easily fools your camera's metering system, so often you need to compensate a little bit with a little more exposure. You might be able to simply add some in post-processing as well.
#10125 | |
Member#: 15341
Congrats on the new purchase! |
| Thread Tools | |
| Display Modes | |
| Koji's Quick and Dirty DIY Guide (AKA Tips for the adventerous DIY newbie) | Koji | Interior & Exterior Modification | 30 | 04-11-2009 11:31 AM |
| EJ25 to EJ25 swap, first time, good tips and tricks to know? | Patrick Olsen | Subaru Conversions | 8 | 11-27-2006 10:14 PM |
| Tips & Tricks to a clutch install | MRF582 | Transmission (AT/MT) & Driveline | 12 | 11-05-2005 03:39 AM |
| Band photography, tips and tricks? | Matt A | Off-Topic | 7 | 08-18-2004 04:50 PM |
| Quick and dirty way to extract pdf files to word or publisher? | ChosenWon | Off-Topic | 10 | 12-17-2003 10:18 AM |
