#26 |
Member#: 59837
SWIC
Vehicle:2004 Spec-C Type RA What MAF? -Speed Density! |
I usually increase the decay delay and slightly increase the enrich, you want to prevent the initial swing to running lean right after you start the car since that starts the fueling correction oscillations. It usually happens in the <80°F range, above that I dont see any issues.
#27 |
Member#: 311781
Vehicle:2003 WRX w STI V8 |
Ill definitely give that a try. Just fixing a turbo issue first
![]() Thanks for posting! |
#28 |
Member#: 202804
MWSOC
Vehicle:2002 PSM Sedan 20g/ewg/Phattbotti Tuned |
I guess the rule of thumb for the cranking tables for the ID injectors is taking 30% out and go from there. Still working with my tuner on this since it's pretty bad.
#29 |
Member#: 134211
just noticed this thread, I have had this same cold start problem for two years now with maf and still with the cobb sd and all sorts of different injectors.. Im getting sick of it now Im ready to switch back to 93 pump
#30 |
Member#: 202804
MWSOC
So your problem is cold starts with E85? Do you have TGV deletes as well? I've spent more than $1k worth of injectors in the past year and im not happy about it.
