Old 12-15-2012, 10:56 AM   #76
silmarilion
Member#: 191270
06 STI
Donkey piss injectors FTW!
silmarilion is offline   Reply With Quote
Old 12-15-2012, 10:33 PM   #77
k mier
Member#: 98000
05 sti [email protected]
Originally Posted by k mier View Post
Wait, are both dyno plots with the exact mods other than injectors or is the later plot with a different turbo?
Originally Posted by boostfedsubi View Post
all i did was change the injectors why does everyone have to nitpick my dyno sheet? i was just sharing my results of the new injectors that made more power.
I'm kind of curious as to how changing just injectors changes that power band and increases peak power... Same boost curve?
The reason I ask is this, another ~25hp and ~200 rpm later spool would be just about right if you were going from a hot 20g to a green sized turbo that needed the tune finished. I take it from this quote he was running the same green turbo during both dyno pulls?
oh i probably should add i have FP green turbo... lol
k mier is offline   Reply With Quote
Old 12-15-2012, 10:54 PM   #78
yamahaSHO
Member#: 73932
2005 STi BROtuned
2004 S2000
The way I took that:
All I did was change the injectors. On a side note, the car already has/had an FP Green.
Old 12-18-2012, 10:18 PM   #79
Nasty EJ25
Member#: 341022
I will start out by saying I can remember when Injector Dynamics came out with the "new at the time" Bosch style injector. They absolutely blew everything out of the water in the injector world. Cars were (and still are) able to idle just as good as the OEM set of injectors but also make awesome power. With that said..... Some of you in here are completely clueless with regards to injectors and the PROCESS that Injector Dynamics and other aftermarket injector companies use to modify injectors to present the product they sell. Injector Dynamics DOES NOT manufacture their own injector from scratch.
I think we need to see a few people run these new DPIs and see what the outcome is. We could be presented with a new option that is better than ID. We could also find out they are not better or are worse. Either way some of the responses in here disappoint me since this could be a new product that the whole community could benefit from.
In for more results, if anyone buys a set please post up info
Nasty EJ25 is offline   Reply With Quote
Old 12-18-2012, 10:43 PM   #80
Syndr78
Member#: 336966
2013 WRX
...Also intrigued...
Syndr78 is offline   Reply With Quote
Old 12-19-2012, 09:16 AM   #81
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
Im deff interested in these...
rexworx is offline   Reply With Quote
Old 12-19-2012, 11:45 AM   #82
boostfedsubi
Member#: 326445
Well put. It's a new option that seems to be working wonderful in my car! Couldn't be happier!
So buy a set I think you will be quite happy with the outcome!
boostfedsubi is offline   Reply With Quote
Old 12-19-2012, 11:55 AM   #83
Leafy
Member#: 330625
2006 WRX
Honestly they only need to be run by a bunch of people to see if their quality control and tolerances are up to snuff. All anyone is really doing with these injectors is putting caps on the tops and maybe the bottoms in order to adapt them to work with current cars intake/head and fuel rails. DW just started carrying EV14's but they sell them un-modded as bought from bosch currently. Five-o does the same thing, and so does FIC.
Old 12-19-2012, 12:01 PM   #84
Nasty EJ25
Member#: 341022
The injector base does not look like an EV14 to me on the DPI. I could be mistaken but it appears to be a completely different injector which is honestly what has me so interested. Anyone have info supporting this?
Old 12-19-2012, 12:06 PM   #85
Leafy
Member#: 330625
2006 WRX
They just look like the compact length ones with adapters on both ends rather than just one end like the other brands.
Old 12-20-2012, 11:41 AM   #86
Nasty EJ25
Member#: 341022
Look at the injector clips.... They look like they are standard OBD II clips. Other places like ID and Five O Motorsports use a different clip. Therefore this is a different injector base.
Old 12-20-2012, 11:54 AM   #87
Leafy
Member#: 330625
2006 WRX
They look like minitimer, aka EV1 style connectors. And the ID ones look like uscar, aka EV6 style. Five O sometimes makes their own connectors so those of us with nippon denso connectors dont need to use adapters/re-wire.
