Welcome to the North American Subaru Impreza Owners Club Friday May 29, 2015
Mid West Subaru Owners Club
Go Back   NASIOC > NASIOC Chapters > Mid West Subaru Owners Club Forum -- MWSOC
Old 12-29-2012, 10:54 PM   #7026
sackytar
Member#: 149262
03WR Rally/XTDD/98SJ
PrimerGrey
Originally Posted by Travisty View Post
The reading I've been doing suggested using the throttle body coolant lines, especially if you have done the TB Coolant Lines Bypass, which I've already done. I'm considering getting some tubing and running my coolant over to my wastegate since TiAL is claiming that the unit will last 5-10 times longer.
My only hesitation is having those lines running that close (relatively) to the down pipe/dump tube/turbo.
It'd be nice the bypass the TB. I wonder where the cleanest route would be to get to the WG. Theyre so new I haven't seen a write up for it yet. You could also heat wrap the lines with thermotek near the WG.
Old 12-29-2012, 11:02 PM   #7027
Travisty
Member#: 241216
2000 Outback
2013 SWP BRZ
Yeah, I thought about that. Technically the down pipe should be wrapped and the turbo should have a blanket, but my car won't have that stuff for a while.
Shortest route would be to Tee in to the coolant feed/return lines for the turbo, but I don't like the thought of using those lines in case they start a leak. I like the throttle body lines idea better.
Travisty is offline   Reply With Quote
Old 12-29-2012, 11:12 PM   #7028
sackytar
Member#: 149262
PrimerGrey
Yeah I would rather have the tb lines blow before turbo lines. Seems like a lot of overkill for virtually no performance gain.
I can see the benefits if a car was dedicated track car. Still look for a write up curious to see how people are routing them.
Old 12-30-2012, 09:49 AM   #7029
Layvon
Member#: 195711
STi 04/05/06/07
JBP / OBP for now
Could also use the return line from the reservoir that goes to the radiator. And daisy chain from one to the other or just tee before and after.
I have dual mvr on mine and I agree with posts above about it being overkill, and more for a track car. Where mine are on the car it would be hard to plumb because it is on the front right corner of motor below the power steering tank.
Old 12-30-2012, 08:01 PM   #7030
Travisty
Member#: 241216
2000 Outback
2013 SWP BRZ
Originally Posted by acmarcus View Post
If you put mud flaps on your car you're fuel rails will leak!! Ill stay away from mud flaps for that reason
Took my mud flaps off and my fuel rails stopped leaking. Reinstalled the mud flaps, and they started leaking again. WTF?
Old 12-30-2012, 08:07 PM   #7031
Shortpersonbk
Member#: 319017
12 sti 700+whp
it wants to be a evo
Seems legit
Shortpersonbk is offline   Reply With Quote
Old 12-30-2012, 08:12 PM   #7032
SVT_2_WRX
Member#: 270699
2005 WRX Wagon
I really wanna put some mudflaps on too...sounds like a bad idea haha
SVT_2_WRX is offline   Reply With Quote
Old 12-31-2012, 07:39 AM   #7033
Travisty
Member#: 241216
2000 Outback
2013 SWP BRZ
Rob, Aron, and Levon, what spring pressure are you running in your gates, and what's your target boost?
Edit: I had mine set up with 19lbs worth of spring. Took the car out last night and it only opened for about 200rpm near 5000rpm in second and third gear. Took it out again just now and the wastegate didn't even open in first and I hit fuel cut (which is set at about 25psi relative). So, I'll be stepping down spring weight, but I'm not sure how low I should go? I also had a couple questions about the wastegate installation. You guys have my number, so if one of you would give me a call that would be awesome.
I'm assuming I have an leak somewhere because the turbo takes til about 5k to hit full boost now, and seems to taper of pretty quickly. I know the headers will make me lose spool, but deleting the TGV assemblies and running the EWG should have nullified that loss... Hopefully it just needs to be tuned.
Old 12-31-2012, 12:32 PM   #7034
Mplvan
Member#: 319020
15 STI
04 Fozzy XT
I read somewhere that the spring rate sounds be 75% of peak boost?
Mplvan is offline   Reply With Quote
Old 12-31-2012, 12:45 PM   #7035
Travisty
Member#: 241216
2000 Outback
2013 SWP BRZ
That is probably better than me trying to go just under my peak desired boost, but if my 19psi spring combo isn't actually opening the gate until 25~psi, I think I'll do around a .9 or 1 bar setup. Thanks Louis.
Old 12-31-2012, 12:47 PM   #7036
187mustang
Member#: 305172
2006 Wrx STI
Wrb
Well the Wrx is gone. Officially sold. Now the Sti is on the road and gets the snow tires put on wed. Wed the stock Wrx wheels will be available.
