Old 12-29-2012, 11:47 PM   #26
JokerGT
Member#: 196433
2006 WRX Sedan
UGM
Originally Posted by sc00by4life View Post
1.) why would OP buy an all season (that is the price you are quoting).
2.) even still, that leaves OP 0 money for wheels.
congratulations on not following the thread.
no more limit
but nonetheless.. I have NARROWED DOWN MY SEARCH!!
I am looking at wheels that are 8-8.5" wide.. I still cant make up my mind about 17" or 18" wheels... I am now leaning more towards the 17" wheels because I like the look of a thicker tire like the 245's
JokerGT is offline   Reply With Quote
Old 12-29-2012, 11:58 PM   #27
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
245 is the width of the tire. You want a thicker sidewall from the 17" tire. Example, if a tire is 245/40-17, the 40 dictates how tall/thick the sidewall is. 40 means 40% of the width, which in this example is 245mm.
You want to keep the overall diamter as close to stock as possible. This tool will help you compare: http://www.rimsntires.com/specs.jsp
These aren't 17", but if you want a nice setup that's right at $1200, I'd recommend these. The wheels are on closeout and the Contis are a good Max Performance summer tire.
Wheels: http://www.tirerack.com/wheels/Wheel...nt&showRear=no
Tires: http://www.tirerack.com/tires/tires....cleSearch=true
mav1c is online now   Reply With Quote
Old 12-30-2012, 01:26 AM   #28
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
pat yer a ****ing idiot...really
i promise
and what you dont know would fill volumes, this case included
you dont know anything about any of this, realy......go get in the caddy and go for a latte or something
Feel free to correct anything I posted, or to even offer a useful opinion on any of it. I'm all ears. I would love for you to help me learn all these things I "dont [sic] know."
Let's start with punctuation, capitalization and communicating like an adult. Once you're done teaching me about that, you can move on to teaching me about tires.
Patrick Olsen is online now   Reply With Quote
Old 12-30-2012, 01:45 AM   #29
pat sweetie...you come in here and troll me every chance you get
piss off
Old 12-30-2012, 12:46 PM   #30
mav1c
Hoodbridge!
Member#: 560
piss off
Rawr!
Old 12-30-2012, 02:13 PM   #31
JokerGT
Member#: 196433
2006 WRX Sedan
UGM
lookin at rota torques 17x9 with 245's on them.
Old 12-30-2012, 03:04 PM   #32
mav1c
Hoodbridge!
Member#: 560
What offset? I don't know if the Torque is available in +42, but if it is, that's what you want. Even with a +42 and 245/40-17 tires, you may have rubbing in the rear. Any offset lower than that you will definitely have rubbing and will require fender pulling.
Old 12-30-2012, 03:25 PM   #33
JokerGT
Member#: 196433
2006 WRX Sedan
UGM
+30-35'ish offset (just past flush)
I am looking at these http://forums.nasioc.com/forums/show....php?t=2445097
Old 12-30-2012, 03:34 PM   #34
mav1c
Hoodbridge!
Member#: 560
Have fun rubbing. If you don't want to rub, you will HAVE TO get your fenders rolled/pulled.
Old 12-30-2012, 03:44 PM   #35
sc00by4life
Member#: 97135
thats over priced for friggin plastidip'd/spray painted wheels.
and yeah, that will require some fender work for sure.
Old 12-30-2012, 03:47 PM   #36
JokerGT
Member#: 196433
2006 WRX Sedan
UGM
even at stock ride height???
I thought only if I lower it
Old 12-30-2012, 03:49 PM   #37
sc00by4life
Member#: 97135
yes.
If you don't understand width/offset relationship, what you need to do is STOP LOOKING AT WHEELS, and start reading the stickies at the top.
Old 12-30-2012, 04:06 PM   #38
JokerGT
Member#: 196433
2006 WRX Sedan
UGM
are there any 9" wide wheels that have a +42 offset?
or 8.5" wide that would fit stock fenders?
Ive been mainly looking at tirerack.com, but they only show the side view.. its doesn't actually show you if they are flush or poke out.
Old 12-30-2012, 04:23 PM   #39
JokerGT
Member#: 196433
2006 WRX Sedan
UGM
will 17x8.5 +48 with 245's work?