Old 12-31-2012, 02:32 PM   #88
dfw
Member#: 161460
Anyone else using these? Heard about these not too long ago. Still on the fence with these and the Five O Motorsports injectors.
dfw is offline   Reply With Quote
Old 12-31-2012, 03:31 PM   #89
Half Crazed
Member#: 321842
2008 STi
Sorry it took so long guys its been one of those chaotic days for me. I had some time off work so i ran over and did the testing on the injectors. I will let the videos speak for themselves. all tests were done at 3bar (43.5psi) and @ 14V
Spray Pattern Test
Powered by VideoBam - Free Video Hosting
Flow Testing
Overall I am Very pleased with the results! I cannot wait to get these installed in the car and tuned!!!
Keep you all updated on how tuning goes!
Holy **** that was cool
Half Crazed is offline   Reply With Quote
Old 12-31-2012, 03:39 PM   #90
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
From what I've heard, Five-0's are garbage. IIRC, Dom at MPS won't tune anything with them.
I still don't understand why people avoid the tried and true methods to save a couple bucks. There's places to do that and there's places not to.
Edit: I happened upon where he stated this.
...Also, DO NOT run Five0 1400's. You will regret it. Any educated, reputable tuner won't tune it with those injectors either. They are horrid injectors that should have never been released to the public. You will fail the motor with those, I promise.
Old 01-02-2013, 10:09 AM   #91
boostfedsubi
Member#: 326445
Just wanted to update everybody the DPI 1000s are working flawlessly! Idle is smooth at 800rpms, drivability is wonderful! Part throttle is perfect.
So far these injectors are working out great!!!
Old 01-02-2013, 12:17 PM   #92
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
That was more about that specific size of Five-O injectors and is similar to the problem ID and DW had when they tried to make an injector in between 1000cc and 2000cc. They all pulled those sizes too due to problems but some manufacturers are doing the intermediate sizes again.
kellygnsd is online now   Reply With Quote
Old 01-03-2013, 03:38 PM   #93
dfw
Member#: 161460
Thanks. I think I might just wait it out for the ID1300's then. I was told release est. is next month anyways
Old 01-17-2013, 08:20 PM   #94
boostfedsubi
Member#: 326445
Just wanted to update everyone the car is running so smoothly these injectors are awesome! Power is nice and smooth!
Old 09-24-2013, 07:45 AM   #95
boostfedsubi
Member#: 326445
Has anybody else tried these out? I have ran e85 thru them for about 15k so far and no issues so far
Old 07-07-2015, 11:57 AM   #96
boostfedsubi
Member#: 326445
just wanted to update everyone 40k on them and still going strong. I have been following DPI on facebook and Instagram they seem to be popping up more and more...
Old 07-07-2015, 12:33 PM   #97
boostfedsubi
Member#: 326445
NV Auto in Canada STI 2JZ Swapped Drift Car
2JZ Swapped Scion FRS
Underground Performance Distribution Time Attack STI
Justin Pawlak Formula D Drifter
Michael Essa Formula D Drifter
Evo X with 5858 precision Setup
Old 07-23-2015, 03:26 PM   #98
Louisvillewagonmafia
Member#: 348886
2002 Subaru WRX
just to follow the updates, im about 5K miles into my DPI 1000cc, and i absolutely love them. posted a review here: http://forums.nasioc.com/forums/show....php?t=2736938
Louisvillewagonmafia is offline   Reply With Quote
Old 07-23-2015, 05:03 PM   #99
BeastianSTI
Member#: 310506
2005 WRX STi
Silver, Sexy 'n Raspy
Damn. The price of the dpis seem the same as ids now... Might as well go ID
BeastianSTI is offline   Reply With Quote
Old 07-24-2015, 11:04 AM   #100
boostfedsubi
Member#: 326445
shoot them an email tell them a little bit about your setup and goals they hooked up a buddy of mine with a good deal
