Old 12-29-2012, 04:02 PM   #8251
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
Originally Posted by Sellars21 View Post
Haha no amount of paint will make them look like 4 pot mono block brembos.
This is true. Best option is to replace with the real thing
Old 12-29-2012, 04:15 PM   #8252
Silver08Waggs
Member#: 283606
2008 Impreza 2.5i
I'm leaning towards gold then paint the calipers red I like the red and gold look black is nice but hard to really see the wheels design so it between silver and gold I think also what do you guys think for clutch stock with resurfaced flywheel or clutch masters stage one with resurfaced flywheel...
Silver08Waggs is offline   Reply With Quote
Old 12-29-2012, 04:24 PM   #8253
09subi2.5i
Member#: 331636
09 impreza
paprika
I posted in the classifieds but I figured I'd post here too. Does anybody have a stock '10 grill?
09subi2.5i is offline   Reply With Quote
Old 12-29-2012, 04:45 PM   #8254
Sellars21
Member#: 304055
2008 2.5i Rallisport
UEL Headers Magnaflow CBE
But who in there right mind would put sti brembos on our car? It's an aesthetic thing for sure. But not worth the price.
I want to know if the subaru branded 4 pot red calipers would bolt up to our car? Not to expensive, might be a better alternative. There made for the older wrx's
Old 12-29-2012, 04:47 PM   #8255
s1eepR
Member#: 335330
2008 Impreza 5DR
My question is, how difficult is it to convert + install those on the 08s that got shafted with frickin drums in the rear?
s1eepR is offline   Reply With Quote
Old 12-29-2012, 04:48 PM   #8256
Sellars21
Member#: 304055
I completely agree. I'm leaning towards resurfacing and professionally painting my 11' wrx rims the 05' bbs gold, hopefully with the calipers above^^^
Old 12-29-2012, 04:49 PM   #8257
Sellars21
Member#: 304055
I'd start by ripping everything apart and seeing if the brackets are at all the same.
Old 12-29-2012, 05:00 PM   #8258
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
Only benefit to having our rear drums is the extremely long brake life. I'm at 45k and at 70% still on them. I changed my front pads about 5k ago.
I think I'll probably try to do a swap in the spring.
Old 12-29-2012, 05:53 PM   #8259
JourdanWithaU
Member#: 146287
2009 Impreza 2.5i 5D
Sunlight Gold Opal
A lot of work. You'd need everything from the knuckle out. VDMTom wanted to get rid of his drums and found out that it was just too much.
Old 12-29-2012, 08:09 PM   #8260
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
The brembos are not only aesthetic but performance as well. Also keep in mind more brake pad options being available.
As for the 06/07 4/2 pots, the fronts will bolt up if you have the wrx brake caliper brackets and I don't remember if the front Wrx rotors will work either. The rear calipers will require a bracket from knsbrakes/kartboy for sure and again I'm unsure about the rotors (this is if you already have disc brakes in the rear). Theirs a few threads on here ill link to when I get a chance.
Old 12-29-2012, 09:12 PM   #8261
Fendyman
Member#: 21542
2011 Impreza 2.5i
Dark Gray Metallic
or get these...
Brembo universal fit disc brake caliper COVERS
Fendyman is offline   Reply With Quote
Old 12-29-2012, 09:13 PM   #8262
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
Originally Posted by Fendyman View Post
Perfect!
Old 12-29-2012, 09:15 PM   #8263
vto
Member#: 261641
2009 Impreza 2.5i
Originally Posted by fancyfootwork15 View Post
^ got any more shots? Specifically directly from the back?
Originally Posted by Steve2.5i View Post
Thiss
Here ya go guys
Originally Posted by Icarus202 View Post
Nice dude any drone off this setup?
mmmm just a little nothing that i was not expecting with this exhaust but she purrrrrs really nice when i start her up in the cold then gets quiet, when i step on the gas and it shifts you hear the exhaust really, i like the sound and it's better than stock and gives it a nice look, i think
Originally Posted by theoutbackdream View Post
Wow, looks like a WRX!
thanks bro, i was hoping to get a little bit of the look with out the price tag, now i just wish i could find someone to swap trunks with, i don't like the little wing in the back.
