#1 |
Member#: 196071
edit: friends are was fixed.
Turns out it was a bad spark plug. thank god!
#2 |
Member#: 185688
NESIC
Vehicle:2006 STi WR Blue |
I would do the compression/leakdown test to be sure.
#3 |
Member#: 185688
NESIC
Also with it being a brand new long block, have you done the first few oil changes yet?
#4 |
Member#: 276209
MWSOC
Vehicle:I am Rub Function>Form |
Did you check the voltages on the knock sensor? It honestly sounds like a fail sensor more then anything else. I can't imagine why the car would knock @ 8* of timing, in vacuum, at stoich AFR, with <1 g/rev load values; it just doesn't make any sense.
#5 |
Member#: 196071
I will try other alternatives prior to the compression and leak down. I dont suspect there to be a problem.
-Yes, all changes were done properly at the right interval with no strange occurrences. -I did not check the voltages. Something that I can do via Romraider logger or with an actual volt meter? |
#6 |
Member#: 222893
NESIC
Vehicle:2012 WRX Hatch 2002 WRB Bugeye |
Knock Sensor sir!
My 02 had the same issue as you. Started out at first only when high humidity/rain. As soon as you touch the gas it pulls -12* and DAM goes to ****. There will be a CEL soon... |
#7 | |
Vehicle:OK Houston we have an Uncle |
take the oil filler cap off with the engine running
does it blow smoke??? yes = its done, stick a fork in it Quote:
![]() and you dont yank out the injectors to do a compression check |
#8 |
Member#: 15306
Vehicle:2011 STi White pearl |
OK, just few questions :
The long block has been changed so you have removed the knock sensor from the previous engine and fitted it onto the new engine. Are you sure you use the correct torque to fit the sensor ? You didn't log the VVT. Did you make any modification in the maps in regards to VVT ? What about timming belt ? |
#9 |
Member#: 53665
NESIC
Vehicle:2011 STI Stg2 w/EBCS 2012 Tribeca Ltd. |
Some food for thought, stock STI does not listen for knock below 0.9 or 1.0 load, depending in which direction you're transitioning in or out of the listening range. What are your threshold set at? Before everybody jumps down my throat on how crappy the stock tune is and all that, the low load timing maps are not that bad. So, why Subaru would do that? It's possible that the sensor may be picking up lots of false knock under low load due to resonances in the engine bay and sounds being interpreted as knock. The knock sensor is nothing more than a microphone whose signal is fed into an analyzer that looks for knock signatures in the feedback. OP, search for false knock. You'll see many threads of people pulling their hair out about this. Low load, cruising situations, crazy FBKC. Makes no sense. Some anecdotal evidence, I tried lowering my listeing thresholds down and it produced exactly what you're describing. My logs started to show major knock events and ECU constantly pulling timing at loads <1.0. ECU would pull timing, more knock, more pull, more knock. That was a year ago. I went back to stock level thresholds as there seems to be more to it that meets the eye. I am actually willing to give Subaru the benefit of the doubt on this one. Now, I am not saying that you're fine. Just pointing out that it's possible that you're chasing a ghost. But, you should investigate to make sure you don't have a problem. If you have an EGT gauge, look at your temps during those events. If they're high, you may not have enough timing.
#10 |
n00b Moderator
Moderator Member#: 10613
South East
Vehicle:2002 USDM WRX WRB |
if its not done..blown up..piston failure due to a lack of fuel.
i would double check anything that the engine is bolted to or bolted to it. |
#11 | ||||
Member#: 196071
Few points: -Knock that low in the G/rev range doesnt make sense. The problem is that I kept the thresholds at a stock level. Now the car has full torque solutions motor-mounts. Now they never produced a problem before I changed the injector o-ring so I dont suspect they are the issue. I have checked the engne bay many many times for something causing ambient noise levels that the knock sensor would pick up and produce knock like symptoms. -As for EGT's being high, you bet! I guarantee that EGT's are massive due to IAM being at zero and running base timing right now. Just to be safe I am not going to disable the knock sensor under 4100rpm and run the risk of potentially melting a valve. -Your post has me thinking. Chasing ghosts is typically what I do. Ha. I am going to take a triple check at whats going on in the engine bay and look for rattles, etc. From there I think I will take a look at the actually knock sensor and see what the hell is going on. Thanks. And always a possibility. |
#12 |
Member#: 196071
Update- no smoke from oil fill cap as I expected. Noticed that I am seeing knock in lower and lower load sites. Really think this knock sensor is on its way out.
#13 |
Member#: 196071
Some new data.
