Welcome to the North American Subaru Impreza Owners Club Sunday August 31, 2014
Old 12-31-2012, 02:56 PM   #51
sc00by4life
Member#: 97135
jesus christ....
you are ****ing LOST.
STOP ASKING QUESTIONS AND JUST STICK TO THE 17x9 +42. Anything wider than a 245 will require a ROLL. anything wider than a 255 WILL REQUIRE A PULL. hell, even that fitment can cause too much problems for someone as lost as you. And if you only plan to run a 245, i'd stick to an 8" wheel. you obviously have no need for wider wheels.
read the ****ing stickies up top.
Old 12-31-2012, 03:07 PM   #52
JokerGT
Member#: 196433
2006 WRX Sedan
UGM
I did, and if im doing the math correctly a 18x9.5 +35 with 255/35's have the same circumference as the stock wheels.(17x7 +55 with 225/45's)
Just these will stick out 1.4' further.. just trying to check if I can get away with just rolling the fenders..?
Im trying to get as fat as possible on stock setup.
Down the road Ill get coilovers, etc.
JokerGT is offline   Reply With Quote
Old 12-31-2012, 03:55 PM   #53
sc00by4life
Member#: 97135
holy ****.
your wheels keep changing.
YES you will need to roll. WITHOUT proper camber control, you WILL need to pull your fenders.
you need to stick to a 17x8 +42-48 and a 235/40.
I'm done helping.
Old 12-31-2012, 04:37 PM   #54
JokerGT
Member#: 196433
2006 WRX Sedan
UGM
Originally Posted by sc00by4life View Post
holy ****.
Sorry lol I know I keep changing my wheels... I just keep finding better deals right before checkout.
Im just trying to figure out since the circumference is the same.. I should be bale to fit the 18x95 with 255's on them, but I am a little worried about turning.. if there is enough inner clearance??
and why should I stick to 17x8 +42-48 and a 235/40. ??
Old 12-31-2012, 04:52 PM   #55
sc00by4life
Member#: 97135
it is NOT just about OVERALL DIAMETER, but WIDTH AND OFFSET. If you try to fit wheels that are TOO WIDE with TOO LOW OF AN OFFSET you HAVE TO RUN SMALLER (i.e. NARROWER) TIRES. Just because the diameter is the same, doesn't mean "IT AUTOMATICALLY FITS". You are looking at things ass backwards.
You haven't even told us if you have a sedan or a wagon, because that changes things A LOT. seriously. stop ****in posting and start reading. if its too far over your head, maybe you should take the hint that aggressive fitments are NOT for you.
you should stick to 17x8 +42-48 because its a retard proof fitment. You need it.
Old 12-31-2012, 05:04 PM   #56
JokerGT
Member#: 196433
2006 WRX Sedan
UGM
Under my name under vehicle it says 06 WRX UGM.. not wagon.. its a sedan..
I know wagons have less room. That's why I am asking if itll work.
18x9.5 +35 with 255/35-18's with just having to roll the fenders and possibly pulling the rear fender a little?
I don't want a fitment that is retard proof because that's not the look I am going for. Those aren't flush enough.
This is my first time EVER dealing with wheels. I do engine work.
I have researched and 99% of the time this fitment is on aftermarket coilovers... so I cant see if itll fit stock.
Old 12-31-2012, 05:16 PM   #57
JokerGT
Member#: 196433
2006 WRX Sedan
UGM
I just found a deal if I get them in grey.. ill save $200 so that means im spending less on 18x9.5 w/ tires then I would on the 17x9's w/ tires!! LOL
Old 12-31-2012, 05:57 PM   #58
JokerGT
Member#: 196433
2006 WRX Sedan
UGM
I just turned the wheel all the way and measured the inner distance from the fender to the tire and I had a good inch left, and 1.5 inches from the stock struts.
I am pretty sure this fitment will work.
Old 12-31-2012, 05:58 PM   #59
OK Houston
we have an Uncle
Originally Posted by mav1c View Post
Rawr!
Old 12-31-2012, 06:00 PM   #60
OK Houston
we have an Uncle
I just turned the wheel all the way and measured the inner distance from the fender tot he fire and I had a good inch left, and 1.5 inches from the stock struts.
I am pretty sure this fitment will work. I may have to roll the rear fenders, but stock height is pretty high!
boody idiots
Old 12-31-2012, 10:31 PM   #61
mav1c
Hoodbridge!