Originally Posted by Tentonted View Post
Nice!
Thanks bro, i appreciate it.
Got this done locally and found this crappy cell phone pic from the interior of my car, had all the plastic pieces dipped
vto is offline   Reply With Quote
Old 12-29-2012, 09:15 PM   #8264
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
Lmao oh wow. Did you see the instructions? Just dab a bunch of silicone on them and call it a day!
Old 12-29-2012, 09:25 PM   #8265
daigledangle8
Member#: 253642
2008 Impreza 2.5i
SSM
soooo my car is now a plow?
Before it really came down
New Shift knob too from Christmas!
daigledangle8 is offline   Reply With Quote
Old 12-29-2012, 09:36 PM   #8266
Sellars21
Member#: 304055
I understand the performance aspect as well. I just didn't think it would be worth mentioning. Brembos are best for heat displacement and continuous used such as track days.
For our cars though, without the HP, its pointless. Given the minimal weight difference between the wrx and sti they show similar 60-0 stopping in a straight line. That's all I care about.
That said, if I had brembos I would put them on a Toyota Prius haha.
As for the 4/2 pots, I didn't know you needed a bracket for the fronts, I was under the impression that 08 wrx 4 pots would bolt up. Just figured we had a beefier setup than the 06/07's
Old 12-29-2012, 10:18 PM   #8267
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
True, however our cars are like 400lbs lighter than the STI : p
We have the same brakes as all 08+Wrx minus the front rotor size difference (assuming you have discs all around). The fronts on the Wrx/2.5i are 2pot and rears are single pot setup. 06/07 Wrx have the 4/2pot setup, thus the physical and visual difference.
Old 12-29-2012, 10:36 PM   #8268
Sellars21
Member#: 304055
I always thought the 08wrx guys got boned with 2.5i struts and springs, minimal HP gains, but with same brakes as us to? I feel just a little better about my car.
I'll have to do some more research into the 4 pot conversion for the 08+ 2.5i's.
Old 12-29-2012, 11:44 PM   #8269
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
They still have 11.6" rotors where the stock 2.5i rotors are 10.x" something. But everything else you stated is correct
Old 12-30-2012, 01:07 AM   #8270
Fendyman
Member#: 21542
2011 Impreza 2.5i
Dark Gray Metallic
We have 10.9" front rotor... rear brakes are identical.
Old 12-30-2012, 01:17 AM   #8271
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
Thank you!
Old 12-30-2012, 02:58 AM   #8272
Steve2.5i
Member#: 293006
2015 Subaru WRX
WR Blue
Originally Posted by vto View Post
Here ya go guys
Dang if ur car was Newport blue Pearl I would of traded for ur trunk lid lol
Steve2.5i is online now   Reply With Quote
Old 12-30-2012, 10:40 AM   #8273
krueger519
Member#: 336523
2010 Impreza 2.5i
Maroon
Alright fellas, what's the best tire to go with? I'm going with with OZ Ultralegarra 17x8 wheels. I was thinking about getting Michelin super sport tires. Thanks for your opinions.
krueger519 is offline   Reply With Quote
Old 12-30-2012, 11:01 AM   #8274
Sellars21
Member#: 304055
Another 2feet of snow again this morning, *sigh* looks like I'll have to go drifting on empty Sunday roads again
Old 12-30-2012, 11:07 AM   #8275
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
Hmm I wonder if that's coming my way...
08 2.5i and 08 Sti Suspension WRXbrother Brakes, Steering & Suspension 7 03-24-2012 02:14 PM
Will an 08 WRX intake fit an 08 2.5i? Racing101 Normally Aspirated Powertrain 26 01-19-2012 11:57 AM
08 STI Wing on 08 2.5i impreza juny102004 Interior & Exterior Modification 13 01-18-2012 09:46 AM
Will 08+ WRX gauges swap into 08+ 2.5i? Simeon Priest Interior & Exterior Modification 10 03-26-2010 02:17 PM
08 2.5i mod question deunique1 Impreza Forum 1 10-03-2007 02:35 PM
