#1 |
Member#: 274436
South East
Vehicle:2004 WRX OBP |
Random, random question...
I'm trying to set my car up for carberry ultimately. I don't have the tgv deletes at the moment and I'm putting in a built motor in the next week or 2. Thus I don't want to completely load carberry because it will not work until I use the TGV deletes. May be irrelevant but a necessary bit of info. I'm trying to get this ecu in and just replace the tables with the ones from my current tune (maf tune). I can work it out from there (assuming it works). I've used jumper wires on the flash block and the test connectors are connected and working. I've checked it twice with my old ecu and I can write maps and crank the car. No problems. With this 02 ecu though... I can read the LV and also read the entire map with ECUflash. I just can't write to it! I get the following output: [17:27:05.640] J2534 API Version: 04.04 [17:27:05.640] J2534 DLL Version: 0.50.2598 Jun 26 2009 15:02:29 [17:27:05.640] Device Firmware Version: 1.10.3020 [17:27:08.421] denso02_bootloader_cmd_start [17:27:09.656] denso02_bootloader_cmd_start [17:27:10.890] denso02_bootloader_cmd_start [17:27:12.125] denso02_bootloader_cmd_start [17:27:13.359] denso02_bootloader_cmd_start [17:27:13.781] kernel get version [17:27:13.796] found oecu kernel! [17:27:13.796] kernel already resident - skipping kernel load [17:27:14.000] kernel get version [17:27:14.015] kernel version is : OpenECU Subaru HC16 Kernel V1.06 [17:27:14.015] reading kernel comm buffer size [17:27:14.031] comm buffer size set to 512 [17:27:14.031] reading kernel flash buffer size [17:27:14.031] flash buffer size set to 4096 [17:27:14.031] -- flashing image to ECU memory -- [17:27:14.437] -- comparing ECU flash memory pages to image file -- [17:27:14.437] seg start len ecu CRC32 img CRC32 same? [17:27:14.765] FB01 00000000 00004000 19358932 9E7D9C31 NO [17:27:15.078] FB02 00004000 00004000 7FEB9078 8F606882 NO [17:27:15.406] FB03 00008000 00004000 C949D99B 0216DE1B NO [17:27:15.718] FB04 0000C000 00004000 A7B2322D D3FE83A7 NO [17:27:16.046] FB05 00010000 00004000 F6AE956A 3ED4232E NO [17:27:16.359] FB06 00014000 00004000 92ED48B7 9B898AB6 NO [17:27:16.687] FB07 00018000 00004000 56326D4C 939D0A27 NO [17:27:17.000] FB08 0001C000 00004000 1675D4F1 C58ED7E8 NO [17:27:17.328] FB09 00028000 00004000 FAD7363A A033E210 NO [17:27:17.640] FB10 0002C000 00004000 20EA7AF5 34E6EF09 NO [17:27:17.953] reading ecu programming voltage [17:27:17.968] programming voltage is 0.00 volts [17:27:17.968] programming voltage is out of range! [17:27:17.968] interface close [17:27:17.984] interface close Any advice is so greatly appreciated.. Is it a bad ecu? If so, why would it let me read and not write? I've also bought some wiring to do the 12v fix from another source (good or bad? which wire would I jump it to since the flash blocks are different from the 02 to the 04)? Just trying to see if anyone has ever seen this before. Please help!
#2 |
Member#: 274436
South East
Bump! Anyone?
#3 |
Member#: 70395
MAIC
Are you using a genuine Tactrix cable or a cheap VAGCOM knock off? The ECU isn't bad,you just are not getting any voltage for flashing. FYI I am pretty sure you can flash the Carberry ROM straight to your 04 ECU.
#4 |
Member#: 274436
South East
It's a Tactrix 2.0. Where should I send the voltage? I've checked the voltage at both jumper wires and I'm getting 4-5 volts on both. I'm almost certain that the 04 usdm ecu will not support carberry but I could be wrong. Thanks for the response!
#5 |
Member#: 274436
South East
Evening bump! I've tried jumping 12v to both lines on the flash block. No luck there. Also tried jumping 12v to the black/white wire on the obd2 port per another thread I read. Still telling me 0 volts. Any help is greatly appreciated!
#6 |
Member#: 292996
MWSOC
Vehicle:02 wrx |
Are you able to flash a standard MAF rom to the 02 ecu? Also make sure your flash block jumper wires are making good contact.
