Welcome to the North American Subaru Impreza Owners Club Monday May 30, 2016
Old 01-01-2013, 12:26 PM   #1
pharmer81
Member#: 341981
2008 STI
Charcoal
Default Just went Stage 2, trouble codes on reflash, please help
I just installed a Cobb DP and AEM CAI to complement my Magnaflow catback. I reflashed to stage 2 with the appropriate AP tune for Stage 2, 91 octane, with AEM CAI. Immediately upon startup, it threw the following codes:
P2008
P2012
P2021
P2016
Can somebody give me some insight as to what is wrong. It wasn't like they threw it after it was running. It was immediate. I tried a reflash to the LWG map just in case the map was corrupted, and nothing. The car starts and runs, but the check engine light is on, and the Si Drive light and cruise control lights are flashing.
pharmer81 is offline   Reply With Quote
Old 01-01-2013, 12:30 PM   #2
HeroCrank
Member#: 301089
2013 Toyota Tundra
Rock Warrior
Use your AP as a code reader, or search the codes here and report back.
Old 01-01-2013, 12:45 PM   #3
pharmer81
Member#: 341981
2008 STI
Charcoal
Ok. I found a connector that I must have bumped off. Plugged that in, now I'm still left with code P2021.
Old 01-01-2013, 12:51 PM   #4
pharmer81
Member#: 341981
2008 STI
Charcoal
P2021 is intake manifold runner position sensor bank 2
Old 01-01-2013, 01:20 PM   #5
pharmer81
Member#: 341981
2008 STI
Charcoal
I found the sensor on the driver's side of the intake unplugged, so I plugged it in. Now I get P2005 and P2012 before I even start the car, and I get P2006 after I start the car. The interesting thing is there is no way I "accidentally" unplugged this sensor. The previous owner had the Cobb Stage 1 V3.01 93 octane LWG tune loaded, and I never noticed any problems. Would there be any reason he would have had these sensors unplugged? I'm really confused right now. I'm hoping I have a simple problem, but I'm past my depth of knowledge. I though I was just going to be bolting on parts and flashing a tune.
Old 01-01-2013, 07:15 PM   #6
coalslaw
Member#: 324808
2006 IWL Stg2
um could you try putting it back to stock airbox and see if that will change the results?
coalslaw is offline   Reply With Quote
Old 01-01-2013, 07:17 PM   #7
cmiovino
Member#: 134005
2004 WRX Premium
The Cobb OTS MAP does not support the AEM CAI. You either need a stock airbox or Cobb SF intake.
Old 01-01-2013, 07:37 PM   #8
pharmer81
Member#: 341981
2008 STI
Charcoal
Actually, I have the specific map for the AEM. I figured out the problem though. After doing some research as to why the TGV connectors would be disconnected from the intake manifold, it would appear the previous owner did a TGV delete. The stage 1 tune he was running apparently had the trouble codes deleted through Accesstuner Race. Since I have a Mac and cannot run ATR, I reflashed his Stage 1 map, and then flashed my correct Stage 2 map as a realtime flash over the top of the stage 1 map (from my research, this does not affect the trouble code omissions). After doing this, all is well. The car runs great, sounds great, and no codes. Now I'll have to do some data logging and get everything dialed in. Hopefully this topic will be of help in the future to someone in a similar predicament.
Old 01-02-2013, 05:46 PM   #9
bacalhau16
Member#: 297565
2011 WRX hatch
Just so you know, there is an accessport subforum here. You wouldve found better information there.
Technical->Engine management->Accessport
bacalhau16 is offline   Reply With Quote
Old 01-02-2013, 06:00 PM   #10
blue sedan
Member#: 311622
2010 WRX
Cobb has great customer support!If your in doubt call them, they will help you step by step.Good Luck!
blue sedan is offline   Reply With Quote
