Welcome to the North American Subaru Impreza Owners Club Wednesday March 4, 2015
Texas Impreza Club
Texas Impreza Club Forum sponsored by Gillman Subaru Houston
and Gillman Subaru San Antonio
Go Back   NASIOC > NASIOC Chapters > Texas Impreza Club Forum -- TXIC
Closed Thread
Old 12-31-2012, 11:47 PM   #1926
RunninKurt
Member#: 338292
2003 Ford Focus ZX3
Red
Changed my oil. Yum.
RunninKurt is offline
Old 01-01-2013, 02:15 PM   #1927
Timithy82
Member#: 293462
2011 WRX Premium 4DR
front end modification... with the help of a slipping clutch..
was going down wellsbranch from dessau and the road goes to the right a little.. when going down that right curve, I shifted from 4th to 5th going about 45-50mph. with the clutch slipping, the rpm jumped and I guess when the clutch caught grip, the tires lost grip. The car spun and it was pitch dark out there so I dont know what I hit.. I hope the insurance company totals it.. grrr makes me mad!!!
Timithy82 is offline
Old 01-01-2013, 02:27 PM   #1928
ierichuljev
Member#: 330442
Midnight Black Pearl
Installed my kartboy short throw shifter with all the bushings ! It was a bitch /:
ierichuljev is offline
Old 01-01-2013, 02:28 PM   #1929
ierichuljev
Member#: 330442
Damn are you okay!!? What year is that anyways ?
Old 01-01-2013, 02:31 PM   #1930
Timithy82
Member#: 293462
I'm okay. Thankyou.. Felt like I hit a speed bump.
MY11...
Old 01-01-2013, 03:24 PM   #1931
c_quiasua
Member#: 318963
2008 WRX STi 5-Door
Was it really that bad. I'm about to order mine :-(
c_quiasua is offline
Old 01-01-2013, 04:42 PM   #1932
TOI
Member#: 238230
98 impreza sedan
it really doesnt look bad at all, maybe a new rad support and body pieces
TOI is offline
Old 01-01-2013, 05:29 PM   #1933
dajeepman
Member#: 329840
2008 Subaru Outback
Gold
I spot cleaned the carpet and the seats today
dajeepman is offline
Old 01-01-2013, 09:41 PM   #1934
ierichuljev
Member#: 330442
MY11...
Damn that's weird that your clutch is already slipping might have been a defect !
Old 01-01-2013, 09:45 PM   #1935
ierichuljev
Member#: 330442
Well make sure you have plenty of extensions and socket sizes . Buy new Grease and make sure you have the snap ring remover . It's simple just a really tight fit the mistake I did was leave it in 1st gear wheb i I did all the work . I would leave in neutral if I were you . It pretty short now though I like it
Old 01-02-2013, 12:43 AM   #1936
TOI
Member#: 238230
98 impreza sedan
thinking again about going rwd in the wagon and having some fun before looking for a donor for a swap.
TOI is offline
Old 01-03-2013, 03:30 PM   #1937
TOI
Member#: 238230
98 impreza sedan
almost lost a wheel going down the highway, cause i forgot to re tighten my lug nuts after picking my car up form Cobb. and found out i can tripod my car getting into my driveway.
TOI is offline
Old 01-03-2013, 11:30 PM   #1938
Wagaru
Member#: 169297
1996 Impreza Coupe
96 LSi Sedan/97 Outback
Sortaflush!
Wagaru is offline
Old 01-04-2013, 01:27 AM   #1939
laxman2001
Member#: 268558
2008 STi
heatshield arrived today.
Shop says I need a new power steering pump though. And brake pads.
What do you guys like, anyway? Here's my list:
my OEMs are worn out, and trying to decide what to get. I definitely want something that performs as well if not better than my OEM pads, and while I wouldn't mind less dust it's not a dealbreaker. I doubt I'd care about noise at all.
