Old 01-01-2013, 03:10 PM   #1
KD1CA
Member#: 341974
09 WRX
BLAACCKK
Default 09 cutch? Plz help. Work tomorrow
Hello, I been searching forums but I this is my daily driver and need some help.
2009 wrx(no mods)
Last night while driving home in any gear when I went over 3000 rpms I didn't get any pull. So today I went out to look for any shop that was open to fix this. And once I stopped I lose all acceleration and clutch Pedal went soft.
I am think that the clutch is gone.?
Any Insight would be helpful.
Thank you so much
KD1CA is offline   Reply With Quote
Old 01-01-2013, 03:43 PM   #2
ah2049
Member#: 261863
2015 Focus ST
OW
While I don't have an answer for you, you might want to put up a little more information about the car and the symptoms. Such as modifications, mileage, and any other problems you might be having, etc...
ah2049 is offline   Reply With Quote
Old 01-01-2013, 03:46 PM   #3
KD1CA
Member#: 341974
09 WRX
BLAACCKK
2009 wrx(no mods)
Thank you so much
It's a 2009 wrx no mods with 65k miles.
Once I went over 3000rpms I felt no acceleration and then not even ten minutes later from a dead stop the car would not accelerate just keep revving higher
Old 01-01-2013, 04:06 PM   #4
ah2049
Member#: 261863
2015 Focus ST
OW
Sounds like the clutch is done for. Were you running it hard prior to this? Excessive slipping could have overheated it.
I'm assuming it goes into gear, but it just won't move?
Old 01-01-2013, 04:15 PM   #5
KD1CA
Member#: 341974
09 WRX
BLAACCKK
No not running hard last night I was on I95 going 70mph for about 20 miles and I live 15 mins from the exit and that was about 4am and the. I left my house today around 2pm and only drove stopped twice and at the second it wouldn't move at all I hoped out and had to push it to a lot.
Old 01-01-2013, 05:40 PM   #6
danger1138
Member#: 279525
04 rex luger!
MAybe its not the clutch. Could be your slave cylinder is shot, could also be a leaky slave cylinder line.
danger1138 is offline   Reply With Quote
Old 01-01-2013, 10:33 PM   #7
KD1CA
Member#: 341974
09 WRX
BLAACCKK
Ok thanks I will check it out. I am putting a new clutch in tomorrow
Old 01-01-2013, 10:35 PM   #8
WhatTurboLag?
Member#: 243992
2006 WRX TR
Is this your first manual car? Are you the first owner?
WhatTurboLag? is offline   Reply With Quote
Old 01-01-2013, 10:52 PM   #9
KD1CA
Member#: 341974
09 WRX
BLAACCKK
Second manual car and also second owner.
I know how to drive it. But I do sit in an hour of stop and go traffic a day.
Old 01-01-2013, 10:59 PM   #10
ah2049
Member#: 261863
2015 Focus ST
OW
Wouldn't that cause issues with engagement first? As in, it would go into gear, but not out of gear, or vice-versa?
Old 01-02-2013, 07:55 AM   #11
NoGraffix
Member#: 276209
I am Rub
Function>Form
Best way to test the clutch for free:
Get the car going, then shift into 5th (at like 20mph or so) and give it a generous amount of gas. If it starts to bog out and feel like its going to die the clutch is fine, but if the clutch starts slipping and the revs raise quickly then your clutch is done.
NoGraffix is offline   Reply With Quote
Old 01-02-2013, 08:08 AM   #12
KD1CA
Member#: 341974
09 WRX
BLAACCKK
Thanks for the tip! That's what it was doing.
Old 03-24-2013, 04:56 PM   #13
Arwing19
Member#: 341137
2009 WRX
Clutch is gone, happened to mine. Check the actual clutch pedal assembly to see if it's loose, it's happens to a lot of 09s and wears on the clutch. Also the factory firewall will eventually become weak.
Arwing19 is offline   Reply With Quote
Old 03-24-2013, 11:20 PM   #14
Cleck
Member#: 147052
1998 Legacy Outback
Pretty much. If the slave was gone, he'd have no pedal, no return. If the line was leaking, it'd act more like a spongy brake pedal. Engagement, return, but really crappy.
Cleck is offline   Reply With Quote