#7 | |
Member#: 274436
South East
I'm not able to do that . That's what I've been trying to do all along. I'm trying to get a maf/standard tune on the wrx so that I can drive it for the next few weeks until I can install my new motor. Still no luck. I've checked the flash block but I'm only getting 5v there. I'm assuming it doesn't matter for the 04/05 ecu because it flashes every time.I've read using a jumper wire from a 12v source should do it but I've tried to both wires to the flash block but still nothing. Still giving me zero volts. I'm tempted to go through the pinout on the ecu then sending it directly there when the ignition is on. I've seriously found very little to nothing on this problem. People usually get whatever their voltage is at the flash block (mine is 4.5-5v) but my ecuflash reading is still 0.00... I can't tell if it's pulling this number from the ecu or from the obd port. I would assume the wires are connected to the same place on the ecu. Maybe it's a bad ecu? I just wouldn't think that I could read the image perfectly, read the learning view, and test write. Just doesn't make sense. Regardless, thanks for your response! |
#8 |
Member#: 212154
South East
Vehicle:02 bugeye, manley ej257, pt5857, MBP on E85 |
That ecu is a plug and play for an 04 wrx. Your voltage should be in the 12 volt range. Make sure you jumped the correct four wires across the jumper block. They jump up and down and not side to side. Recheck all your plugs to the ecu for any fubars there.
Btw, the carberry won't flash to an 04 up ecu because the flash method is different. |
#9 | |
Member#: 274436
South East
#10 |
Member#: 176128
South East
Vehicle:2005 WRX slowwwww..... |
^bump. We tried his ecu in my car today. I have an 02 ecu running car berry and flashing just fine. We put his ecu in my car and get the same 0.00 volt issue. With my ecu it works fine. My bet is his ecu is bad.
#11 |
Member#: 274436
South East
After last night I've realized that the rom size on the ecu is 160kb. How this is possible, I'm not sure. I received the ECU this way
... I've pulled the stock ecu from Romraider. It will not flash up. If I pull the map from the ECU, it opens fine in ECUflash but if I try to open it in Romraider it throws errors. Specifically that it's missing tables.I've been told that it could be my cable. Although, working with the 04 ecu, I will test this. |
#12 |
Member#: 156326
South East
Vehicle:2011 RA 03 bugiftw for the track |
Are you using the latest version of Ecuflash? Some issues with voltage errors were solved in this latest build. I experienced something similiar with an 03 ecu in an 05 and using 1.44 fixed it.
#13 | |
Member#: 274436
South East
Thanks for the input. It's greatly appreciated. |
#14 |
Member#: 86107
E. Canada
Vehicle:02 SD built 207 |
the 04 wrx ecu WILL BRICK if you try to flash ( successfully I imagine ) CB on it...
#15 |
Member#: 176128
South East
^not at all what he's doing
#16 |
Member#: 321715
Tri-State
Vehicle:03 WRX PSM |
Is an 02 ECU plug and play with 04? My initial thought would be no. The flash block isn't even similar. The 03 and 04 ECU flash blocks are identical. I'm not an expert at this but this would be my initial question OP
#17 | |
Member#: 108089
MWSOC
Vehicle:2003 WRX NF Performance |
You can install an 02-03 into an 04-05 and flash it. |
#18 | |
Member#: 274436
South East
I'm pretty sure they should be but you bring up a great question. As long as the car goes into test mode and the ecu sees that it's in test mode it should work. I've seen several run this setup without an issue w/ the flash block but that was my initial thought. Thanks for the reply. I may check out the flash block setup as opposed to an 02 setup. Still think it's a bad ecu. |
#19 |
Member#: 172698
MWSOC
Vehicle:11 STi Stg2 E85 02 v8 Spec C E85 |
I think it should be but I've been wanting to confirm this myself. The 03 WRX's use the same 4 pin flash plug that 04/05 WRX's use but all the 03's I've encountered have ECU's that identify as 02 WRX.
#20 |
Member#: 274436
South East
#21 |
Member#: 321715
Tri-State
Learn something new everyday
#22 |
Member#: 306186
NWIC
Vehicle:2002 Subaru WRX PSM |
Have you tried the mad mod on the VagCom? It will get the voltage to the ECU. http://forums.nasioc.com/forums/show...&postcount=190
To get power to the ecu you will need to jump the pins inside the cable at the ODB end. It is shown in the pictures, the white wire from 2 to 9 and 1 to 7 if i remember correctly. The 02 ecu is kinda a pain. |
#23 | |
Member#: 274436
South East
I have a tactrix op 2.0 but I do have a spare bfm cable I could try this with. Thanks for the suggestion I'll probably try it! |