Car is definitely a daily driver, but I'd like to get into autocross, maybe rallycross, and possibly a track day.
So after far too much googling and searching here, my list looks somthing like this:
1. OEM (good, but expensive)
2. Mu B Spec (almost as expensive as OEM, similar performance, maybe a bit less initial bite, less dust and noise)
3. Mu HC+ (even more expensive, more to the track side of things)
4. Ferrodo DS2500 (More toward the aggressive side, with plenty of dust)
5. HP+ (sounded like they were noisy and dusty, though presumably work well enough)
Do I have that about right? What do you guys suggest? I haven't seen much info on the HC+.
laxman2001 is offline
Old 01-04-2013, 02:51 AM   #1940
Griever423
Member#: 118749
2013 BRZ
Just starting out in autox the OEM pads would be just fine. You probably won't even heat your brakes fully as short as the runs are.
For reference I did time trials consisting of 3-5 laps on a pretty lengthy 1:20ish course and the OEM pads were perfectly fine. This was in an 06 STi
Also something like HPS pads or Stoptech pads will be fine too if OEM is too expensive.
Griever423 is offline
Old 01-04-2013, 03:25 AM   #1941
laxman2001
Member#: 268558
2008 STi
My view is kinda that I don't want to get "worse" pads. I'm too used to the bicycle world where you ride it till something breaks then get something better.
I've seen too many threads about the HPS and Stoptechs being worse than OEM
Old 01-04-2013, 10:56 AM   #1942
SilverSpool
Member#: 55869
BMW / Ducati / Kawa
135i / M796 / ZX6R
Hawk pads have great bite.
SilverSpool is offline
Old 01-04-2013, 10:59 AM   #1943
Wagaru
Member#: 169297
1996 Impreza Coupe
Hawk hps pads do have great bite and very little fade
Wagaru is offline
Old 01-04-2013, 11:21 AM   #1944
m1r4g3
Member#: 220476
2--> 06 STI & 12 Leg
WRB & SWP
installed my ebcs
m1r4g3 is offline
Old 01-04-2013, 11:48 AM   #1945
Butterz
Member#: 21205
2004 Poopwagon
2010 135i
Ground off a stupid dimple in the top-hats for maximum (...or minimum?) camberz!
Butterz is offline
Old 01-05-2013, 08:04 AM   #1946
Likeorasgod
Member#: 247465
'08 WRX
Went to jack in the box last night, got home and found out my cup had a hole in it, so most of my soda went into my cup holder. Guess today is a good day to detail and clean my dirty car. Prob do an oil change too while I'm at it.
Likeorasgod is offline
Old 01-07-2013, 10:17 PM   #1947
Excision
Member#: 294622
2007 STI - WRB
Perrin GTX3076r, Slow
Originally Posted by Wagaru View Post
Sortaflush!
Look what i spotted on reddit.
Excision is offline
Old 01-07-2013, 10:19 PM   #1948
m_clark54
Member#: 224322
2013 WRX Spec Ed
Tangerine Orange
Someone else is a redditor... sweet!
Took the forester out some muddy roads.
This past weekend, took the new outback offroading. Tested out that ground clearence.
m_clark54 is offline
Old 01-07-2013, 10:28 PM   #1949
shilohb
Member#: 214121
2005 604whp/543wtq
fp3586 twinscroll
Installed my carbonfiber driveshaft
shilohb is offline
Old 01-07-2013, 11:19 PM   #1950
TOI
Member#: 238230
98 impreza sedan
i sanded off some surface rust and primed all my bare metal.
TOI is offline
Closed Thread
what did you do to your car today? Schrecken Bay Area Impreza Club Forum -- BAIC 11 09-25-2012 04:08 AM
What did you do to your subie today?! 07imprezadrifter General Community 277 06-15-2009 12:42 AM
What did you do to your Scoob today? Sheehan North West Impreza Club Forum -- NWIC 27 11-23-2007 01:02 PM