Old 12-30-2012, 05:22 PM   #40
mav1c
Hoodbridge!
Member#: 560
Yes. It'll fit but you won't get that poke look (which is a good thing IMO). It won't quite be flush either, but you'll have much less chance of rubbing.
Old 12-30-2012, 05:34 PM   #41
JokerGT
Member#: 196433
2006 WRX Sedan
UGM
Ah ok.. I guess its just very hard to find wheels that have the perfect offset. Like 17x9 +42 or 17x8.5 +45.
Thanks for the help!
Old 12-30-2012, 05:40 PM   #42
mav1c
Hoodbridge!
Member#: 560
Old 12-30-2012, 06:16 PM   #43
JokerGT
Member#: 196433
2006 WRX Sedan
UGM
oh wow perfect!
17x9 Rota DPT - Flat Black (5x100/114.3/e42/73)-
Bolt Pattern: 5x100 & 5x114 (dual drill)
Offset: 42
Hub Bore: 73
- Lug Options 20 pcs. 12 x 1.25 Wheeltek Splinedrive Lugs - Black
- 17x8 Tire Options 245/40R17 91W NEXEN N3000
Comes out to a total of $1612 including shipping!!
These are some sexy beasts!! Im just a little worried about having to pull fenders. Would this fit right in with stock alignment or should I go with the 235's just incase?
Old 12-30-2012, 06:20 PM   #44
JokerGT
Member#: 196433
2006 WRX Sedan
UGM
If I do go from 17x7+55 to 17x9 +42 it says
Inner Clearance: 12mm LESS (how much space do I have before I hit the struts?)
Outer Position: EXTEND an extra 38mm (how much space do I have before rubbing issues?)
Old 12-30-2012, 06:30 PM   #45
JokerGT
Member#: 196433
2006 WRX Sedan
UGM
and if I go from 17x7 +55 to 17x9 +30 the inner clearance stays the same.. just the outer position will extend an extra 50mm instead of just 38mm.
So that means Ill probably have to roll all my fenders? but for the +42 offset I might only need to roll my rear fenders?
Just found out I can get my buddies roller for 30bucks.. so rolling isn't completely out of the question
thanks again for all your help MAV1C
Old 12-30-2012, 07:26 PM   #46
JokerGT
Member#: 196433
2006 WRX Sedan
UGM
Old 12-30-2012, 08:54 PM   #47
mav1c
Hoodbridge!
Member#: 560
and if I go from 17x7 +55 to 17x9 +30 the inner clearance stays the sme.. just the outer position will extend an extra 50mm instead of just 38mm.
You'll be fine on inner clearance with the 17x9 +42 and 245/40-17. I used to run 245/40-17 on a 17x8.5 +48 offset and had plenty of inner clearance.
Those Nexen tires are garbage. Junk. Crap. Get something better. If you're trying to stay cheap, and those offerings from wheeldude are you're only choices, at least go with the Hankook V12
That's a nice deal, but 245/40-18 is too tall a tire. You'll have rubbing issues for sure.
Old 12-30-2012, 09:25 PM   #48
JokerGT
Member#: 196433
2006 WRX Sedan
UGM
thanks bro, appreciate it!
+35 offset
http://www.wheeldude.com/catalog/pro...oducts_id=5869
+42 offset
http://www.wheeldude.com/catalog/pro...oducts_id=5733
$100 difference between the two ROTA DPT's
Is this because there is less fitment required with the +42?
Which lugs do I need? 12 x 1.25 or 1.5
and thank you for letting me know those tires are crap.. Ill look into the V12's
Old 12-31-2012, 02:08 PM   #49
mav1c
Hoodbridge!
Member#: 560
I don't know why the +42 wheels cost $100 more. Seems crazy to me. Maybe shop around.
But you DO want the +42 versions.
Old 12-31-2012, 02:49 PM   #50
JokerGT
Member#: 196433
2006 WRX Sedan
UGM
ok.. I wondered the same thing
and for the same price I could get the 18x9 +40.. but Im guessing with those If I got the 265/35's on it Id have to do more than just roll my fender? or could I get away with just rolling them? (because its a 0.3" taller diameter)