Member#: 560
2006 STi, '11 A4
Crystal Gray, Silver
It won't without fender pulling. I've given you a lot of advice, but you don't seem to want to take it.
Old 01-01-2013, 12:20 PM   #62
JokerGT
Member#: 196433
2006 WRX Sedan
UGM
My buddy said for a 18x9.5 +35 with 255/35 setup, you can run it on stock, but Ill have to adjust my camber. and I can adjust my front camber.. and rear only with camber bolts?
but if this is really a big deal, ill size down to a 18x8.5 +44 with 255/35's
Thanks mav1c for all the help, If I do go with the 17" ill def. go with +42 like you recommended. Im just trying to see what the biggest option for 18" wheels are for the 06 WRX.
If I want to save some money I am going to have to order some by tomorrow :/ This is my last day to decide.
Old 01-01-2013, 03:07 PM   #63
sc00by4life
Member#: 97135
You'll need to roll all around with a 18x9.5 +35 and 255's if you don't want to rub like crazy.
You'll have to buy bolts for the rear, but it's possible they won't provide enough adjustment if you decide to lower your car.
Old 01-01-2013, 08:02 PM   #64
JokerGT
Member#: 196433
2006 WRX Sedan
UGM
sounds good to me.
I am going to start rolling all my fenders and place the order tomorrow.
Ill keep you guys updated on the final picture.
Old 01-02-2013, 12:51 AM   #65
JokerGT
Member#: 196433
2006 WRX Sedan
UGM
does anyone know is the 255/35R18 XL 94Y NEXEN N3000 run big?
or are they standard size? because I know some manufacturers run small or large.
Old 01-02-2013, 07:27 AM   #66
mav1c
Hoodbridge!
Member#: 560
2006 STi, '11 A4
Why are you asking? Those tires are garbage. Cheap crap. If you're going to spend the money, get decent tires.
Old 01-02-2013, 07:34 AM   #67
OK Houston
we have an Uncle
d00000000000000d...this one is a lost cause like that whatterbolag d0000d....
Old 01-02-2013, 07:40 AM   #68
krzyss
Member#: 8365
2013 Ford Focus SE
It is not my money but one will get better bang for the buck (if performance is the objective) going with smaller (smaller diameter and width) wheels and smaller (matching the wheel size) tires from top manufacturer than buying big wheels (usually heavy) and junk large tires.
Just my opinion.
Krzys
Old 01-02-2013, 07:54 AM   #69
OK Houston
we have an Uncle
Just my opinion.
Krzys
but d00000000000000000d...it aint k00 not to put the wrong size, cheap ass, junk wheels on yer car with stupid ****ty too big tires
every kiddie knows THAT
Old 01-02-2013, 07:55 AM   #70
mav1c
Hoodbridge!
Member#: 560
2006 STi, '11 A4
I think you're right. I've been trying to help...
Old 01-02-2013, 08:03 AM   #71
meat_WRX
Member#: 96919
2004 sti
black
lol. i read all 3 pages.
meat_WRX is offline   Reply With Quote
Old 01-02-2013, 08:05 AM   #72
OK Houston
we have an Uncle
does yer brain hurt???
do ya need a drink??
do ya wanna slap somebody????
Old 01-02-2013, 11:53 AM   #73
JokerGT
Member#: 196433
2006 WRX Sedan
UGM
Trying to figure out why they are crap.. and trying to figure out which tire will fit well. I know you told me to go with the Hankook Ventus V12 evo K144. Are those regular size or are they "XL" as well? I definitely don't want a larger size of the 255/35's. If those tires run large ill take the 245/35's
Old 01-02-2013, 12:11 PM   #74
mav1c
Hoodbridge!
Member#: 560
2006 STi, '11 A4
They're cheap Chinese tires. Why do you think they cost so little? They won't have good grip anywhere (dry or wet), and will be more prone to damage (week sidewall). The Hankooks aren't much better, but they're a little better.
I'd still recommend getting the 17x9 +42 DPT with 245/40-17 tires.
The Hankook V12s don't tend to run wide AFAIK.
Old 01-02-2013, 12:45 PM   #75
JokerGT
Member#: 196433
2006 WRX Sedan
UGM
Hmm.. the difference between the crappy Chinese and a little better hankooks is a $220 difference.
Here are the specs comparing the 17x9 +42 and the 18x9.5 +35
http://www.rimsntires.com/specs.jsp?...9&text2=18x9.5
Only difference really is that the 18x9.5 sticks out half an inch further..(leaves even more room for suspension than the 17x9's)
Decisions.. decisions..