Decided to LOG pretty much everything. It all looks Kosher and perfectly normal. The bucking is getting worse. No oil consumption, no external strange engine noise, no smoke out the oil cap, or exhaust. I just dont get it. The car hasn't thrown a CEL but is nearly undrivable under load. Knocking has pretty well stopped due to IAM at .650 (i assume bucking is due to lack of timing) Havent tested the knock sensor....but I should see the problem in the data. I see f%$* all. Experts.....replace knock sensor? Burn car to the ground? Fuel trims are complete INSANE! https://docs.google.com/open?id=0B-D...2RqNFFIU0JZekU https://docs.google.com/open?id=0B-D...EZreE1SZ2ZiSFk https://docs.google.com/open?id=0B-D...GsxWEloT0NnX0k ![]() Thanks, Nick |
#14 |
Member#: 175565
MAIC
Vehicle:2005 STI CGM Built 351whp/368tq |
If you are stilling having the issues and nothing is showing up in logs, why not just replace the knock sensor and rule that out? They run around $100. Check the voltage first and proceed from there. Aside from your engine insides wanting to be on your outsides, my guess is the sensor as well.
#15 |
Member#: 117854
Vehicle:2003 spec c |
nasioc is definately not the place to get some info. UNLESS you want to be missled)
/returns to romraider |
#16 |
Member#: 53665
NESIC
#17 | |
Member#: 262684
Vehicle:2011 MCS |
![]() Sorry man, not sure what logs you're looking at but none of those are perfectly fine, actually they're the exact opposite. You're maxing out the FLKC threshold even at an iam of 0.625, which happens to also be the boost control cutoff point because your ecu is trying to protect the engine. Compression test it. Your fuel trims are showing that fuel is being pulled because the ecu is detecting an overly rich afr, which can happen with low compression as well. Do the compression/leak down, and boost leak test and come back, then we'll move onto other culprits. |
#18 | |
Member#: 276209
MWSOC
When you do that the accuracy of the data you see goes out the window, so get some logs with parameters that will actually help you evaluate how the car is running and leave a bunch of stuff off. I'm not sure what you mean by the second statement because everything likes completely wacky lol. You need to do what I suggested in my original post, check the voltage of the knock sensors (with a volt meter, sorry I didn't get back to you work got busy) and see if they are function properly, if not replace them. From what I can see this is your obvious problem and is completely distorting the tune on the car. With all the FLKC your timing is literally all over the place, which simply put is in no way good for your engine. |
#19 | |
Member#: 196071
I feel like its strongly correlated to the injector in that cylinder. Somehow it could have gotten damaged or at that specific pule the spray pattern could be bad. Either way I will be pulling the plugs to analyze what they look like. If I see something unusual I will then yank the corresponding injector and send it off for analysis. Heres my thought process - 1 cylinder isn't getting enough fuel (somehow) causing detonation while the others are over compensating to achieve a proper AFR. This is why I am seeing insane long term fuel trims but perfect AFR's. of course I will do a compression test while in there as well. If that doesn't solve the issue I will check out the knock sensor. If that fails, ill set the damn thing on fire. |
#20 |
Member#: 262684
Vehicle:2011 MCS |
the knock sensor isnt hard to get to, just pull the ic off. torque the sensor to spec, it's the easiest of the possible issues... and cyl 1 is furthest from the knock sensor. remember how detonation can occur- poor fuel quality, too much timing, too little fuel, poor compression, hot charge temps. your knock correction is massive, more than just the typical pesky knock. a false knock- like loose bolt on the engine somewhere could cause this. or poor engine grounds too.... check your engine grounds, there should be ground straps attaching to the left and right frame rail and to each head.
#21 |
Member#: 196071
Does anyone know what the knock sensor torque specs are?
Removed the injectors tonight. Obviously looks great. Sending them off for inspection and to be flow tested tomorrow. Will remove the spark plugs tomorrow night and see what they look like. Then address the knock sensor and grounds. Will also do a compression test while I have everything out. That should pretty well remove any possibility of a fuel delivery, spark to compression issue. |
#22 |
Member#: 262684
Vehicle:2011 MCS |
17.4ft-lb
#23 |
Member#: 196071
Injectors are out and off for testing tomorrow. What's interesting here is that all 4 plugs looked awesome. No sign of lean or rich mixture. I think I maybe chasing the wrong ghost. At any rate they need to be tested and cleaned to rule them out.
Wednesday I will do a compression test on the 3 cylinders I can get to just to make sure. As for the knock sensor. This sounds been but I can't locate it. Anyone have some good pictures of its location to share? Also, if I can't figure this out, my next guess is that possibly the timing belt slipped a tooth perhaps? Does this sound like the type of symptoms you'd see? At any rate I has to bent the snot out of the bracket that surrounds the rails and the damn rails themselves to get the injectors out. I hope to god I didn't create more problems. Any comments let r rip! -nick |
#24 |
Member#: 204578
MAIC
IIRC, isn't the sensor bolted to the block, under the intake manifold?
#25 |
Member#: 196071
Thank you sir! looks easy enough to get with a socket.