187mustang is offline   Reply With Quote
Old 12-31-2012, 01:00 PM   #7037
Travisty
Member#: 241216
2000 Outback
2013 SWP BRZ
LOL! Just found my air line feeding the EWG was loose... No wonder it wasn't venting!
Old 12-31-2012, 01:54 PM   #7038
acmarcus
Member#: 166290
04 EJ207 GT30R 6MT
SRR Widebody Wagon
Mine is at either 14 or 15 psi
acmarcus is offline   Reply With Quote
Old 12-31-2012, 02:07 PM   #7039
Layvon
Member#: 195711
STi 04/05/06/07
JBP / OBP for now
Mine is 16psi. Decent rule of thumb is half of target, but you found your issue anyway.
Old 12-31-2012, 02:34 PM   #7040
EtotheZ
Member#: 315241
2015 STI
Dark Grey Metallic
Anybody interested in (4) Stock WRX 235/45/17 Dunlop SP Sport 01s? Have about 7500 Miles on em all of them still in really good shape. Threw Blizzaks on for the winter then going bigger come Spring. Would rather sell them local.
EtotheZ is offline   Reply With Quote
Old 12-31-2012, 04:12 PM   #7041
Travisty
Member#: 241216
2000 Outback
2013 SWP BRZ
Threw in a combination that should net me 15psi.
......Aaaaand it works! Yay, EWG is fun! It's not near as loud as other people have said, but then again my car is kinda loud to begin with....
Old 01-01-2013, 02:18 AM   #7042
Layvon
Member#: 195711
STi 04/05/06/07
JBP / OBP for now
The rule of thumb i gave was for a maximum spread, obviously im not running 32psi w/ electric control but I also don't want it cracking at low levels.
Just wanted to clarify.
And yeah I was expecting it to roar too, and I think between the fact I don't care about the noise because it is foot regulated and the fact I'm only spinning to 4500 right now. I was kinda disappointed
Old 01-01-2013, 09:53 AM   #7043
acmarcus
Member#: 166290
04 EJ207 GT30R 6MT
SRR Widebody Wagon
are you running a hybird boost controller? i have to agree with you, its not as loud as i thought it would be either. I guess it might be diff if you have a quite exhaust..
Old 01-01-2013, 10:03 AM   #7044
Travisty
Member#: 241216
2000 Outback
2013 SWP BRZ
Yeah, it's a hybrid setup using a GM EBCS and a Hallman Pro. Right now my WGDC is at zero, and the manual is backed all the way off so I'm just running spring pressure.
Old 01-01-2013, 10:44 AM   #7045
acmarcus
Member#: 166290
04 EJ207 GT30R 6MT
SRR Widebody Wagon
Burger King your choice of hangover food?
Old 01-01-2013, 11:15 AM   #7046
Travisty
Member#: 241216
2000 Outback
2013 SWP BRZ
No, I was really looking forward to some MickeyD's rootbeer, but they didn't have their lunch menu up yet.
I rolled by your shop looking to see if I could give you a EWG blast, but apparently you guys are playing hooky today?
Old 01-01-2013, 12:47 PM   #7047
acmarcus
Member#: 166290
04 EJ207 GT30R 6MT
SRR Widebody Wagon
I wish I was playing hooky today. Had to take Down tents downtown from last nights party's.
Old 01-01-2013, 12:55 PM   #7048
Travisty
Member#: 241216
2000 Outback
2013 SWP BRZ
Time and a half I hope?
Old 01-02-2013, 06:39 AM   #7049
Travisty
Member#: 241216
2000 Outback
2013 SWP BRZ
Founders meet next Monday.
Old 01-02-2013, 07:25 AM   #7050
sackytar
Member#: 149262
PrimerGrey
DId you ever get those rails you made flow tested?
Anyone here from the Grand Rapids, Holland, or Muskegon MI areas? Scooby do Mid West Subaru Owners Club Forum -- MWSOC 19 05-25-2012 02:09 PM
Good alignment shops in the Grand Rapids/Muskegon areas? Paradenu Mid West Subaru Owners Club Forum -- MWSOC 3 12-08-2006 01:20 PM
Anyone close to Grand Rapids going to the Ojibwe ProRally? penjaja Mid West Subaru Owners Club Forum -- MWSOC 4 08-13-2002 01:55 AM
Grand Rapids metroplanner Mid West Subaru Owners Club Forum -- MWSOC 0 06-15-2001 05:00 AM
Grand Rapids MI Autocross Scooby do General Forum Archive 0 09-27-2000 03:26 PM
